Abigdumkid Samba Member
Joined: November 17, 2017 Posts: 74 Location: Minnesota
Posted: Mon Nov 15, 2021 8:29 pm Post subject: Rear seat area rebuild |
Hi there,
So winter is officially here and my 74 is going to be put away. I figure now would be a good time to redo the rear seat delete. Someone at some point put rear seats in it. I'd like to recreate the factory no seat. I managed to find an old thread that 74Ghia helped with..
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=20
I found an old picture he had about the bottom panel and have a question on it. Is this piece basically an L lying on its back or does that vertical piece extend just slightly past the back? Any help would be appreciated.
_________________ 74 Bahia red Ghia coupe. Built Jan 24th 1974, left on Jan 31st 1974. Initial destination Columbus/USA. |
gorbur Samba Member
Joined: October 10, 2010 Posts: 187 Location: West of Calgary
Posted: Tue Nov 16, 2021 5:41 pm Post subject: Re: Rear seat area rebuild |
Here's a picture of my 72's in its original state. The lip sits forward and is canted back slightly. Hopefully this helps you a bit.
_________________ 73 - Ghia Cabriolet, currently under resto
76 - Type1, 1776, full restomod |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Wed Nov 17, 2021 8:09 am Post subject: Re: Rear seat area rebuild |
this is how I made mine for a '72
some support for big butts, I can not lie
_________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Wed Nov 17, 2021 2:03 pm Post subject: Re: Rear seat area rebuild |
I made mine from MDF and put in 2 12” subs.
I can’t believe I don’t have a picture I can share.
Must still be on film and not digitized.
Anyway, yes. It’s basically an L.
I used cardboard to cut out a template then mocked up the pieces.
You will need some support for the L.
I reinforced mine about 6” in on each side.
I’ll see if I have any photos that I haven’t posted yet. _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Sun Nov 21, 2021 9:47 pm Post subject: Re: Rear seat area rebuild |
Thanks to all for the advice. I have lots to do after the holidays. _________________ 74 Bahia red Ghia coupe. Built Jan 24th 1974, left on Jan 31st 1974. Initial destination Columbus/USA. |
NoDents Samba Member
Posted: Mon Nov 22, 2021 8:13 am Post subject: Re: Rear seat area rebuild |
I did the same for my 71 vert. I took the opportunity to use the newly created space to mount my audio Amp to the plywood underside along with several other items to support my upgraded electronic gadgets. _________________ No Dents
1963 Bug - Sold in 1980
1966 Karmann Ghia Convertible - Stolen in 1988
1971 Karmann Ghia Convertible, resto/mod COMPLETED 10/2020 |
Joined: September 03, 2021 Posts: 1 Location: North Carolina
Posted: Wed Jan 26, 2022 10:32 am Post subject: Re: Rear seat area rebuild |
I have a question. I have purchased a 1973 Ghia convertible. I was told that the 73 did not come with a back seat? Is this correct? |
kingkarmann Samba Member
Posted: Wed Jan 26, 2022 11:39 am Post subject: Re: Rear seat area rebuild |
[email protected] wrote: |
Correct. _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
EJT Samba Member
Joined: August 07, 2014 Posts: 1 Location: Decatur, GA
Posted: Sat Jan 29, 2022 2:25 pm Post subject: Re: Rear seat area rebuild |
I have a 73 with everything missing in the back seat area... not even the rear seat delete. I would like to put a back seat in, but can't find one anywhere. I can only find seat covers. Any idea where to find a seat, and will a seat from an earlier model (before the seat-belt issue) fit the '73? |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13957 Location: Southampton U.K.
