VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Wed Jan 12, 2022 8:07 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Ok, don't need it. I guess I can remove it then?
Just curious, what's it for? The cruise control already receives an electric signal if the brakes are depressed. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Zeitgeist 13 Samba Member
Posted: Wed Jan 12, 2022 10:00 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
It's a redundant system; using both vacuum and electrical signals. This cruise system is really nice when it works, so unless you're morally opposed to the concept, I'd just leave it dangling, or at least pull it as a complete kit to sell to the next guy. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
VicVan Samba Member
Posted: Wed Jan 12, 2022 11:54 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
It worked very well on the WBX. Unfortunately, it is not compatible with the new engine. I'll take it out and put it in the parts bin, with the other cruise control components. Thanks for the info. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
VicVan Samba Member
Posted: Thu Jan 13, 2022 12:04 am Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Finished fixing the bumper,
treated some small rust spots on the body behind the bumper,
cleaned the inside of the frame rails (bumper to rear crossmember @ firewall - will spray Fluid Film in there),
installed dash harness,
started installing the cruise control unit,
new throttle cable,
installed ECU harness and ECU bracket.
It seems like the number of steps backwards for every step forward is decreasing. That's a good thing.
Notch the wall of the water tank enclosure slightly, because that harness connector is huge:
Trim off some of that bench sidewall too, so the harness isn't too tight, a few screws, and voila!
Dang, they put the sticker upside down... _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Vana Guy Samba Member
Posted: Thu Jan 13, 2022 8:40 am Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Was wondering if there is any metal on the bottom of the ECU. |
VicVan Samba Member
Posted: Thu Jan 13, 2022 10:00 am Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
What do you mean? The ECU is enclosed in the aluminum casing you see. The only place non-metal in that casing is the part on the top, with the electrical connectors. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
VicVan Samba Member
Posted: Fri Jan 14, 2022 10:03 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Man, adjusting the engine carrier bar mounts was a lot more work than I thought. Bumper brakcets had to be threaded, holes had to be enlarged, metal to be straightened, metal had to be ground down... But it's done! I can finally install the carrier bar on the engine.
Supporting the carrier bar for dry-fitting
Reinforcement blocks in place, holes enlarged, rust treated:
Dash (almost) complete:
Harness through front wall (I reused and enlarged the existing hole for stock cruise control vaccum tubing):
Drive-By-Wire accelerator pedal, here seen at the oddest possible location, because the Vanagon's automatic transmission was designed in 1370 and does not know what an electron is:
Tomorrow: finish dash install, coolant bottle bracket, bits and pieces (firewall fuel spigot, electrical connections, coolant lines, MAF-airbox adapter, air filter, fuel filter), and, oh, mating engine to transmission, ATF dipstick modification... _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
VicVan Samba Member
Posted: Sat Jan 15, 2022 9:14 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Another good day today, many small things completed.
Finished installing the dash
Coolant and Power Steering tanks bracket
Fuel spigot (I got rid of the original plastic one a long time ago, and was replaced by hose, but since this part is included in the kit, might as well use it!)
ECU installed. I need to make a metal or wooden enclosure to protect the ECU and harness
Engine bay ready for install... Notice the stainless steel coolant tubing on the right
The AVH spreading its tentacles over the good'ol tranny:
Tomorrow: ATF dipstick modification, engine to transmission mating, and if all goes well (sure it will...), raising the engine in the bay! _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
VicVan Samba Member
Posted: Sat Jan 15, 2022 9:59 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
I need to modify the ATF dipstick, because it now interferes with the engine. I have to bend it towards the passenger side. FAS recommends using a small propane torch, and bending it a in few steps. Any tips before I tackle this? _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
VicVan Samba Member
Posted: Sun Jan 16, 2022 9:16 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Dipstick modification:
Engine and transmission were mated together, and put on a rolling cart
Engine is then lifted in the engine compartment:
Aaaand... engine is in! And no, I don't have pictures, forgot to take some with all the exictement...
