Red Beard Samba Member
Joined: May 09, 2006 Posts: 463 Location: Seattle, WA
Posted: Sun Nov 28, 2021 2:27 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Steel coolant pipes if you haven't already done it.
I'll be really curious how you like the setup with the AT. I assume your transmission will have stock gearing for now?
I initially converted to the 2.0T but removed the turbo due to recurrent issues that disrupted reliability for me. I am now underpowered with the NA setup and the 3.27 R/p I did with the original conversion, but it sure runs nice! _________________ 1990 Vanagon, FAS Gen V 2.0 NA, AT w/ Peloquin diff, NAHT conversion |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Sun Nov 28, 2021 3:04 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Hi Red Beard, yes I'll be leaving the automatic transmission stock. I don't like to change too many things at the same time. First, it's more expensive , second I like to differentiate between modifications, understand which mod has more impact. It gives me a better feel of the mechanics of the van. Third, it's easier to troubleshoot of something goes wrong. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
VicVan Samba Member
Posted: Mon Nov 29, 2021 5:42 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Good news: engine ships tomorrow.
If I raise the rear of the van on 8" ramps, I'll have approx. 24" of clearance at the rear. Is that enough? _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
VicVan Samba Member
Posted: Thu Dec 02, 2021 11:33 am Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Van is raised, I have 28-29" of clearance. Should be fine.
I gave in to your suggestions and ordered some stainless steel coolant lines from Werke1/GoWesty.
FAS folks: is the cooling tower retained in the FAS setup or do I remove it?
(Image credit GoWesty) _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Thu Dec 02, 2021 12:36 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Every time this thread pops up, I find myself wandering over the the FAS site and doing irrational expenditure calculations in my head. I really REALLY wanted to use their MK3 mount setup on my engine but my supercharger won't fit at 50 degrees. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Thu Dec 02, 2021 2:04 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
joetiger wrote: |
Every time this thread pops up, I find myself wandering over the the FAS site and doing irrational expenditure calculations in my head. I really REALLY wanted to use their MK3 mount setup on my engine but my supercharger won't fit at 50 degrees. |
Hey Joe, with all the if's and but's you think through, just raise your bar, get more buses!!!
https://www.thesamba.com/vw/gallery/pix/2222274.jpg _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Thu Dec 02, 2021 2:16 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
bobbyblack wrote: |
joetiger wrote: |
https://www.thesamba.com/vw/gallery/pix/2222274.jpg |
Ha! First I need the good yard for them! _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Vanagon Nut Samba Member
khughes Samba Member
Joined: July 13, 2013 Posts: 747 Location: Phoenix AZ
Posted: Thu Dec 02, 2021 8:05 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
VicVan wrote: |
(Image credit GoWesty) |
Nope, not mine anyway. All the hoses are replaced, and can be replaced with hoses from any FLAPS. _________________ '86 Westy FAS GenV Turbo (Marvin) |
VicVan Samba Member
Posted: Thu Dec 02, 2021 8:49 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
The answer I was hoping for. Cheers.
Thanks Neil. How did I miss their photo gallery? I'll head over there now and drool a little bit. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Thu Dec 02, 2021 9:20 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
You're welcome VicVan.
Yeah, that link is at the bottom of their home page. They used to have (still do?) a "beta" album of stuff that was really cool. To my mind, IIRC, it provided some insight into the manufacturing and/or design processes.
1988 West DIY 50º ABA
VE7TBN |
VicVan Samba Member
Posted: Fri Dec 03, 2021 7:05 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Almost done disconnecting the engine from the van.
A couple of questions :
1/ Will the large ECU connector (under the rear bench) fit through the hole in the firewall?
2/ How do you remove the accelerator cable (coming from the front) from the transmission (automatic)?
If I get these two sorted out tomorrow, I'm left with CV joints and I'll be ready to remove the engine+transmission on Sunday. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Fri Dec 03, 2021 7:16 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
VicVan wrote: |
Yes.
This pic isn't so great but might shed some light. I got the ECU plug out as shown but I think turning it (and harness) would help.
edit: it's possible the cover comes off the plug which would obviously help.
VE7TBN |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2796 Location: North Carolina
Posted: Fri Dec 03, 2021 7:19 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
I honestly can’t remember how to remove the cable, which generally means I followed the Bentley and/or YouTube.
Connector does not fit pretty sure. EDIT and look wrong again!
I’m with joetiger can’t wait for the rest of this thread, go FAS! _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
VicVan Samba Member
Posted: Sun Dec 05, 2021 9:45 am Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Thanks for the above tips. I had to unscrew the side panel of the bench to give me more wiggle room to remove the ECU connector.
As for throttle cable, removing the ball is a pain. I ended up removing the L-shaped lever from the transmission altogether, and will remove the ball from the socket on the bench.
Only thing left in the way are CV joints (and whatever I have forgotten of course). I'll be removing the engine today.
In the meantime, here's what I found in the coolant tank:
Amagnetic and real shiny, most likely aluminium. Water pump bearing/axle gave up a year ago on the highway, I believe that's when this happened. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
VicVan Samba Member
Posted: Sun Dec 05, 2021 8:04 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Engine is out! Feels good, and weird.
Shoutout to Alex and Wayne, who were not afraid by the near-freezing temperatures, and came to help. And second thanks to Wayne for lending me his engine hoist. It helped!
Don't know what to start next. Transmission/engine separation? Rust-proofing the engine compartment? Installing those stainless steel collant lines? _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
9.5isCanadian Samba Member
Joined: September 16, 2017 Posts: 465 Location: In your blind spot.
Posted: Mon Dec 06, 2021 8:46 am Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
VicVan wrote: |
I gave in to your suggestions and ordered some stainless steel coolant lines from Werke1/GoWesty. |
Hi VicVan.
I see you're planning on replacing a bunch of coolant pipes.
Don't overlook Concept 1 as a supplier.
They're Canadian, Calgary and I've found their prices are comparable or even better than the other suppliers.
Most things arrive within the week.
I've purchased all the coolant pipes in stainless from them.
https://store.concept1.ca/ _________________ 9 1/2 - missing a few pieces.
1987 Getaway Hightop
1980 Sunroof Vanagon
2018 BMW R Nine T
2012 Golf tdi |
valvecovergasket Samba Member
Posted: Mon Dec 06, 2021 9:25 am Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
VicVan wrote: |
Don't know what to start next. Transmission/engine separation? Rust-proofing the engine compartment? Installing those stainless steel collant lines? |
coolant lines and maybe a quick flush of whatever other cooling hoses remain?
looking forward to seeing the new setup in there! _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
Zeitgeist 13 Samba Member
Posted: Mon Dec 06, 2021 10:37 am Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
That gunk in your cooling system looks like the vestigial remnants of a stop leak product. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
VicVan Samba Member
Posted: Mon Dec 06, 2021 10:39 am Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
9.5isCanadian wrote: |
VicVan wrote: |
Hi VicVan.
https://store.concept1.ca/ |
I use them too, but unfortunately they are out of stock of the stainless steel coolant lines (or were when I ordered anyway).
valvecovergasket wrote: |
VicVan wrote: |
looking forward to seeing the new setup in there! |
Yup, I'm changing the main coolant lines to stainless, and will flush what's left. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
