Kerrick Samba Member
Posted: Tue Nov 16, 2021 11:14 am Post subject: 2000 Eurovan Sunroof stuck open |
Hey guys. On a nice day this past weekend I opened my Eurovan sunroof... Bad Idea, lol, now it won't close.
All my internet searches led me to the crank method but this sunroof motor doesn't have a spot for a crank. See attached picture.
https://photos.app.goo.gl/4Cn55HKdA49ozCYi8
The motor will try and turn if I press the open button but stops since its all the way back. If I try pressing close it does nothing. Doesn't even sound like its trying to turn.
I took the button off and tried jumpering the ground and close wire... no luck there either.
Any other ideas you guys have?
Thanks!
Andrew |
Posted: Tue Nov 16, 2021 11:14 am Post subject: Re: 2000 Eurovan Sunroof stuck open |
I should also add.... the sunroof leaks and has no drain lines so I've been thinking about sealing it anyway or adding a drain. |
soissisc Samba Member
Joined: April 04, 2007 Posts: 634 Location: Western Pennsylvania
Posted: Tue Nov 16, 2021 1:56 pm Post subject: Re: 2000 Eurovan Sunroof stuck open |
Do you have the tool? Mine was in the cover. Anyway, that middle part pushes in with a little bit of pressure and you can turn it. Maybe just a large flat screw driver would work if you do not have the tool? Maybe pushing in that center part releases it from the electric motor? I don't know. _________________ Mark
68 Westy
92 Jetta (oh it is retired)
99 Eurovan
05 NBC
06 Audi A3
72 Westy (I am going to fix it up) |
Posted: Wed Nov 17, 2021 6:19 am Post subject: Re: 2000 Eurovan Sunroof stuck open |
soissisc wrote: |
Do you have the tool? Mine was in the cover. Anyway, that middle part pushes in with a little bit of pressure and you can turn it. Maybe just a large flat screw driver would work if you do not have the tool? Maybe pushing in that center part releases it from the electric motor? I don't know. |
Oh nice. I'll give it a try. I tried pushing it in but I'll try pushing harder |
Posted: Wed Nov 17, 2021 9:19 am Post subject: Re: 2000 Eurovan Sunroof stuck open |
Unfortunately this is a no go. I do not have the tool as the last owner must have lost it. I tried pressing into the center of the wheel. It will not budge. Thinking this tool must flush fit into the notch.
@soissisc
Can you confirm that you have the same motor? I know they shipped different versions in these Eurovans.
Any way you can take a picture of it so I know what I'm looking for? I'm trying to find one online.
Thanks! |
Posted: Wed Nov 17, 2021 9:46 am Post subject: Re: 2000 Eurovan Sunroof stuck open |
I can get you a picture. It was a bit stiff to push that in. _________________ Mark
68 Westy
99 Eurovan
05 NBC
06 Audi A3
Posted: Wed Nov 17, 2021 12:01 pm Post subject: Re: 2000 Eurovan Sunroof stuck open |
soissisc wrote: |
I can get you a picture. It was a bit stiff to push that in. |
@Soissisc
I found a big flat head and forced it in there. You were right... just stuck. Was able to get it turned and closed.
Thanks for the help! No picture required now. |
Posted: Wed Nov 17, 2021 12:14 pm Post subject: Re: 2000 Eurovan Sunroof stuck open |
cool. Yeah, I had to give it a little bump. _________________ Mark
68 Westy
99 Eurovan
05 NBC
06 Audi A3
Posted: Thu Nov 18, 2021 8:28 am Post subject: Re: 2000 Eurovan Sunroof stuck open |
Here is what the tool looks like. It lives in the cover over the motor. It takes a little bit of force to get it in the slot (this disengages the electric motor from the gear, I believe). You can then crank the sunroof open or closed by hand. Once you remove the tool, you need to jog the switch get the motor to engage with the gear again.
[/img]
It seems like you could use a large flat screwdriver that is about as wide or smaller than the tool. _________________ Mark
68 Westy
99 Eurovan
05 NBC
06 Audi A3
