Das67bus Samba Member
Joined: April 06, 2008 Posts: 242 Location: Prescott, AZ
Posted: Mon Nov 15, 2021 6:32 am Post subject: Master Cylinder application |
A question to the brake experts on The Samba:
Could a 1968-1969 master cylinder work on a 1967 bus? Any other years?
What would have to be changed/modified, if so? Fittings, lines, etc?
I cannot find a German made master cylinder for a 1967. Reproductions, but not the better quality product.
As always, thanks for your help!! _________________ SLOW RIDE........TAKE IT EASY!!!
-Foghat
COMFORTABLY NUMB!!
-Pink Floyd |
easy e Samba Member
Joined: May 28, 2008 Posts: 3930 Location: 1 hr north of Santa Barbara
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Mon Nov 15, 2021 10:41 am Post subject: Re: Master Cylinder application |
Das67bus wrote: |
As always, thanks for your help!! |
Just because it says made in Germany dose not mean it is. Most likely produced somewhere in the world and crated to Germany. It is then given it's final packaging and labeling to be shipped out.
The rules are pretty vague on what "Made In" actually is. In the bicycle industry Made In the USA could be a fully welded and machined frame delivered to a US company for paint, stickers, final parts assembly and packaging.
I have been running white box China brake parts for the last 20 years with no issues. The only thing I did before install was a final inspection, cleaning and reassembly. |
easy e Samba Member
Posted: Mon Nov 15, 2021 1:21 pm Post subject: Re: Master Cylinder application |
ToolBox wrote: |
The rules are pretty vague on what "Made In" actually is. In the bicycle industry Made In the USA could be a fully welded and machined frame delivered to a US company for paint, stickers, final parts assembly and packaging. |
The rules aren't vague and companies can be sanctioned for not labeling correctly. "Made in" is different than "Assembled in."
Ref. https://www.cbp.gov/sites/default/files/assets/documents/2020-Jul/ICPMarking-of-COO-onUS-Imports.pdf _________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13247 Location: Tejas!
Posted: Mon Nov 15, 2021 3:48 pm Post subject: Re: Master Cylinder application |
bus depot lists ATE brand but it's pricy. https://www.busdepot.com/211611011q
you can rebuild yours. if you buy the chinese one, get it from rock auto at $48. I would take it apart and clean / lube it. |
Posted: Wed Nov 24, 2021 6:39 am Post subject: Re: Master Cylinder application |
Thank all of you for your replies and help!!
I'll check it all out............... _________________ SLOW RIDE........TAKE IT EASY!!!
-Foghat
COMFORTABLY NUMB!!
-Pink Floyd |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24670 Location: Olympia Wash Rinse & Repeat
Posted: Wed Nov 24, 2021 7:09 pm Post subject: Re: Master Cylinder application |
Problem is the 1968-69 MC requires a different brake fluid set of reservoirs, and tubing between is not like a beetle.
The 1971-79 bus MC will accept the 1967 only bus reservoir or the rabbit one. With no tubing required. _________________ In Stereo, Where Available! |
Posted: Fri Nov 26, 2021 10:03 am Post subject: Re: Master Cylinder application |
Eric&Barb wrote: |
The 1971-79 bus MC will accept the 1967 only bus reservoir or the rabbit one. With no tubing required. |
OK, thank you!! Good to know........ _________________ SLOW RIDE........TAKE IT EASY!!!
-Foghat
COMFORTABLY NUMB!!
-Pink Floyd |
Posted: Fri Nov 26, 2021 11:27 am Post subject: Re: Master Cylinder application |
Glad to help.
Diagram below shows both versions of the 1968-70 bus MC reservoirs (1&2) with upper mini reservoirs (5&6):
Highly recommend you dig deeply into the "Split Bus FAQ and How Tos - *Read before posting*" up at the top of the split bus forum. That has a ton of specific need to know info concentrated in it. Amongst all in there is a thread about installing the 1971-79 bus MC. Enjoy! _________________ In Stereo, Where Available! |
