Lead paint in ceiling panel of 73?
73bus_and_me
73bus_and_me is offline
PostPosted: Fri Oct 22, 2021 4:36 pm    Post subject: Lead paint in ceiling panel of 73? Reply with quote
Hi all, we just completed our first trip, driving to Lake Tahoe actually from the bay area, in our 73' Bay Window Bus (weekender) acquired last Spring. We slept for 3 nights in the bus and woke to several inches of snow the last morning. It was beautiful!!!
Anyhow, it was also "snowing" white dust from the wood panel in the ceiling which gave a noticeably white powdery appearance on the rubber mat flooring and also on our clothing. The panel has faint white embedded in the wood grain, which I assume are the remnants of paint.
We're not sure if we should replace the panel, seal it, get it sanded down by some kind of approved lead removal place or what not.
Our "next step" is probably to get an EPA-approved lead test kit.
Has anyone been through this and have any tips?
aeromech
aeromech is offline
PostPosted: Fri Oct 22, 2021 5:37 pm    Post subject: Re: Lead paint in ceiling panel of 73? Reply with quote
I’d seal it. Unless you add the flakes to your coffee, I doubt it would be a problem but lightly sand and then seal
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
busdaddy
busdaddy is offline
PostPosted: Fri Oct 22, 2021 5:40 pm    Post subject: Re: Lead paint in ceiling panel of 73? Reply with quote
Welcome!
The finish flaking off the panelling isn't uncommon, even the best German coatings break down after 48 years. But you are the first to ask about lead content, I guess you'll want to avoid licking the interior if you are worried.
A good vacuuming with a stiff brush attachment usually gets all the loose crap off. Nobody has found a way to exactly replicate the photo printed finish on those, a light sanding, some whitish stain and a coat of varnish usually comes really close though.
Слава Україні!
aeromech
aeromech is offline
PostPosted: Fri Oct 22, 2021 5:46 pm    Post subject: Re: Lead paint in ceiling panel of 73? Reply with quote
^^^^^^ what he said
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Malokin Martin
Malokin Martin is offline
PostPosted: Fri Oct 22, 2021 7:53 pm    Post subject: Re: Lead paint in ceiling panel of 73? Reply with quote
The original panels are pickled. I can’t remember if they were varnished after. It doesn’t look like they were painted from 500 miles away in the one photo you posted on my screen.
danfromsyr
danfromsyr is offline
PostPosted: Fri Oct 22, 2021 7:54 pm    Post subject: Re: Lead paint in ceiling panel of 73? Reply with quote
now if we could only get some radioactive coating.
then it would glow softly at night.
Abscate wrote:
aeromech
aeromech is offline
PostPosted: Fri Oct 22, 2021 8:03 pm    Post subject: Re: Lead paint in ceiling panel of 73? Reply with quote
Honestly I would consider the entire bus to be lead contaminated. Therefore it’s a total loss. It just so happens that I recently (read tomorrow) started a company that specializes in lead disposal. My company will only charge you a small fee to collect your bus and make this problem go away for you.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
my59
my59 is offline
PostPosted: Fri Oct 22, 2021 8:24 pm    Post subject: Re: Lead paint in ceiling panel of 73? Reply with quote
I have dealt with lead contamination and remediation, owning an 1860's house and having young kids while renovating it.
Dry scraping and or sanding is a big don't do it.
Testing for lead if positive makes you liable if it's positive and you don't disclose.
Hepa vacuum and wet wiping might be something to consider. With loose debris off, priming and painting would encapsulate what's left..
Please keep in mind that lead affects children significantly more thN adults, as child's brains are still developing where adults are what they are.
Lead is an element, so we just move it around. Be cognizant of how it is disposed of, and only hunt waterfowl with steel or bismuth shot
my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget.
metahacker
metahacker is offline
PostPosted: Fri Oct 22, 2021 9:09 pm    Post subject: Re: Lead paint in ceiling panel of 73? Reply with quote
the Germans were already anti-lead-paint way before us (the US banned it in 1978).
In 1886, women and children were not allowed in lead paint factories.
By 1961, Germans considered lead paint a no-no. (simply a best practice, although not formally banned, if I understand correctly)
You should test it and let us know for all of our own edification.
I wouldn't let it concern you the least bit on your trip. If you want to put a mask on and wipe it with a wet rag, go for it.
But I wouldn't stress out about it.
Don't eat it.
busdaddy
busdaddy is offline
PostPosted: Fri Oct 22, 2021 9:32 pm    Post subject: Re: Lead paint in ceiling panel of 73? Reply with quote
Yeah, I figured testing would be stepping into a big steaming pile of trouble, clean it up as safe as you can and don't mention it ever happened.
