Notch_Norway Samba Member
Posted: Wed Nov 03, 2021 12:44 am Post subject: Gearbox swap in a 52 |
Hi,
This topic has been covered, but i cant find any threads as of now.
Anyway. I`ve been told i need this adapter to fit a newer gearbox in the split bugs if i don't want to weld a bracket in.
Is this correct or is it just a nosecone swap and I'm good like in the later bugs?
https://wagenswest.com/product/lollipop/
Please dont turn this into a campaign for me to run the OG gearbox |
splitjunkie Samba Member
Posted: Wed Nov 03, 2021 4:16 am Post subject: Re: Gearbox swap in a 52 |
I have never used one but it looks like a pretty workable solution. Urethane motor mounts tend to be crap so that is my main reservation.
Keep in mind that you will still need a bus nose cone and hockey stick to use this mount.
The other option, is to install a late '52-'59 split case synchro transmssion with a '59 and earlier bus nose cone and hockey stick. This will all bolt in with no mods other than having to drill a hole in the top of the hockey stick for the shift lever lock screw. This won't be as robust as a tunnel trans but will give you synchromesh on 2nd through 4th and will be fine if you aren't running a big engine. _________________ Chris
Posted: Wed Nov 03, 2021 4:33 am Post subject: Re: Gearbox swap in a 52 |
Thanks
I have bought a T2 nose cone. What is a hockeystick? |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Wed Nov 03, 2021 6:12 am Post subject: Re: Gearbox swap in a 52 |
Notch_Norway wrote: |
Thanks
The hockey stick is the shift rod that is mounted through the nose cone. It is matched to the style of nose cone, so you need the bus hockey stick for the bus nose cone. _________________ modok wrote:
Posted: Wed Nov 03, 2021 6:39 am Post subject: Re: Gearbox swap in a 52 |
Thanks, mate |
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Sat Dec 25, 2021 7:38 am Post subject: Re: Gearbox swap in a 52 |
The name "hockey stick" is slang, because the overall shape resembles that of a sports hockey stick with its downward-bent "paddle" area and the long holding stick (W1K1 gallery). Here you can see small differences with the hockey stick "paddle" end, the dimple location, and the shape &length of the "Z" of the paddle end.
Per esde's explanation, here's a photo from a later Type 2 repair manual showing how the hockey stick fits through the nose cone (AndyBees gallery). Beetles and other VWs have different details but the principle is the same. The front end of the stick (the long end "handle") has the small dimple. This dimple is where you attach the small securing bolt of the shift rod's rear bushing and mounting cage. When you shift gears using your shift lever, the shift rod rotates slightly and moves front/back. This motion is transmitted into the transmission via the hockey stick.
Lind Samba Member
Joined: November 06, 2000 Posts: 9916 Location: idaho
Posted: Sat Dec 25, 2021 8:33 am Post subject: Re: Gearbox swap in a 52 |
If you are going to use a later split case gearbox with 2nd-4th gears synchronized, then I'm pretty sure you can use your original nose cone and hockey stick. (this is a '53-'60 beetle gearbox)
If you are going to use a fully synchronized tunnel type gearbox, then you have to get creative. There are four different solutions, all of which have some drawbacks. (the "lollipop", a plate that hangs way down, a bolt on piece for the nose cone, and an aftermarket nose cone. they are all discussed in various places in the split bus forums) I didn't like any of them, so I took a different route.
On my '50, I took a '60s era tunnel type nose cone, and had a machinist turn it down on a lathe, and then weld part of a split case nose cone onto it so it fits into the stock mount. Then we used a bolt on mid mount on the transmission to help hold the weight so the nose cone would have an easy life. This solution worked well, and is total bolt-on, with no hacks to the car. The down side is that it is a bunch of work and expense (not that any other solution is particularly cheap and easy). I have driven it over 6500 miles with a 100+ hp engine, and it works just fine. _________________ .
Wanted:
sunroof Samba Member
Joined: October 06, 2006 Posts: 1774 Location: Winnipeg
Posted: Sat Dec 25, 2021 9:11 am Post subject: Re: Gearbox swap in a 52 |
Quote: |
On my '50, I took a '60s era tunnel type nose cone, and had a machinist turn it down on a lathe, and then weld part of a split case nose cone onto it so it fits into the stock mount. Then we used a bolt on mid mount on the transmission to help hold the weight so the nose cone would have an easy life. |
I think we need pictures because this sounds like a good solution.
Don _________________ Better and better mistakes! |
Lind Samba Member
Posted: Sat Dec 25, 2021 11:04 am Post subject: Re: Gearbox swap in a 52 |
sunroof wrote: |
Don |
I'll try to get some pics. The hard part is finding a machinist/welder to marry the two nose cones together. _________________ .
Wanted:
Posted: Sun Dec 26, 2021 7:59 am Post subject: Re: Gearbox swap in a 52 |
Lind wrote: |
On my '50, I took a '60s era tunnel type nose cone, and had a machinist turn it down on a lathe, and then weld part of a split case nose cone onto it so it fits into the stock mount. Then we used a bolt on mid mount on the transmission to help hold the weight so the nose cone would have an easy life. This solution worked well, and is total bolt-on, with no hacks to the car. The down side is that it is a bunch of work and expense (not that any other solution is particularly cheap and easy). I have driven it over 6500 miles with a 100+ hp engine, and it works just fine. |
This is incorrect. You need a '59 -'59 split case bus nose cone and hockey stick which continued to use the rubber doughnut/retaining plate arrangement until they went to the tunnel transmission on the bus in 1960. You will also need the rear transmission cradle so you can use the later style rear trans mounts. This will be completely bolt in configuration although you will still need to drill the divot on the top of the hockey stick.
The '59 and earlier synchro (2-4th) definitely won't work as it is not setup for the doughnut mount and the '60 was a one year only part that is very different so it won't work either.
This is the late '52 (Zwitter) -'59 Beetle nosecone.
This is the '53 - '59 Bus nosecone. Note the much larger diameter of the shifter shaft area and the half round ridge that mates with the rubber doughnut mount.
