mStrad Samba Member
Posted: Fri Oct 22, 2021 6:16 am Post subject: Diesel Vanagon oil drain bolt torque spec |
Hi Everyone
Does anyone know what the torque setting should be when tightening this oil drain bolt on a diesel T3 vanagon? I prefer not to guess what “snug” means. Also is there supposed to be a crush washer on it? If so what would be the part #?
Thanks in advance.
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9935 Location: Orbiting San Diego
Posted: Fri Oct 22, 2021 6:35 am Post subject: Re: Diesel Vanagon oil drain bolt torque spec |
Never a washer on that kind of drain plug.
Bentley says 15 ft lb for drain plug torque.
page 17.4
Mark |
valvecovergasket Samba Member
Posted: Fri Oct 22, 2021 8:40 am Post subject: Re: Diesel Vanagon oil drain bolt torque spec |
is that the original bolt for the factory diesel pans? i have a brickwerks reproduction pan and it came with those normal copper washer + shouldered bolt versions on both ends of the pan _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
pjn_wyo Samba Member
Joined: April 22, 2019 Posts: 181 Location: Bellingham, WA
Posted: Fri Oct 22, 2021 8:43 am Post subject: Re: Diesel Vanagon oil drain bolt torque spec |
https://www.thesamba.com/vw/forum/viewtopic.php?t=620788
Lots of info here.
I have a new pan (purchased from Brickwerks that I think is the same that VanCafe sells...) that has two plugs that both require crush washers. |
danfromsyr Samba Member
Posted: Fri Oct 22, 2021 9:40 am Post subject: Re: Diesel Vanagon oil drain bolt torque spec |
do note that I have personally had a freak incident where the stock plug like the OP shows backed out and fell out of the oil pan while on the road coming home.
the miracle saving grace was that this happened within 1 house down from turning into my driveway. I was greeted with a large pool of hot oil on the driveway as I exited the van.
I now cross drill the bolt head and safety wire it to something.
if it can't spin it can't depart the pan. _________________
Abscate wrote: |
mStrad Samba Member
Posted: Fri Oct 22, 2021 9:33 pm Post subject: Re: Diesel Vanagon oil drain bolt torque spec |
Mine didn’t have a washer with it so I guess it’s an original pan. |
?Waldo? Samba Member
Posted: Sat Oct 23, 2021 12:09 pm Post subject: Re: Diesel Vanagon oil drain bolt torque spec |
There are two different diesel Vanagon oil pans. One of them was for the non-turbo engines and the other was for the turbo engines. They are the same aside from the following differences. The turbo pan has a bung for the turbo oil return line, it has a drain plug at the front AND the rear of the pan and both plugs are the typical crush washer design. The non-turbo pan has no bung for the turbo oil return and has the single tapered drain plug pictured at the beginning of this thread. |
Vanagon Nut Samba Member
Posted: Sat Oct 23, 2021 12:19 pm Post subject: Re: Diesel Vanagon oil drain bolt torque spec |
danfromsyr wrote: |
Good tip. Thanks.
My older style oil pan has hair line cracks at area where cone on bolt seats; as is it will always have a very slow minor slow leak.
@ the OP: use care not to over tighten that drain bolt.
1988 West DIY 50º ABA
VE7TBN |
Posted: Sat Oct 23, 2021 1:24 pm Post subject: Re: Diesel Vanagon oil drain bolt torque spec |
I think VW produced 5 versions of the pan.
Also there is at least 1 aftermarket version.
The photo the OP put with his questions shows the earliest pan drain plug.
Mark |
