ebenasky Samba Member
Joined: March 16, 2011 Posts: 211 Location: Helena, MT
Posted: Tue Nov 02, 2021 8:24 am Post subject: Thankful for TheSamba |
I have been into the aircooled VW's for a long time and had done a lot to my current '64 daily driver. However, it never ran "just right" until now.
With the research I did on TheSamba and the forums, along with information from
Oldvolkshome https://oldvolkshome.wetwesties.org/ignition.htm
Rob & Daves http://www.vw-resource.com/index.html
Chris Valone videos
1967 VW Beetle https://1967beetle.com/
and the many TheSamba sellers I was FINALLY able to get a matched set of carb to distributor that works well for me.
I also learned how to completely clean the carb (along with taking out the check balls) and refreshing distributors (after sourcing the correct fiber washer and shims). I have learned a WHOLE lot more by getting in there and doing it.
I appreciate all the sellers for rebuilt distributors and carbs for those that don't have the time and patience that it took me to do this.
My bug runs a stock 1500, but now has a correctly matched 113-905-205T distributor, and a 30 PICT 3 (flange 226-1). I am very happy with the way it now runs without bogging down or lack of power.
It took a bit, but not being afraid of getting my hands dirty has helps me understand things a lot better and having such a great resource (and people) to reach out to for information.
Thank you all! _________________ "I don't fix 'em to look at 'em, I fix them to drive."
- '60 Beetle "Ruby"
- '70 Beetle "Peace" |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Tue Nov 02, 2021 10:35 am Post subject: Re: Thankful for TheSamba |
I've been working on VWs since the mid-'70s. Back then parts and repair shops were everywhere, and the cars were relatively new. It was not hard or expensive to keep an old Bug going.
Then the 90s came, and parts dried up, shops closed, junkyards stopped handling VWs, and times were rough!
Then the internet, and in particular The Samba came along, and in many ways it's like the "old days" where the knowledge and parts are flowing again, as we form a community from afar. The combination of the knowledge base of the Samba, and youtube videos, means I now have far more expert advice and access to parts than ever before! It is why my cars are still running today. If you can, please donate to the samba!
https://www.thesamba.com/vw/donate.php
But there is a dark side to this... the internet didn't make new parts, it led us to the remaining stashes of them. So we are draining the supply faster, not necessarily enlarging the supply.
We may find the hobby getting more expensive some day, not too far off. Hoarding may become more common.
bobhill8 Samba Member
Posted: Tue Nov 02, 2021 10:52 am Post subject: Re: Thankful for TheSamba |
I found thesamba before I bought my first VW 5 years ago and have been on here almost every day since. It's a bit like a soap opera sometimes, but there are a lot of great and intelligent people on here and I would have sold my Westy and Squareback a long time ago in complete frustration/failure if it wasn't for all of you. _________________ 1986 Westy
1971 Squareback |
Posted: Tue Nov 02, 2021 5:34 pm Post subject: Re: Thankful for TheSamba |
I forgot to add that I followed the suggestions and changed out my main jet from 112.5 to 120 since I live at 4000 feet and the stock jet was WAY too lean. _________________ "I don't fix 'em to look at 'em, I fix them to drive."
- '60 Beetle "Ruby"
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Tue Nov 02, 2021 6:42 pm Post subject: Re: Thankful for TheSamba |
KTPhil wrote: |
I've been working on VWs since the mid-'70s. Back then parts and repair shops were everywhere, and the cars were relatively new. It was not hard or expensive to keep an old Bug going. |
Same here.
My two VWs have few made-in-China parts, probably a reason to help explain their longevity. Another might be because I'm their mechanic. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1782 Location: Santa Rosa, Ca
Posted: Wed Nov 03, 2021 7:03 am Post subject: Re: Thankful for TheSamba |
This is so true, I also have been into VWs since the late 70s. They helped me get through the Fuel Shortages of the time and became a hobby/obsession even today. For me information was very hard to obtain in the early years, not so much the mechanical part but just general information about correct colors, VIN info and production numbers. I can remember when the Samba started up and being computer handicapped I fought it until just after the 2000s began, I check in here almost everyday...Thank You EV for starting and continuing to keep The Samba alive and well. |
Zundfolge1432 Samba Member
Posted: Wed Nov 03, 2021 10:06 pm Post subject: Re: Thankful for TheSamba |
KTPhil wrote: |
We may find the hobby getting more expensive some day, not too far off. Hoarding may become more common. |
Nobody hoards this stuff why bother? And I’d have to agree this is an entertaining place that’s why I give a small amount to keep it going.
