dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
Vanagon Nut Samba Member
Posted: Sun Jan 09, 2022 5:40 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Those Vise-grips are good for another 100K.
Nice work. That engine will just hop right in now!
To try and answer your question, I'd say yes to wire wheel, top coat of your choice at part bumper mounts to.
My '81 has bad rust perforation in engine bay metal under area bumper rail slides in. This might be what dobryan is getting at but maybe Fluid Film or similar sprayed into bumper rail tube would creep and protect areas nearby.
Caveat: Fluid Film creeps REALLY well. e.g. past a body seam seal and onto paint.
Enjoying your thread.
Neil.
VicVan wrote: |
The Vise-Grip put up a nice fight, but suffered a few injuries...
_________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Sun Jan 09, 2022 7:12 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Looks like a fun project, but I'm confused, your title says Little Blue Truck ? I was looking for a Doka or Sinka ??? You B.C. guys talk funny..
Good luck w/ your install, John & the FAS guys do some good work.... _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Sun Jan 09, 2022 7:29 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
crukab wrote: |
Good luck w/ your install, John & the FAS guys do some good work.... |
It's from a kid's book my son used to love:
_________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Zeitgeist 13 Samba Member
Posted: Sun Jan 09, 2022 9:46 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Looks kinda like a '36 Studebaker |
enochramal Samba Member
Joined: September 29, 2015 Posts: 76 Location: Klamath Falls Oregon
Posted: Mon Jan 10, 2022 1:18 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Looks great can't wait to hear it fire up! _________________ 1988 Vanagon "Bill Murray", 2WD manual w/Peloquin Torque-biasing differential, FAS GenV 2.0 NA (AVH) |
VicVan Samba Member
Posted: Mon Jan 10, 2022 5:01 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
How do I clean the power steering fittings? Is there a coating/paint, or is it just brass and I can wirewheel it to make it shiny?
Posted: Mon Jan 10, 2022 5:32 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
That's a cadmium plating over steel. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
VicVan Samba Member
Posted: Mon Jan 10, 2022 11:41 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Thanks. I'll just degrease it then. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
1988M5 Samba Member
Joined: January 23, 2016 Posts: 674 Location: Santa Cruz, CA
Posted: Tue Jan 11, 2022 1:18 am Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Tub-O-Towels is your friend here. A wire wheel will make anything look great temporally. Like paint work, start with the mildest solution 1st then go up as needed. If the parts are off the car and free in hand, brake clean aerosol followed by a blast of compressed right after, works fine. Don't let parts have Brake Clean on them for long, I'm talking a few seconds. If you have the time and patience, diluted Simple Green and a nylon brush is the solution that can't go wrong.
BK _________________ 1991 tin top GL
Some BMWs. |
Posted: Tue Jan 11, 2022 1:59 am Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Don't leave undiluted Simple Green on cadmium plating for too long, or it will dull and stain the finish. I've done this far too many times. _________________ Casey--
y u rune klassik? |
VicVan Samba Member
Posted: Tue Jan 11, 2022 10:24 am Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Thanks for the tips. I'll be gentle then.
Here is another one, less fun:
I was cleaning the stalk assembly when bzoing, the wiper stalk component let his minions run free:
Any idea, diagram, video, on how to reassemble these buggers?
(this was brought to you by the "If it ain't broke, dont fix it" and "I told you so" folks) _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6361 Location: Honolulu,Hawaii and France
Posted: Tue Jan 11, 2022 10:52 am Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
The plastic plunger goes horizontally, the contacts go on the bottom. That's not gonna be fun to put back in place, you must have forced down on the lever at some point to pop these out.... The lever is riveted making things hard to put back in place. I did it years ago, I can't remember exactly what little part goes where but it's fairly obvious. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Tue Jan 11, 2022 11:52 am Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Vicvan: not sure this would help but if you want, I can post close up images of my spare wiper stalk (s?). Don't know what year they're for though.
VE7TBN |
VicVan Samba Member
Posted: Tue Jan 11, 2022 1:22 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
I think I see where the thingies go, but yeah it's going to be a pain... I'll call local veedub garages to see if they have any old ones laying around.
Neil, thanks for the offer, but I don't think it'll help. When the assembly is properly assembled, you can't really see hese small parts.
Alika, you did, so it's not impossible! I'll give it a shot, who knows. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1491 Location: Victoria,B.C.Canada
Posted: Tue Jan 11, 2022 2:11 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
I have a new one from CIP1. It came apart on me and CIP1 sent me a replacement that I used. It's together except for that little H or n metal piece. |
metropoj Samba Member
Posted: Tue Jan 11, 2022 7:32 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
VicVan wrote: |
Any ideas on what to do with the crate? A fort? Trailer? |
So, my TiiCo crate from South Africa became our back yard Leaf Compost box
I just put a couple hinges on the top and a handle, drilled a couple holes and it does a great job.
Damn that's a beauty of a motor. _________________ John.
86 TiiCo powered Westy. |
Posted: Wed Jan 12, 2022 4:53 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
I will be following closely as I just ordered mine. Started a thread here...
https://www.thesamba.com/vw/forum/viewtopic.php?p=9785610#9785610 _________________ 1988 Vanagon "Bill Murray", 2WD manual w/Peloquin Torque-biasing differential, FAS GenV 2.0 NA (AVH) |
VicVan Samba Member
Posted: Wed Jan 12, 2022 6:51 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Unable to fix the wiper stalk. Ordered one at Dr Bjorn.
What's this? Vacuum tube, going from the brake pedal to the engine compartment, right side. Can I get rid of it? I'd like to reuse the hole behind the dash (passenger side, as seen on the second picture) to pass the FAS harness.
Posted: Wed Jan 12, 2022 7:02 pm Post subject: Re: Little Blue Truck gets a new engine - FAS 2.0 engine conversion |
Cruise control vacuum tube. _________________ Casey--
y u rune klassik? |