Слава Україні!
Starbucket
Starbucket is offline
PostPosted: Sat Oct 23, 2021 12:24 pm    Post subject: Re: Lead paint in ceiling panel of 73? Reply with quote
Buy a water filtration vacuum, around $125.00 and clean up the area then seal the panel with clear paint.
metahacker
PostPosted: Sat Oct 23, 2021 3:09 pm    Post subject: Re: Lead paint in ceiling panel of 73? Reply with quote
oh cmon Smile it's not like he has a rental property with some liability lawsuit lying in the wait
this is about their own bus and their own safety
wouldn't hurt to test and i'm sure many of us would honestly like to hear the results (or not, depending on what the test says, heh)
pioneer1
pioneer1 is offline
PostPosted: Sat Oct 23, 2021 3:34 pm    Post subject: Re: Lead paint in ceiling panel of 73? Reply with quote
Seal the finish. I used a latex linen color stain to refinish. Move the stain around with a rag to create that woodgrain finish. Then seal with semi glass urethane. Just like new
"Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project
73bus_and_me
PostPosted: Tue Oct 26, 2021 9:51 pm    Post subject: Re: Lead paint in ceiling panel of 73? Reply with quote
Thanks everyone.
I did two lead paint tests and both were negative. Thank you Germany. The 3M lead test kit is really well designed. It includes a sheet with actual lead in it so you can confirm each test was capable of detecting lead.
I can't say this result would generalize to other buses (though hopefully it would) because it's possible a former owner could have modified the ceiling and painted it with US lead paint early in the bus's history. And who know what the history is of my bus?
Anyhow, my next step will be to sand the ceiling until the paint stops flaking off it. I don't necessarily need or want it to be eliminated entirely because it kind of looks retro and imperfect.
Then I'll apply a latex linen color stain to refinish as pioneer1 recommended. I think the challenge will be to waterproof it afterwards with a finish that does not look "glossy" so the water vapor from us sleeping at night (even with front windows cracked) does not affect the wood. Maybe some light sanding with steel wool would take care of any gloss.
Hey pioneer1, I also have an 80's-era 911 targa. Mine is a red 1987 with around 50 thousand original miles.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Tue Oct 26, 2021 11:36 pm    Post subject: Re: Lead paint in ceiling panel of 73? Reply with quote
*buys poison test kit. kit includes poison*
what a world we live in
73bus_and_me wrote:
Thank you Germany.
not so fast. you'll have a stroke when you find out about the asbestos in the heating system Dancing
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Xevin Premium Member
Xevin is offline
PostPosted: Wed Oct 27, 2021 12:03 am    Post subject: Re: Lead paint in ceiling panel of 73? Reply with quote
My buddy’s wife grew up driving bugs as a teenager. When she married my buddy (Who also owns a fleet of vintage VWs) she was daily driving an 80/81 Vanagon as her daily driver for many years. A handful of years ago she went to work for a firm that does lead testing. When she tested her Vanagon the results made her uncomfortable to let her young son travel in the Van. She stopped driving it for good. I don’t have details of the results but maybe I’ll ask her if she recalls the specifics.
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
SGKent wrote:
sodbuster
sodbuster is offline
PostPosted: Wed Oct 27, 2021 8:38 am    Post subject: Re: Lead paint in ceiling panel of 73? Reply with quote
So in other words you really do not know what the source of the lead contamination was.
For the original poster. that is the original finish on your pannels. and it is a wood stain and not paint. Smile
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Oct 27, 2021 8:52 am    Post subject: Re: Lead paint in ceiling panel of 73? Reply with quote
Lol! Funny shit! And no doubt for sale in California it has the Prop 65 warning label.
The only sillier thing is a warning on the laser pointer for my pistol that came with a sticker to put on the weapon stating that there is a health hazard from the laser light. Personally, I'd be more worried about the lead poisoning threat coming our of the barrel, not the photons...
Xevin is offline
PostPosted: Wed Oct 27, 2021 9:15 am    Post subject: Re: Lead paint in ceiling panel of 73? Reply with quote
This is absolutely correct. Hopefully I can get more details from her today and can report back.
Keep on Busin'
SGKent wrote:
metahacker
PostPosted: Wed Oct 27, 2021 9:00 pm    Post subject: Re: Lead paint in ceiling panel of 73? Reply with quote
just put a coat of penetrol on it and move on with your life, making note to appreciate the patina of your wood headlining that can only be earned and not purchased
the germans aint puttin lead in that shizz
no need to worry
told ya so Smile
i know OLD and PAINT = LEAD death in most ppls minds
but that bus is probably safer with VOCs and toxins than any home built after 1945