Thanks to Wayne for coming over and helping today! Thanks to my Dad and my buddy Max too. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Mon Jan 17, 2022 8:04 am Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
VicVan wrote: |
What do you mean? The ECU is enclosed in the aluminum casing you see. The only place non-metal in that casing is the part on the top, with the electrical connectors. |
Great job! please post pictures of engine in engine bay.
Some ECUs with metal bottoms, or metal around mounting holes, rely on mounting to metal surface to transmit heat from ECU to metal surface. |
VicVan Samba Member
Posted: Mon Jan 17, 2022 8:41 am Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Thanks!
That's good to know. Yes, this ECU is a metal box on all sides. The bracket is aluminium too, but too small to be a heat sink (and it's aluminium, not great for heat conduction). The ECu is mounted as per FAS' instructions, but I'll keep an eye on the temperature of the box, especially in the summer. Thanks for the tip. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
khughes Samba Member
Joined: July 13, 2013 Posts: 747 Location: Phoenix AZ
Posted: Mon Jan 17, 2022 1:37 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
VicVan wrote: |
Thanks!
That's good to know. Yes, this ECU is a metal box on all sides. The bracket is aluminium too, but too small to be a heat sink (and it's aluminium, not great for heat conduction). The ECu is mounted as per FAS' instructions, but I'll keep an eye on the temperature of the box, especially in the summer. Thanks for the tip. |
Mine's been fine connected to the wood in our 118F summers, so I wouldn't worry too much about it in your neck of the woods! _________________ '86 Westy FAS GenV Turbo (Marvin) |
VicVan Samba Member
Posted: Mon Jan 17, 2022 2:10 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
A little teasing in the meantime... Seen from below.
VicVan Samba Member
Posted: Mon Jan 17, 2022 8:20 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Crankshaft rotating tool, reference M12-2x4
FAS bracket and cable, going from the transmission kick-down lever to the Drive-By-Wire pedal
Remember that boot for the end of the shifter cable that's NLA? I found a quick and cheap fix. Not ideal, but not bad:
And when you think you've seen it all, and all the bad stuff is behind you, and all you have to do is install new parts... You shear a transmission mount bolt, because your torque wrench is a piece of crap (remember, always blame your tools). And then as you're removing the piece of screw in there, you break the nut free (the one that's welded from inside the frame rail). Fun.
4Gears4Tires Samba Member
Posted: Mon Jan 17, 2022 8:45 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Man, that's a lot of progress and then a serious setback. We've all been there for sure.
What is your fix for the broken captive nut? A rivnut could work. But if the spacing is off, you might have to weld it shut, drill through the weld (fun), and then install the rivnut. _________________ '87 Syncro
VicVan Samba Member
Posted: Mon Jan 17, 2022 9:09 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
There's a hole in the framerail nearby. I can almost access the top of that hole. I'll try to JB Weld the original nut back in place. If it fails, Rivnut, thanks for the idea. Never done one of these, but I guess it's time. I just don't want to remove all the engine mounts, put the cherry picker back on, etc. so I can lower the transmssion and get clearance to install the rivnut. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
VicVan Samba Member
Posted: Tue Jan 18, 2022 12:37 am Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Connecting vacuum hose from brake booster to engine. Inner diameters are fairly similar. Do I just heat up the black tube with a heat gun, or do I need some kind of adapter? (Picture should be rotated 90 deg clockwise...)
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Tue Jan 18, 2022 9:04 am Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
get some of this:
https://www.busdepot.com/n203741
it should slide over both pieces without a problem _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
VicVan Samba Member
Posted: Wed Jan 19, 2022 12:12 am Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
skills@eurocarsplus wrote: |
it should slide over both pieces without a problem |
Thanks for the idea! I reused a piece of old power steering line:
4Gears4Tires wrote: |
What is your fix for the broken captive nut? |
JB Weld some wire to the back of the not-so-captive-anymore nut (looks real fancy):
Place some JB Weld on the captive nut and inside the framerail
Position captive nut in place, and remove JB Weld from threads using a Q-tip
Gently screw in shiny new fastener (note: captive nut has been rethreaded prior, to ensure smooooth screwing) until captive nut is tight against the framerail
Wait overnight for the JB Weld to cure, and tighten to torque. That's tomorrow morning. We'll see...
Meanwhile, above the chassis:
