VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2076 Location: Gardnerville, NV
Posted: Tue Nov 16, 2021 10:01 am Post subject: Re: Installing 123 Ignition Distributor - advice sought |
RedSquare wrote: |
Tram wrote: |
Looks like an ignition issue- plug or wire. Your timing light should be blinking steady and it's not. |
Yeah, I should have commented on the apparent flickering of the timing light. It only looked that way on the video. In reality it had the consistent flash you would expect. Not sure why it looks like that on the video, but it in reality the light flashed every time and not the “hit and miss” as it appears in the video. |
frame rate made it look off |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6609 Location: Houston, Texas
Posted: Thu Nov 18, 2021 9:05 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
Good call on the 123. _________________ www.vwnos.com [email protected]
RedSquare Samba Member
Joined: August 28, 2017 Posts: 238 Location: Kansas City
Posted: Fri Dec 03, 2021 9:32 am Post subject: Re: Installing 123 Ignition Distributor - advice sought |
Quote: |
The other vacuum related issue with type 3 D-jet...is the fit and wear of the throttle plate and throttle shaft in the unreplaceable TB system.
To check this....at idle only mind you.....warm the car up so it can be started without having to open the throttle. Make sure all vacuum leaks are plugged like the AAR and PCV if you have one.
Take some simple modeling clay ....and roll a piece out into a rod about 3/16" in diameter and pack it around the perimeter of the throttle plate.
Start the car. If it idles stable....you know what the issue is.
If it only changes some...or does not change at all.....Take a Q-tip and apply grease around the throttle shaft openings. See if that changes anything.
If no change....remove all of that crap and check the gasket on the back plate of the center manifold. You can do this with carb spray.
Ray |
Ok - it’s been a while since I followed up on what I’ll bet is a vacuum leak, but I plan to do so this weekend. In re-reading Ray’s vacuum chasing tips, I was not sure entirely what the “throttle plate” is. I think you mean the circular disk inside the throttle body - what others might call the butterfly valve. Is that correct? If so, then remove the air filter boot, pack that circumference with clay and see what effect it has.
Am I tracking here? |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21518 Location: Oklahoma City
Posted: Fri Dec 03, 2021 11:30 am Post subject: Re: Installing 123 Ignition Distributor - advice sought |
RedSquare wrote: |
Ray |
Yes.
Ray |
Posted: Fri Dec 03, 2021 4:55 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
Definitely leaks around the throttle plate.
Started the car up and let it warm up to operating temp. (And pulled the AAR hose off of the air cleaner and plugged it after it was warm.) Once warm the oscillation started as expected. Then, before I took the intake boot off of the throttle body, I sprayed carb cleaner around the back plate and near the throttle shaft, but the idle didn’t change, so I’m assuming there is no appreciable leakage at either of those locations.
Took the intake boot off and started putting the ring of modeling clay in place, but hadn’t bothered to shut the motor off, which proved to be a mistake. The air being pulled in through that bypass passage that runs under the throttle shaft (or whatever that passage is) is significant and it grabbed a bit of my modeling clay rope and…THUUUUP!…sucked it right in. I had the presence of mind to quickly cup my hand over the intake which immediately killed the motor and was then able to fish the little bit of modeling clay out of that passage. Whew….
So, with the motor SHUT OFF I placed the ring of modeling clay around the circumference of the throttle plate, then restarted the motor while remembering to leave the darn throttle alone. Started up fine, but with an obviously lower RPM. Maybe 150 rpm’s or so lower than without the clay. I didn’t measure it - just looked at the dash tach and estimated, but it was meaningful lower. Seemed like it still had a very small oscillation even with the clay, but either I imagined it or it was very small.
Then pulled the modeling clay back off. That was harder than I expected because I hadn’t cleaned the throttle body before I put it on, so there was some general grunge (not a lot) which didn’t make it any easier. Also, the clay got warm and didn’t hold together as well as it did when cool, so it took a bit to get it all off of the throttle body.
Things I would do differently if I had it to do over again:
1. Clean the throttle body before you put the clay on.
2. Shut the motor off before you put the clay on.
3. Wait for throttle body to cool before removing clay.
One thing I got right on accident was that I used white modeling clay. That made it easier to see when I was trying to get it off than it would have been had I chosen a dark color.
So now what? Is there a remedy for a leaky throttle plate?
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34009 Location: Conejo Valley, CA
Posted: Fri Dec 03, 2021 5:42 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
Because it is designed to bypass with that screw/nut/hole that sucked in your clay, this throttle plate is not required to seal completely, just consistently. It may not be your problem.
I have never had to do so, but many use clamps, or at least tight zip ties, on both ends of the four stubby hoses connecting the intake runners to the plenum. I used a slight smear of sealer on mine when I put it together, even if they are tight. However, with age and heat cycles, they can stiffen, and if you ever loosen the plenum or runners, they can develop hard to find leaks, even though they look fine. |
Posted: Fri Dec 03, 2021 7:23 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
You are talking about these 4, yes?
