dlyle Samba Member
Joined: March 22, 2019 Posts: 307 Location: Morgan Hill
Posted: Sat Oct 23, 2021 11:25 am Post subject: Need Help Identifying this mystery dune buggy |
Went and looked at this dune buggy today. Can anybody tell what this is? I looked but didn't find any marking or cards under the dash etc. Gotta love those farm tires on the back and the extra springs on the shocks. Even with those it feels soft in the back.
oprn Samba Member
Joined: November 13, 2016 Posts: 12708 Location: Western Canada
Posted: Sun Oct 24, 2021 3:41 am Post subject: Re: Need Help Identifying this mystery dune buggy |
What it looks like to me is a really good start to a fun Manx copy Buggy. Beyond that... not sure.
Lift that carpet and see if there is anything left of the floor pans and calculate that into what you pay for it. Nice find, I hope you can get it for a decent price, it has lots going for it. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sun Oct 24, 2021 10:43 am Post subject: Re: Need Help Identifying this mystery dune buggy |
It looks to me to be a Safari Body. There are images of the advertisements online somewhere.
I have one in white and I have seen quite a few online and in person at the Manx Club Meet.
It's a great start to a buggy....I drive mine everywhere and have over 70,000 miles on it since it was built in 2004.
The Safari has a distinct hood/dash that is pretty easy to spot.
The flat area on the bottom and a small ridge running down the center of the hood along with the dash edge resting on the buggy body are a characteristic of the Safari.
There are two other bodies made by the same company but you have the standard Safari like mine.
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
pugwash Samba Member
Posted: Sun Oct 24, 2021 11:52 am Post subject: Re: Need Help Identifying this mystery dune buggy |
dlyle wrote: |
Yep Safari.......https://barnfinds.com/porsche-powered-1969-safari-vw-dune-buggy/ |
dlyle Samba Member
Posted: Sun Oct 24, 2021 1:37 pm Post subject: Re: Need Help Identifying this mystery dune buggy |
clonebug wrote: |
Thanks for the info everyone. I agree looks like a Safari.
Clonebug, does yours have a body lift? This one does and from what I can tell if it were removed the body would hit the front shock towers. Even with the lift it is nearly touching.
This one I'm looking at probably doesn't have a current registration or special construction tag so I'll have to think about it. Last tags were from 1979 so not sure when it last ran. |
Posted: Sun Oct 24, 2021 1:58 pm Post subject: Re: Need Help Identifying this mystery dune buggy |
Mine is on a 64 pan.....swing axle and link pin beam.
It does not have a lift on it.
I'm guessing that one is on a 68 pan with swing axle rear and ball joint front.
The Safari body has molded in bumps for the K/L shock towers to sit in. It is a tight fit and mine will rub a little bit and squeak enough to annoy the wife.
The upper shock bolt threads were stripped and it has through bolts and that makes for the tighter fit.
Depending on where you are live is going to decide how you go about getting it titled and registered for the road.
I myself bought a 64 bug with a good title and used that and it's been on the road for 17 years....never even been pulled over in it. _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
dlyle Samba Member
Posted: Sun Oct 24, 2021 2:38 pm Post subject: Re: Need Help Identifying this mystery dune buggy |
clonebug wrote: |
I myself bought a 64 bug with a good title and used that and it's been on the road for 17 years....never even been pulled over in it. |
This one has a chassis number starting with 1804 which I think is a 1958-59 but I could be wrong on that. Engine is is 8887234 which is possibly from a 1964. |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2222 Location: HdG, MD & NJ
Posted: Sun Oct 24, 2021 4:50 pm Post subject: Re: Need Help Identifying this mystery dune buggy |
I always assumed my old buggy was a safari, also. I had the bumps on the hood. And thumb tack holes. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
Posted: Sun Oct 24, 2021 5:00 pm Post subject: Re: Need Help Identifying this mystery dune buggy |
NJ John wrote: |
I always assumed my old buggy was a safari, also. I had the bumps on the hood. And thumb tack holes. |
If you have the two bumps on the hood then you have the Safari Trail Body.
There is one more body style also made by Safari but I have never seen one for real yet.
The Safari and the Safari Trail seem to be the more common of the three. _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
dlyle Samba Member
Yup, I think that one was called the Safari Trail. They had the two bumps on the hood.
EVfun Samba Member
Posted: Sun Oct 24, 2021 6:53 pm Post subject: Re: Need Help Identifying this mystery dune buggy |
dlyle wrote: |
That would be a January 1958 chassis, but it appears that you have even older rear brakes, oval window era rear brakes. I see the wheel cylinder at the bottom and it appears the backing plate is larger where it fits over the edge of the brake drum. You also still have a splitcase transaxle, used through 1959 (also in 1960, but that one is different.) The motor appears to be a 40 horse unit, and the buggy still appears to be 6 volt. Its a cool vintage buggy, what ideas for it do you have in mind? _________________
Wildthings wrote: |
dlyle Samba Member
Posted: Sun Oct 24, 2021 9:08 pm Post subject: Re: Need Help Identifying this mystery dune buggy |
EVfun wrote: |
dlyle wrote: |
That would be a January 1958 chassis, but it appears that you have even older rear brakes, oval window era rear brakes. I see the wheel cylinder at the bottom and it appears the backing plate is larger where it fits over the edge of the brake drum. You also still have a splitcase transaxle, used through 1959 (also in 1960, but that one is different.) The motor appears to be a 40 horse unit, and the buggy still appears to be 6 volt. Its a cool vintage buggy, what ideas for it do you have in mind? |
Thanks for the info. Yes, still 6 volt. If it becomes mine I'm not sure what I'll do with it. I'd take inventory and see if it will run. From there I'd clean it up and have fun with it. Of course I'd have to get some new tires on it and go through the brakes to get it roadworthy. I did notice it has a small 5 hole bolt wheel pattern and I didn't see any adapters. |
dlyle Samba Member
Posted: Tue Oct 26, 2021 8:27 am Post subject: Re: Need Help Identifying this mystery dune buggy |
The guy is asking $3,200 for this. Non running and with a bill of sale only so it would need a special construction permit.
Doesn't run but motor spins freely. What do you guys think it's worth?
I offered him $1,500. I see running and registered buggies for $3,ooo and less. |
slayer61 Samba Member
Posted: Tue Oct 26, 2021 10:21 am Post subject: Re: Need Help Identifying this mystery dune buggy |
Asking price is just that, right? What others are willing to pay is another thing.
Good luck with your offer. If you get it at that price, I would consider myself lucky. _________________
Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes? |
Paul
'68 Manx clone... Sears??
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
CB Magna spark
1 5/8 merged collector w/ hater stinger |
dlyle Samba Member
Posted: Tue Oct 26, 2021 11:03 am Post subject: Re: Need Help Identifying this mystery dune buggy |
slayer61 wrote: |
Good luck with your offer. If you get it at that price, I would consider myself lucky. |
Thanks for the response. So what would you say it's worth? |
Posted: Tue Oct 26, 2021 11:45 am Post subject: Re: Need Help Identifying this mystery dune buggy |
dlyle wrote: |
slayer61 wrote: |
It's worth what you are willing to pay. Everybody has a different pain threshold.
I got mine for 14, but it was far from complete. But it was a "pain" I could tolerate that day
Cusser wrote: |
Paul
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
CB Magna spark
dlyle Samba Member
Posted: Tue Oct 26, 2021 12:48 pm Post subject: Re: Need Help Identifying this mystery dune buggy |
slayer61 wrote: |
dlyle wrote: |
slayer61 wrote: |
I knew you were going to say that! It is a cool buggy but that's above my pain threshold for what it will need.
Those wheels on your buggy look like the old Hands wheels you could get on Corvairs and Sunbeam Tigers. |
