bluesman Samba Member
Joined: September 27, 2006 Posts: 130 Location: wheeling,wv
Posted: Fri Nov 12, 2021 11:44 am Post subject: 65 sunroof project |
I’ve had this 65 steel sunroof car for a long time. Thought I'd start a thread to document some of the metal work, that's been happening.
Found a nice radio hole, from another car, so I could put my delete plate in.[
Marked and cut, so I can get in to some good, straight metal.
Found a couple bolts, close to the size of the wiper/headlight switch diameter. snugged them up. then , I scribed a line on the bottom of the new piece, so I had something constant. Then whittled the new piece down to fit.
Some redneck indexing with a sharpie
Welder up! A little at a time.
We're in, and the trim lines up pretty nice..
The hacked dash has always been sore spot. Much better now. I was lucky the replacement dash piece, had the holes for the switches, so I could get it lined up right, for the trim. Pretty happy with the way it turned out. Maybe this could help someone down the road..
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
Posted: Fri Nov 12, 2021 12:27 pm Post subject: Re: 65 sunroof project |
That is bare metal... |
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Fri Nov 12, 2021 4:10 pm Post subject: Re: 65 sunroof project |
Great job! I
What did you do on the trunk side? Did you leave it as is, or did you metal finish as well?
I have to do this too but am baulking at doing it because I’m not sure how I’m going to grind the welds on the trunk side. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Posted: Fri Nov 12, 2021 6:00 pm Post subject: Re: 65 sunroof project |
Thank you!!
It’s “as is” for now. I’ll probably run a mini disc over it. Maybe put a little filler. I have the wiring cover that will enclose it also. Be difficult to see. |
Jennepher Administrator
Joined: September 10, 2002 Posts: 4767 Location: Arizona
Posted: Sat Nov 13, 2021 7:09 am Post subject: Re: 65 sunroof project |
She’s a border collie/lab. A Borador. 😂 |
Posted: Mon Nov 15, 2021 8:43 am Post subject: Re: 65 sunroof project |
I have a NOS German front apron. Car isn't nice enough to waste it on. So , I picked up a Wolfsburg West piece. This one has the correct teardrop holes (both sides) for the trunk release, and the correct overider holes.
Had to add on to the floor of the spare tire well.
Both sides of the spare tire area needed replaced.
Mock up, and cut.
Didnt care for the bumper brackets, already on the wolfsburg panel. Had to go. Ordered one from CIP1. looks like an original.
First time since I've owned the car, that everything has been bolted properly. Bumpers, brackets, over riders.. |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Wed Nov 17, 2021 5:53 pm Post subject: Re: 65 sunroof project |
holy moly you did awesome welding the front clip sir! _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Posted: Thu Nov 18, 2021 12:31 pm Post subject: Re: 65 sunroof project |
Thank you ... Its not quite a full clip replacement. Probably should've replaced the whole thing. Here's a few more pics
Clean shop! Small...but I get a lot of work done in this little 20x20
Apron is still loose, so I'm trying to take care of any straightening, sanding
Posted: Wed Nov 24, 2021 8:48 am Post subject: Re: 65 sunroof project |
For this part, I'll just say....I did the best with what I had. I searched high and low for a German 1/4 panel, with no luck.... Or, the shipping was more than the person wanted for the piece.
Found this at a swap meet years ago. $25 I think.. Have no idea who made it. It's for a 70's car.
Posted: Wed Nov 24, 2021 9:06 am Post subject: Re: 65 sunroof project |
Must have fit and re-fit the piece 500 times.
Wheel arch isnt quite right, door gap was more important to me.
Posted: Tue Nov 30, 2021 9:54 am Post subject: Re: 65 sunroof project |
matthew henricks wrote: |
Nice work on that quarter panel. Clean. |
Thank you! |
Posted: Tue Nov 30, 2021 9:58 am Post subject: Re: 65 sunroof project |
It has to get worse before it gets better.
Donor
Need a better pic of the final product
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2008 Location: Texas
Posted: Thu Dec 02, 2021 12:17 pm Post subject: Re: 65 sunroof project |
Your metal work is impressive! Makes me wish I had taken up welding in high school. _________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
Posted: Fri Dec 03, 2021 8:31 am Post subject: Re: 65 sunroof project |
sportin-wood wrote: |
Your metal work is impressive! Makes me wish I had taken up welding in high school. |
Thank you! Appreciate it.. I wish I had taken some classes myself. I'm self taught. Some times it shows.
I've learned a lot from these forums. There's some nice work being done out there. |
keegs Samba Member
Posted: Sat Dec 04, 2021 6:44 am Post subject: Re: 65 sunroof project |
bluesman wrote: |
Thanks Bluesman ...not sure how you welded this... did you lap or butt ?? ... Did you weld both sides? Really nice job ..TIA |
Posted: Sat Dec 04, 2021 7:23 am Post subject: Re: 65 sunroof project |
keegs wrote: |
bluesman wrote: |
It is “butt” welded, only one side. Then I filed the welds by hand. Then finish with an 80 grit mini discs. |
keegs Samba Member
Posted: Sat Dec 04, 2021 9:10 am Post subject: Re: 65 sunroof project |
[quote="bluesman"]
keegs wrote: |
bluesman wrote: |
It's a very tight seam... did you cut and butt with a dremel? Newbe trying to find his way |
