Replacing main seal - what else while engine is out?
restcon
restcon is offline
PostPosted: Tue Oct 26, 2021 12:08 pm    Post subject: Replacing main seal - what else while engine is out? Reply with quote
I'm replacing a leaking main seal on my 74 Thing. While I have the engine out what else should I replace? Clutch? Transmission seal?What parts are required?
airschooled
Air-Schooled
airschooled is offline
PostPosted: Tue Oct 26, 2021 6:52 pm    Post subject: Re: Replacing main seal - what else while engine is out? Reply with quote
There is a graphite o-ring that goes along with the main seal. Part # 311 105 295A. If the throwout bearing feels chunky or gritty replace it, otherwise they last a long time if you don't overuse the clutch.
Replace the o-ring any time you take the flywheel off the crank. It should go in dry, to a completely cleaned out grooved.
Before removing the pressure plate, mark its orientation so it goes back on in the same place for balance. Same with the flywheel; a hammer and centering punch works well to make dots on flywheels, pressure place, and crankshaft dowel pins.
If the transaxle input seal is dry, I don't usually replace it. Check the transmission/motor mounts for cracks, and the throwout arm for hairline fissures.
Good luck!
Robbie
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Oct 26, 2021 6:56 pm    Post subject: Re: Replacing main seal - what else while engine is out? Reply with quote
Throwout bearing
Seal between the engine and body
Rear tranny mounts
Use foil tape to seal up gaps in tin around the oil cooler doghouse
Tranny input shaft seal
Fuel hose between hardline in frame for engine
Double check tail light wiring before reinstalling the engine
Glenn
Member #1009
#BlueSquare
MuzzcoVW
MuzzcoVW is offline
PostPosted: Wed Nov 17, 2021 10:32 am    Post subject: Re: Replacing main seal - what else while engine is out? Reply with quote
Replace the oil cooler seals along with the other items mentioned here.
