zachattack1966 Samba Member
Joined: September 08, 2021 Posts: 16 Location: Glendale, Arizona
Posted: Mon Oct 18, 2021 11:53 am Post subject: Starting a rebuild of a 1966 Beetle Sedan |
Hey Guys!
I'm starting a restoration on my grandpas 66 pearl white sedan. It has all matching numbers and the original and basically untouched 1300 motor. It's been sitting in a gravel backyard since the late 80's and it's an Arizona car so rust is a pretty minor concern other than a new battery tray.
I can post pictures if it will help but I was hoping to get a little advice on where to start, this is my first restoration.
I've already been researching for months, all I can think about is this car, I can't wait to share my excitement with you all!
I also wanted to test just how active these threads are |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Mon Oct 18, 2021 12:17 pm Post subject: Re: Starting a rebuild of a 1966 Beetle Sedan |
Yes, post pictures, good pictures. Put the in the Gallery here, then upload to this thread.
Also post pictures of the battery and generator, as your 1966 may be updated to 12 volt now. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2507 Location: Santa Cruz, CA
Posted: Mon Oct 18, 2021 2:28 pm Post subject: Re: Starting a rebuild of a 1966 Beetle Sedan |
zachattack1966 wrote: |
I also wanted to test just how active these threads are... |
Lots of helpful folks here, and this forum is quite active, so post any questions you might have and I'm sure you'll get quick responses.
Also check the 'stickys' at the top of the page, and try using the 'search' feature for topics that you might need help with.
Everyone here likes photos...so post 'em if you got 'em. Here's how: https://www.thesamba.com/vw/forum/viewtopic.php?t=6 _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
gt1953 Samba Member
Posted: Mon Oct 18, 2021 2:40 pm Post subject: Re: Starting a rebuild of a 1966 Beetle Sedan |
Do show us the vehicle.....lts of help here as well.
66 nice year as the first ball joint front end. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Mon Oct 18, 2021 2:41 pm Post subject: Re: Starting a rebuild of a 1966 Beetle Sedan |
For starters, safety first:
- replace all fuel lines (under tank, under car, engine bay).
- check or replace soft brake lines. Ensure the system can stand maximum pressure.
- check the handbrake.
- check the battery (it can produce hydrogen gas which can ignite).
- check for any wiring faults that could short and cause a fire.
Then start checking for rust, including where you can't see easily.
Lots of folks can do good mechanical work (maybe even yourself), but few can do proper bodywork, so check that most carefully.
BSheldon Samba Member
Posted: Mon Oct 18, 2021 9:12 pm Post subject: Re: Starting a rebuild of a 1966 Beetle Sedan |
Definitely show us. I always want to see all the other 66s out there! There is a ton of information here, and people who have already walked any path you're about to go down with the car, so definitely document it here and let us follow along! _________________ "Betty" - 1966 L41 Sedan |
Posted: Tue Oct 19, 2021 6:48 am Post subject: Re: Starting a rebuild of a 1966 Beetle Sedan |
Here are some of the pictures I’ve snapped of the car as it was being moved to my house. I haven’t gotten a chance to do much other than clean all the junk out of it and scrape up the old tar board. The pans look kind of dented under where the front seats should be and there’s a rust hole under the battery.
Poor girl was tapped on the passenger side years ago but I’ve secured a replacement fender.
