ryanator Samba Member
Joined: May 17, 2020 Posts: 16 Location: Canfield ohio
Posted: Sat Oct 23, 2021 12:42 pm Post subject: VIN # lookup??? |
Hi all...just wondering how I would find vehicle history on a 1956 bug? It isn't owned privately and I wanted some history on it before I consider a purchase. Any help is appreciated! Thanks...I have the VIN and a somewhat recent plate # also . |
OvalinAz Samba Mini Tech
Posted: Sat Oct 23, 2021 1:38 pm Post subject: Re: VIN # lookup??? |
not sure how you would be able to find any history on it without asking the previous owner. your DMV wont give out personal info on PO's. also it being a 56 most online car history places wont have any info, or help you because of the year. _________________ Dad's 4/55 Oval
8/56 Oval
5/64 French Notchback
12/62 French 11 Window Bus
Wedge VW
Pandraggers C.C. |
David Samba Member
Joined: June 29, 2004 Posts: 2027 Location: Raleigh, NC
Posted: Sun Nov 07, 2021 3:22 pm Post subject: Re: VIN # lookup??? |
Ok, thanks guys....it's a matching # car but my main concern is it's a ragtop and was wondering if there's a way to tell if it's factory or not...I understand that it's even hard to tell by the VIN plate...some have a 1-17 code and some don't I guess? |
Bub Samba Member
Joined: June 10, 2004 Posts: 1151 Location: Central Washington
Posted: Mon Nov 08, 2021 5:25 pm Post subject: Re: VIN # lookup??? |
ryanator wrote: |
If it were my car and you simply could not tell, I'd just say it's original. Screw it, if it was done that well and it's your car then enjoy the roof hole and say it's factory until proven otherwise.
If there's a headliner installed you *can* carefully loosen the front edge and inspect under the headliner. Up around the front is usually the hard part to copy factory panels and assembly. _________________
hitest wrote: |
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
