walter kandetzki Samba Member
Joined: June 02, 2003 Posts: 918 Location: Dillwyn, VA
Posted: Mon Oct 18, 2021 6:23 pm Post subject: Stock 1500 cooling stuff on dual relief case |
Hi guys I’m going to run a 1600 single port in my 68 with a dual relief case but use the stock 1500 cooler,fan housing,correct 205m distributor 30 pict 2 carb and pierburg square top pump.anyways would I be ok using the non late (71+) cooling system or do I need to use it?I plan on the tennis ball trick as well..thanks |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9955 Location: Huntington Beach, CA
Posted: Mon Oct 18, 2021 6:27 pm Post subject: Re: Stock 1500 cooling stuff on dual relief case |
You should be fine. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
Posted: Mon Oct 18, 2021 6:29 pm Post subject: Re: Stock 1500 cooling stuff on dual relief case |
I would use a dog house shroud and fan. With the decklid up you'll never know and the engine will run it's best.
30PICT2 and 205M are just fine. _________________ Glenn
Member #1009
#BlueSquare |
Igpoe Samba Member
Joined: February 24, 2019 Posts: 853 Location: South Boston, VA
Posted: Tue Oct 19, 2021 3:17 am Post subject: Re: Stock 1500 cooling stuff on dual relief case |
If the '68 fan and shroud don't provide adequate cooling I would look for the reason first. If you must buy a fan and shroud, then yes, doghouse will be the way to go. _________________ '73 super. |