And you’re saying that the throttle plate leakage just adds to the air that the idle set screw allows? Makes sense if so. |
KTPhil Samba Member
Posted: Sat Dec 04, 2021 4:48 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
Yep. |
Posted: Sun Dec 05, 2021 8:36 am Post subject: Re: Installing 123 Ignition Distributor - advice sought |
I put a pair of zip ties on either end of all 4 of those stubby hoses, then ran it again. Seems like the oscillation was less pronounced after that then it was in the video I posted earlier in this thread, but I’m not entirely sure.
Regardless, I took the car for a short drive after I got it all buttoned back up, and it drove really well. Hard to describe what was different - the engine just felt smoother to me. Not like it had more power or anything. Just smoother. Maybe it was, or maybe I just thought it was because I changed to the 123 Ignition and expected it to be better. But it really did feel noticeably smoother to me.
If nothing else, I don’t have to concern myself with distributor maintenance anymore, and that is something. |
KTPhil Samba Member
Posted: Sun Dec 05, 2021 11:27 am Post subject: Re: Installing 123 Ignition Distributor - advice sought |
Those hose stubs are sometimes hard to find.
Jbugs has them, but categorize them as Bug parts, not Type 3.
https://www.jbugs.com/product/043133241.html
But these fit correctly/tightly.
If you bother to replace these, you should go whole hog and replace all the runner/injector seals, so you don't have to for many years. This would include sealing the bakelite plates (since no one sells the super-thin gaskets you used to be able to get--use a thin smear of fuel-compatible silicone non-adhesive sealant), injector tip seals, and these stubs. A PITA job with the engine in the car, so do it all at once. Replace the 1 or 2 hoses that fit into the plenum while you are at it.
Your clamped stubs may be good enough for now, though. |
Posted: Sun Dec 05, 2021 7:31 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
KTPhil wrote: |
Yes...it IS required to seal a lot better than what he is seeing. A LOT better.
I already knew what he would find. All of the type 3 plenums are like this at this point in time. And...unless you got into type 3's with D-jet almost 50 years ago and had one with very low miles....virtually every D-jet type 3 you have had already had a largely worn out plenum. Its usually NOT the throttle plate....its the aluminum manifold thats worn.
It was NOT this way from the factory and that "seemingly" small amount of extra bypass....is read by the MPS...and it gives you fuel that you DO NOT NEED at idle. This is where a lot of the oscillation comes from. wet ports and excessive fuel at idle.
By the way....the bus guys with L-jet....many of them are having this same issue. By this point in time the TB's are worn out. Its the last frontier of trying to get the damn things to idle right. f they cannot idle right you cannot properly set the fuel mixture.....ever.
The D-jet systems on type 4 have the same issues except with D-jet...whether its type 3, 4 or 914...have a more sensitive sensor....the MPS.
Now...as you note....if the throttle plate leakage is consistent.....you CAN usually adjust around it....with the MPS. Thats the other problem. 95% of all D-jet guys are in mortal fear of adjusting the MPS...and you should not be. Its a necessity. Its your fuel mixture adjustment. If you have air ingress you cannot fix like the throttle plate or a PCV valve....you MUST adjust the sensitivity of the MPS to ignore that extra air.
But....you can only adjust for so much before you affect the rest of the fuel curve too much.....so at some point if it gets bad enough...you have to either fix the throttle body or the throttle plate.
There is a guy in the bus forums that does top notch work remachining bus TB's and putting in a new stainless steel throttle plate. Very fine work.
As I noted....I already knew what he would find. What I wanted to see is if it would largely...mostly...stabilize the oscillation. Ray |
KTPhil Samba Member
Posted: Mon Mar 28, 2022 9:57 am Post subject: Re: Installing 123 Ignition Distributor - advice sought |
Ok, I'll add to this thread instead of my other \troubleshooting threads, since this is just about the 123.
I installed it and timed it and ran 200 miles yesterday using the "F" curve, and although it runs well, it is down on power from the stock unit through the mid range.
Comparing table entries:
Can I select the "E" curve (intended for the Type 4), to see if the earlier advance helps? The current F setting feels sluggish and I need to rev it higher, making it peaky, which makes sense if it reaches just 21 degrees and is all in by 2600 rpm. The higher 30 max of the E curve might be a bit much, but the slower rise might make it okay.
