ClassicCamper Samba Member
Posted: Mon Oct 25, 2021 8:16 pm Post subject: Door Panel Clips and Rubber Boots (with pictures) |
Been reading through the various posts about 412 panel cups and cups. The gist was that the rubber cups were the hardest of the two to find.
To that end, does anyone have a recommendation as to where I can find both of these products?
As you can see, the clips are clearly for a beetle or bus, not even close in fit for T4:
You can see how they just fall out of the holes:
These are the clips I need, I just cant find them; a link would be really helpful
Thanks in advance.
-Ron _________________ 1973 412 Wagon
1976 Westy
1978 SB Vert |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21512 Location: Oklahoma City
Posted: Mon Oct 25, 2021 8:54 pm Post subject: Re: Door Panel Clips and Rubber Boots (with pictures) |
Let me dig in my small parts box. How many do you need? The rubber boots I cannot hep with....yet....but the clips....I harvested quite a few over the years. Ray |
Posted: Mon Oct 25, 2021 9:09 pm Post subject: Re: Door Panel Clips and Rubber Boots (with pictures) |
Ray,
Thanks for jumping in. I counted up and I need 70 to complete all of the panels.
Let me know if you have that many, I really appreciate it! This is exciting.
1976 Westy
1978 SB Vert
Last edited by ClassicCamper on Mon Oct 25, 2021 9:10 pm; edited 1 time in total |
Pepperbilly Samba Member
Joined: April 08, 2017 Posts: 977 Location: Seattle, Wa
Posted: Mon Oct 25, 2021 9:10 pm Post subject: Re: Door Panel Clips and Rubber Boots (with pictures) |
Yeah, I’m looking for the rubber boots also. Have not found any yet.
Bill |
Posted: Tue Oct 26, 2021 6:53 am Post subject: Re: Door Panel Clips and Rubber Boots (with pictures) |
I will be looking at the boots as well. I have a few in the same repository that,are from the salvage yard. Ray |
Posted: Tue Oct 26, 2021 8:24 am Post subject: Re: Door Panel Clips and Rubber Boots (with pictures) |
Thanks a million, Ray. Looking forward to finally having door pamels on the car! _________________ 1973 412 Wagon
1976 Westy
1978 SB Vert |
Posted: Wed Oct 27, 2021 1:24 pm Post subject: Re: Door Panel Clips and Rubber Boots (with pictures) |
ClassicCamper wrote: |
Thanks a million, Ray. Looking forward to finally having door pamels on the car! |
I have 96 of them and only need about 7 or 8 per side on my rear seat cards (I have a two door sedan). All of my front door cards have their clips in place.
Check to see how many you need. The front doors on a wagon should be 23 each...call it 46. The rear seat door cars I am not sure but the wagon has longer cards and its something like 12 each....that should be right at 70?
I probably have a few more here and there in other parts buckets. I will check as I get time.
The seals....really they are "mostly" seals. But they do take up a little space on the steel clips. I could probably mold something. It would have to be urethane because the outer flange is too thin for silicone to not tear easily.
They would not look 100% just like stock....but would function perfectly and never bee seen from the outside.
Ray |
Posted: Wed Oct 27, 2021 2:27 pm Post subject: Re: Door Panel Clips and Rubber Boots (with pictures) |
Check to see how many you need. The front doors on a wagon should be 23 each...call it 46. The rear seat door cars I am not sure but the wagon has longer cards and its something like 12 each....that should be right at 70? |
You are exactly right, I need 70 to cover the front cards, rear cards, plus the inside hatch back cover.
This is really helpful Ray, Thanks again _________________ 1973 412 Wagon
1976 Westy
1978 SB Vert |
Posted: Wed Oct 27, 2021 7:10 pm Post subject: Re: Door Panel Clips and Rubber Boots (with pictures) |
raygreenwood wrote: |
Ray,
Were you able to dig up any rubber boots also? I need about 20 of them.
Bill |
