dave1 Samba Member
Joined: September 12, 2003 Posts: 478 Location: United Kingdom, London
Posted: Sun Nov 14, 2021 4:25 pm Post subject: 52 Deluxe crotch cooler front seal |
Hi all,
Quick question. I'm restoring a 52 deluxe crotch cooler. Not sure if the front screen should have chrome trim or not? Purchased seal without but not sure now. Looked at numerous cars & undecided. Can you help clarify with or without
Thanks Dave |
Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 4125 Location: Planet VW
Posted: Sun Nov 14, 2021 5:03 pm Post subject: Re: 52 Deluxe crotch cooler front seal |
After April 13th, 1951, chrome around the front window. _________________ CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker |
splitjunkie Samba Member
Posted: Mon Nov 15, 2021 9:36 am Post subject: Re: 52 Deluxe crotch cooler front seal |
And to add, the seal and trim was different than later ones from the oval/zwitter era onward. The split trim had steel clips that fit into the groove on the rubber seal and the chrome strip attached to the clips.
https://www.thesamba.com/vw/classifieds/detail.php?id=716125
https://www.thesamba.com/vw/classifieds/detail.php?id=434252
The above reproductions are available but you can use the oval window rubber and chrome strip.
Unless someone is really looking, it is hard to tell the difference. If you want it to be 100% correct you will need to use the above repro parts, otherwise just use the commonly available, and cheaper, oval parts. _________________ Chris
