nikbrewer Samba Member
Posted: Tue Oct 19, 2021 7:56 am Post subject: Best aftermarket carbs for 1679, stock motor |
looking at minor upgrades for my SB this winter. Looking at putting on 88mm jugs, maybe some mild heads, and 1.25 rockers.
Fueling is the thing I am not sure about. I am considering doing the Holley sniper EFI, but will probably try some carbs first.
There are so many options, and I don't know what works best. Just want drivability and easy starting in all temps over pure performance.
I don't want dual 2 barrel carbs. Had that once, don't feel like messing with it on this mild of an engine.
So, here are all the options I am finding. Just need some feedback on what is easiest to tune, and drive.
1. Single 2 barrel carb, like the EMPI Single 40 HPMX Carb Kit - https://www.jbugs.com/product/47-7315.html
2. 32/36 progressive carb, like EMPI Progressive 32/36F Single, 2 Barrel Carb Kit - https://www.jbugs.com/product/47-0622.html
3. 2 barrel synchronous carb, like EMPI 38EGAS Single Carburetor Kit - https://www.jbugs.com/product/47-0628.html
4.Dual 34 EPC 1 barrels - EMPI Dual 34 EPC Carb Kit - https://www.jbugs.com/product/47-7411.html
5.Dual 35 mm solex - https://scatvw.com/product/economy-solex-35mm-carb-kit-with-electric-choke/
6. Duel 40mm solex - https://scatvw.com/product/super-dual-carburetor-kit/
7. Dual weber 34mm ICT - https://www.cbperformance.com/product-p/6428.htm
With all these options, i am totally confused what is the best options.
Any advice would be super helpful |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Tue Oct 19, 2021 8:09 am Post subject: Re: Best aftermarket carbs for 1679, stock motor |
Stick with a single Solex 34PICT-3. I've heard that people are enlarging the 34PICT-3 for more performance.
BTW.. slip in 88s are not the best option. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Oct 19, 2021 8:56 am Post subject: Re: Best aftermarket carbs for 1679, stock motor |
Glenn wrote: |
BTW.. slip in 88s are not the best option. |
How are they enlarging them? I was planning on the thick wall 88mm that requires a bored head. Do you recommend something else without splitting the case? |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
toxicavenger70 Samba Member
Posted: Tue Oct 19, 2021 10:51 am Post subject: Re: Best aftermarket carbs for 1679, stock motor |
Stick with the 34PICT-3 |
