Initial jetting for a 1905?
DerrickfromNC1
DerrickfromNC1 is offline
PostPosted: Thu Oct 21, 2021 9:27 am    Post subject: Initial jetting for a 1905? Reply with quote
74 x 90.5….1905 daily driver engine
*engle 110
* non ported 40 x 35 valve heads
* cr 8.5
* 1-3/8 headers with single qp
Carb is a single 44idf.
What are your recommendations for:
vents
air
main
idle
Also what NGK heat range plugs(long reach) would you suggest?
Thanks
VWporscheGT3
VWporscheGT3 is offline
PostPosted: Thu Oct 21, 2021 11:04 am    Post subject: Re: Initial jetting for a 1905? Reply with quote
https://dunebuggywarehouse.com/vw-bug-bus-dunebuggy-weber-idf-jetting-guide
I'd start here
jimmyhoffa
jimmyhoffa is offline
PostPosted: Thu Oct 21, 2021 11:09 am    Post subject: Re: Initial jetting for a 1905? Reply with quote
In my experience around that displacement, you'll want 32-34mm vents in a 44IDF. I'd probably guess to start with 32. That'll put your main jet around 140-145. It'll probably run with the Dunebuggywarehouse jetting but I expect it will be a good bit rich up top.
I would anticipate 55 idle jets.
My jetting on my 1915cc single 44 IDF is:
34 vents
f15 emulsion tubes (mainly like f11 but slightly different)
150 mains
165 air jets
55 idles
What manifold do you have and does it have preheat?
1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous.