KTPhil Samba Member
Posted: Tue Oct 19, 2021 8:55 am Post subject: Re: Starting a rebuild of a 1966 Beetle Sedan |
The pot of gold at the end of the rainbow! |
Posted: Tue Oct 19, 2021 9:14 am Post subject: Re: Starting a rebuild of a 1966 Beetle Sedan |
KTPhil wrote: |
Awesome picture right? I’ll try to get some better pictures of the engine, cleaned up floor, and the collision damage
I’m really excited to drive this car |
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
Posted: Tue Oct 19, 2021 9:16 am Post subject: Re: Starting a rebuild of a 1966 Beetle Sedan |
Welcome, always nice to see another 66! Doing a build thread is really helpful for you, it's a great way to track your own progress as well as ask advice along the way. Post lots of pics, future you will find them very useful when you go to reassemble something to you took apart months or years ago. _________________ 1973 Superbeetle: 1st car, owned since age 12. Update thread --> https://www.thesamba.com/vw/forum/viewtopic.php?p=9919140#9919140
1966 Beetle: My new project. (SOLD) Build thread--> https://www.thesamba.com/vw/forum/viewtopic.php?t=678040 |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
Posted: Tue Oct 19, 2021 9:44 am Post subject: Re: Starting a rebuild of a 1966 Beetle Sedan |
Welcome and good looking and solid starting point for you.
You will find almost every bit of info on thesamba with many super helpful members. My advise until you have a solid plan would be to be careful on what you throw out. Restoring the old part many times is better than anything you can buy new.
Have fun with it. Make a plan. Set a budget. Label everything you remove so you remember where it goes later and whatever you think your going to spend double it. _________________ 1964 Original Owner build Thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=702135&highlight=
Ambulance Fan's. https://www.thesamba.com/vw/forum/viewtopic.php?t=627707&highlight=
Parts i am looking for:
64 bug nice used front/rear Black LHD floor mat. |
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2009 Location: Texas
Posted: Tue Oct 19, 2021 10:10 am Post subject: Re: Starting a rebuild of a 1966 Beetle Sedan |
^^^ X2!
Good advice. You'll be glad you didn't throw away stuff that you thought might be useless. At least hold onto old parts you remove until you've got your bug safe and running, then you can decide if you want to toss or even sell the old parts. _________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
marklee Samba Member
Joined: March 24, 2009 Posts: 821 Location: Flintshire, North Wales
Posted: Tue Oct 19, 2021 10:43 am Post subject: Re: Starting a rebuild of a 1966 Beetle Sedan |
just getting to the end of the refurbishment on my 66 pearl White and Pigalle car _________________ CGLI qualified body repair and refinish tech
CGLI qualified motor repair tech
Qualified automotive Glass installer
Motor Insurance Repair and Research Centre,Thatcham, Advanced Vehicle Damage Estimator.
Police qualified vehicle examiner
Police Class 1 High performance, pursuit trained Advanced driver |
Posted: Tue Oct 19, 2021 10:49 am Post subject: Re: Starting a rebuild of a 1966 Beetle Sedan |
just getting to the end of the refurbishment on my 66 pearl White and Pigalle car[/quote]
That’s awesome man!! And pretty much exactly what mine will end up looking like. I love the lower profile bumpers.
If you don’t mind me asking you, what kind of budget did you set for the build? Did that budget change throughout the project? I’d absolutely love to hear the story behind this car.
Last edited by zachattack1966 on Wed Oct 20, 2021 11:09 am; edited 1 time in total |
Posted: Tue Oct 19, 2021 11:02 am Post subject: Re: Starting a rebuild of a 1966 Beetle Sedan |
There were lots of spare parts in the trunk along with 3 of the 4 hubcaps. I was able to find the missing sister in my grandpas shed.
I threw out anything that was rusted beyond use or fuses that were smashed up.
The rear bench is also out and under a tarp, it is the pigalle red but it has a brown cover stapled over it (that’s gonna to for sure ) |
Posted: Tue Oct 19, 2021 12:03 pm Post subject: Re: Starting a rebuild of a 1966 Beetle Sedan |
As far as pre restoration prep goes, what kind of books and videos should I be hunting for?