AS long as I am not pinging and overheating, I presume the setting can work and might help. Any reasons not to do so?\
And what does "for tuning" mean? |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22727 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Mon Mar 28, 2022 11:12 am Post subject: Re: Installing 123 Ignition Distributor - advice sought |
KTPhil wrote: |
26 isn't enough max advance. Personally, I would go with D. Use premium fuel. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
KTPhil Samba Member
Posted: Mon Mar 28, 2022 11:31 am Post subject: Re: Installing 123 Ignition Distributor - advice sought |
Thanks, Tram, I'll experiment. I'll also be recalibrating the MPS with my O2 sensor, but I want to get timing right first.
Does changing static/idle timing also affect the timing of the trigger contacts, like in a stock distributor? I would presume so.
Do we have data about the entire curve, or just the max/rpm info in this table?
Anyone else experimented with the curve choices?
Thanks, all! |
KTPhil Samba Member
Posted: Mon Mar 28, 2022 1:17 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
I wonder if others like "B" (generic 1600) still work the trigger contact wires?
25 max for mechanical (plus vacuum) sounds about like stock. |
heimlich VWNOS.com
Posted: Wed Mar 30, 2022 6:38 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
Looks like F curve is for tuning. Appears to be a 009 curve which is not going to give you anything close to stock.
D is usually a curve for Porsche. It ramps up very quickly. The stock curve at least does this.
What is your stock distributor is I can help match it for you? _________________ www.vwnos.com [email protected]
heimlich VWNOS.com
Posted: Wed Mar 30, 2022 8:29 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
I sent a message to the 123ignitionusa. They said they do not have the curve data.
Maybe one of you whom have bought one can ask for this data? _________________ www.vwnos.com [email protected]
KTPhil Samba Member
Posted: Wed Mar 30, 2022 10:01 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
heimlich wrote: |
Maybe one of you whom have bought one can ask for this data? |
I did but have not heard back yet... not sure if I will. The USA outfit declined already. |
heimlich VWNOS.com
Posted: Thu Mar 31, 2022 8:46 am Post subject: Re: Installing 123 Ignition Distributor - advice sought |
Here's what was sent to me:
Curve 0:
500 0
1100 0
1600 10
3800 24
8000 24
Curve 1:
500 0
1100 0
1600 14
3800 24
8000 24
Curve 2:
500 0
1100 0
1600 10
3800 24
8000 24
Curve 3:
500 0
1100 0
1600 14
3800 24
8000 24
Curve 4:
500 0
1000 0
1500 8
2000 12
2500 15
3000 18
8000 18
Curve 5:
500 0
1100 0
1550 13
2200 13
4000 22
8000 22
Curve 6:
500 0
1200 0
1500 9
3800 23
8000 23
Curve 7:
500 0
1150 0
1600 14
2200 14
3800 23
8000 23
Curve 8:
500 0
1100 0
1600 21
2100 21
3600 31
8000 31
Curve 9:
500 0
1250 0
1500 9
3750 23
8000 23
Curve A:
500 0
1250 0
1500 9
3750 23
8000 23
Curve B:
500 0
1000 0
1300 8
3400 25
8000 25
Curve C:
500 0
800 0
1200 18
3100 35
8000 35
Curve D:
500 0
800 0
1300 15
3100 30
8000 30
Curve E:
500 0
1100 0
1600 18
3200 30
8000 30
Curve F:
500 0
1100 0
1300 5
1700 5
2600 21
8000 21 _________________ www.vwnos.com [email protected]
Erik G Samba Member
Joined: October 16, 2002 Posts: 13278 Location: Tejas!
Posted: Thu Mar 31, 2022 9:05 am Post subject: Re: Installing 123 Ignition Distributor - advice sought |
heimlich wrote: |
Curve 0:
500 0
1100 0
1600 10
3800 24
8000 24
Curve 1:
500 0
1100 0
1600 14
3800 24
8000 24
Curve 2:
500 0
1100 0
1600 10
3800 24
8000 24
Curve 3:
500 0
1100 0
1600 14
3800 24
8000 24
Curve 4:
500 0
1000 0
1500 8
2000 12
2500 15
3000 18
8000 18
Curve 5:
500 0
1100 0
1550 13
2200 13
4000 22
8000 22
Curve 6:
500 0
1200 0
1500 9
3800 23
8000 23
Curve 7:
500 0
1150 0
1600 14
2200 14
3800 23
8000 23
Curve 8:
500 0
1100 0
1600 21
2100 21
3600 31
8000 31
Curve 9:
500 0
1250 0
1500 9
3750 23
8000 23
Curve A:
500 0
1250 0
1500 9
3750 23
8000 23
Curve B:
500 0
1000 0
1300 8
3400 25
8000 25
Curve C:
500 0
800 0
1200 18
3100 35
8000 35
Curve D:
500 0
800 0
1300 15
3100 30
8000 30
Curve E:
500 0
1100 0
1600 18
3200 30
8000 30
Curve F:
500 0
1100 0
1300 5
1700 5
2600 21
8000 21 |
great info - thanks |