Speaking of collecting junk I was looking through some boxes and found these 36hp bits and pieces
I moved it from the falling apart box into the banana box. |
KTPhil Samba Member
Posted: Thu Nov 04, 2021 10:33 am Post subject: Re: Thankful for TheSamba |
Zundfolge1432 wrote: |
Nobody hoards this stuff why bother? |
Check the prices of Type 3 FI stuff... 3-5X in the last few years! Let the hoarding begin!
Abscate Samba Member
Joined: October 05, 2014 Posts: 22648 Location: NYC/Upstate/ROW
Posted: Sat Nov 06, 2021 2:08 am Post subject: Re: Thankful for TheSamba |
If you thank the Samba without the yellow star, you’ve just stolen from the Church bar. _________________ .ssS! |
Posted: Sat Nov 06, 2021 6:44 am Post subject: Re: Thankful for TheSamba |
Thanks to Jen and Everett 😀 |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sat Nov 06, 2021 7:07 am Post subject: Re: Thankful for TheSamba |
Agree completely with the sentiments above. I got into distributors by finding an original one in front of me one day and digging into it for my own benefit. Then a good friend suggested that I should do the same for others and there you go. Mid 1970's was the beginning for me too. Seen and done a lot in that time. I had that yellow star next to my name for many years but times have gotten tough for me and I've had to make due without for the better part of the last year. _________________ Roads Scholar &
Jennepher Administrator
Joined: September 10, 2002 Posts: 4767 Location: Arizona
Posted: Sat Nov 06, 2021 10:10 am Post subject: Re: Thankful for TheSamba |
Abscate wrote: |
If you thank the Samba without the yellow star, you’ve just stolen from the Church bar. |
That is funny and we do appreciate people who support the site through premium membership. But there are tons of ways to contribute, not just financial.
Many members donate scans to our technical and archives sections, spend time creating helpful stickies in the forums, or help us with the monumental and never-ending task of moderating the site by reporting posts, pictures, and ads. Some people make site suggestions that we can implement, and a lot of people spend countless hours over years answering questions in the forums.
So, yes, money is great and it helps support the site, but it takes time, love, and attention too. And we appreciate that just as much. _________________ Donate to TheSamba.com
If your post begins "I know this is against the rules but..." just stop typing. |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sat Nov 06, 2021 2:01 pm Post subject: Re: Thankful for TheSamba |
KTPhil wrote: |
I am decades ahead of you... MB stuff too, also! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Sat Nov 06, 2021 2:05 pm Post subject: Re: Thankful for TheSamba |
Jennepher wrote: |
Abscate wrote: |
So, yes, money is great and it helps support the site, but it takes time, love, and attention too. And we appreciate that just as much. |
Here's a suggestion- a reminder email when your star burns out might make us ADHD types stick with it more consistently.
But in all seriousness- I first encountered TS when it was VW Planet. It was like having a dealership from back in the Day (which day- was it Wednesday?) at your keyboard with all the parts and forum advice.
In addition, TS was a social media pioneer- I met folks online, and then in person, who remain friends to this day- some going on 20 years now like that reprobate notchboy.
To this day, in my experience, there still isn't anything quite like it. Other sites TRY but they just lack the magic somehow. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Sat Nov 06, 2021 3:56 pm Post subject: Re: Thankful for TheSamba |
Actually Tram, I did get a reminder email from TheSamba notifying me that my premium membership was about to expire. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Sat Nov 06, 2021 6:39 pm Post subject: Re: Thankful for TheSamba |
Tram wrote: |
Jennepher wrote: |
Abscate wrote: |
To this day, in my experience, there still isn't anything quite like it. Other sites TRY but they just lack the magic somehow. |
Hey, Tramuel---lookit---up there. By my name. I just bought it. Trying to make amends in my old age for my errant ways of yore. |
Posted: Sat Nov 06, 2021 7:18 pm Post subject: Re: Thankful for TheSamba |
Now you are a good boy, it’s official |
Posted: Sat Nov 06, 2021 7:39 pm Post subject: Re: Thankful for TheSamba |
tasb wrote: |
Actually Tram, I did get a reminder email from TheSamba notifying me that my premium membership was about to expire. |
Mom always DID like you best!! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Sat Nov 06, 2021 7:40 pm Post subject: Re: Thankful for TheSamba |
iowegian wrote: |
Tram wrote: |
Jennepher wrote: |
Abscate wrote: |
Does it come with a signature line? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
EverettB Administrator
Joined: April 11, 2000 Posts: 69810 Location: Phoenix Metro