For work area, I'm working in a gravel side yard under a car port that will keep the car out of the weather. I'm hoping to rig up some lights soon too so I can work out of the sun
Also if anyone here in Arizona is willing to share some of their local experience that would be greatly appreciated (shop recommendations, etc.) |
Posted: Wed Oct 20, 2021 9:39 am Post subject: Re: Starting a rebuild of a 1966 Beetle Sedan |
If you don’t mind me asking you, what kind of budget did you set for the build? Did that budget change throughout the project? I’d absolutely love to hear the story behind this car.[/quote]
I bought the car, an unmolested example 9 years ago. I used it intermittently until a new business and relationship breakdown meant it was stored in a damp garage and was neglected. Last April it was dragged out of storage and there is no real budget. The interior came from TMI 5 years ago, Ima body and paint man by trade so did all the metalwork and prepaint repairs myself, spurred on by the fact its going to be my wedding car in February. Ive repaired rather than replaced where I can, hand made the door bottoms and rear 1/4 bottoms only buying heater channel bottoms to repair what was there. I made a friend of a bodyshop and painter locally and he agreed to a self prep job and painted it for me in his shop for not much money, a couple of hours labour and the cost of the top coat paint...
Ive got roughly 120 hours in it over the last 6 months, just got to renew the whole braking system and its back on the road _________________ CGLI qualified body repair and refinish tech
Posted: Wed Oct 20, 2021 10:44 am Post subject: Re: Starting a rebuild of a 1966 Beetle Sedan |
Going out on a limb here and assuming this is going to be all new for you. If that is the case then research will be your best friend but i also understand that you want to get dirty too. I would suggest.
1. Understand what you want to do with it. Driver, stock, custom, etc. (Not that this will change over time)
2. Understand your budget as that will affect the above and no matter what you think you will spend you will spend more. Alot more.
3. Understand your skills and your tools today. What you do not have you can learn or borrow for the most part.
Once you have that in mind then unless your going for a full ground up resto i suggest you forget about the body and get it mechanically sound. Any car that has sat around for a while will need all systems gone through and in doing this you will learn a ton and discover all the other bad parts of your car.
(rust) You also get your hands dirty and start making progress.
- Brakes. Rebuild them all. Don't try to "go" until you know you can "stop". While in there check your axle bearings. Replace your flexible brake lines.
- Fuel. Clean it all and look for rust in your tank. Likely rebuild your carb and fuel pump. No sense trying to start the engine if your fuel is bad. Replace ALL soft fuel lines
- Electrical. Basics like battery, starter, ignition and generator/regulator.
- Engine. Read up on starting a motor after long storage so you do not break your piston rings. Oil, points, plugs, timing, etc. Check it all and see if you can get it to "go".
- Trans. Check the oil and maybe change it. Check your shifter, shifter bushings and shift coupler. Clutch & throw out bearing.
- Safety. Lights, seats glass and all that stuff.
At this point you have a driver and satisfaction plus alot of learning under your belt. Re-assess your plans from the start and figure out where to go next.
Anyways. If i were getting my son going this is what i would suggest.
As far as sources for info. Get yourself a Bently Manual. Used is totally fine. You may want to get an Idiot book (John Muir) and you will find almost everything you need on YouTube or right here on thesamba.
Good luck and will be watching. _________________ 1964 Original Owner build Thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=702135&highlight=
Posted: Wed Oct 20, 2021 11:03 am Post subject: Re: Starting a rebuild of a 1966 Beetle Sedan |
Good luck and will be watching.[/quote]
I can't tell you how much all this useful information means to me. I know that at the moment my eyes might be a little bigger than my stomach but I'm enthusiastic nonetheless.
I'm balancing senior year of high school and baseball at the moment and in about a year I'll be moving to Flagstaff so progress will come slowly but surely.
I think this helps that I don't need to completely disassemble the whole thing and then piece it back together. Are you suggesting that you can always change things as you go or after you get them to a working condition? I.E. priority getting it moving and not prone to explode |
Posted: Wed Oct 20, 2021 11:07 am Post subject: Re: Starting a rebuild of a 1966 Beetle Sedan |
Ive got roughly 120 hours in it over the last 6 months, just got to renew the whole braking system and its back on the road[/quote]
That's cool that you were able to complete so much of it yourself, a gratifying feeling I'm sure. Best of luck with the brakes, I'll be making sure to keep up with the car if you keep posting |
