FeveredMind Samba Member
Joined: December 28, 2016 Posts: 147 Location: Riverside, CA
Posted: Sat Oct 16, 2021 9:44 pm Post subject: How to identify a 67 gas filler door from a bay window door |
I tried searching with no luck.
Can anyone help me identify what to look for at swap meets to be sure I get a correct door?
Thanks _________________ New to split window busses but learning new things everyday. This forum is a wealth of knowledge. Thank you everyone for sharing. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sat Oct 16, 2021 10:15 pm Post subject: Re: How to identify a 67 gas filler door from a bay window door |
Original paint on the inside? _________________
EverettB wrote: |
FU#5 |
Posted: Sun Oct 17, 2021 7:46 am Post subject: Re: How to identify a 67 gas filler door from a bay window door |
hitest wrote: |
Original paint on the inside? |
Are they the same door or is the 67 a one year only?
For instance, I found these doors at OCTO yesterday, but didn’t purchase one because I couldn’t tell if they were bay or 67. One is marked 70 and I looked at current listings in the split bus classifieds and I couldn’t identify whether these were 67 or bay. That is, unless, 67 and bay doors are the same.
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Sun Oct 17, 2021 6:21 pm Post subject: Re: How to identify a 67 gas filler door from a bay window door |
I think they are the same. Here's a '67 but the inner view.
Clara Samba Member
Posted: Mon Oct 18, 2021 3:11 am Post subject: Re: How to identify a 67 gas filler door from a bay window door |
Imadesignerd wrote: |
hitest wrote: |
Hm... you could go check the part numbers in the Parts Lists.
The early bay parts list shows 211 829 605 as flap - tank filler to 211 2300 000
Does the late splitty Parts list show the same number for a 67 bus gas flap? If so, it is the same part. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Mon Oct 18, 2021 9:45 am Post subject: Re: How to identify a 67 gas filler door from a bay window door |
Clara wrote: |
hitest wrote: |
Does the late splitty Parts list show the same number for a 67 bus gas flap? If so, it is the same part. |
Thanks for pointing out these part documents. I had no idea these existed. This is what I found in the split documentation. I assume I am looking for 117 (I know that the 67 door has no lock on it), part number 211 829 605
So this is what I found in the bay window document.
This means they are the same, but I need an "early bay" door? _________________ New to split window busses but learning new things everyday. This forum is a wealth of knowledge. Thank you everyone for sharing. |
Krustybus Samba Member
Joined: February 16, 2004 Posts: 442 Location: SE Michigan
Posted: Mon Oct 18, 2021 10:54 am Post subject: Re: How to identify a 67 gas filler door from a bay window door |
So by crossing the the vin numbers from here:
https://www.thesamba.com/vw/archives/info/chassisdating.php
In chronological order
#121 261 829 605 is up to the last day of the 66 model year
#117 211 829 605 is 67 to 71
#43 211 829 605 C is 72 and up
QED _________________ Tim |
Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Posted: Sun Oct 24, 2021 1:53 pm Post subject: Re: How to identify a 67 gas filler door from a bay window door |
I dug through my fuel filler flap stash recently, and took this pic showing the difference between a '67 and a bay fuel filler flap.
The '67 flap has two weld nuts for the screws that mount it. The early bay unit has theads going through the sheet metal bracket. It looks like the split one is heavier duty, but I have never seen a bay unit fail.
The bay unit also has a sticker saying which gasoline to use.
They are interchangeable.
_________________ .
Wanted:
