rsvp Samba Member
Joined: September 02, 2006 Posts: 162 Location: Annapolis, MD(but usually travelin' somewhere else)
Posted: Wed Oct 20, 2021 8:09 pm Post subject: Vendor for left side engine bracket to install 1Z/AHU TDI motor |
Hi Vanagon diesel folks,
I'm looking for the person who makes/sells those custom made driver's side engine mounts/brackets that clear the 1Z AHU turbos in the stock position. As I recall. there were a few vendors selling them, but I cant find them at this moment.
If anyone knows who sells them please be in touch
Thanks in advance!
Steve |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
16CVs Samba Member
Joined: February 22, 2004 Posts: 4024 Location: Redwood City, California
Posted: Fri Oct 22, 2021 9:57 am Post subject: Re: Vendor for left side engine bracket to install 1Z/AHU TDI motor |
Did you try the guy in Pahrump? Vic. _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
dkoesyncro Samba Member
Posted: Fri Oct 22, 2021 10:07 am Post subject: Re: Vendor for left side engine bracket to install 1Z/AHU TDI motor |
If I remember correctly, It was a vendor across the pond, either brickwerks or tristar connection. |
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2323 Location: Adobe Jungle USA
Posted: Fri Oct 22, 2021 12:55 pm Post subject: Re: Vendor for left side engine bracket to install 1Z/AHU TDI motor |
I wonder if you are talking about an engine support arm that looks like this:
A batch was made by someone out of Oregon, I bought one in 2015 and paid too much for it since it was about the last one made. Unfortunately a few years later I discovered a weld coming apart on the engine plate, but fortunately it was only a crack and I had it welded up professionally. He also added a triangular reinforcement to it.
This arm has the advantage of not taking up much space, leaving room for exhaust and turbo access.
Full writeup here what I did with it, which I am still running:
https://www.thesamba.com/vw/forum/viewtopic.php?p=7654936 _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
rmcd Samba Member
