Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Thu Nov 25, 2021 11:26 am Post subject: Re: Existing cam wanting to add 1.3 ratio rockers |
Should give you long valve train life, that cam normally is used with 1.4's _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
RCP Phx Samba Member
Joined: November 20, 2021 Posts: 496 Location: Phoenix,AZ
Posted: Fri Nov 26, 2021 6:59 pm Post subject: Re: Existing cam wanting to add 1.3 ratio rockers |
I got the engine tore down today and much to my surprise it was neither a 4062 or a 2339, it was a Engle W-110! |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sat Nov 27, 2021 4:09 pm Post subject: Re: Existing cam wanting to add 1.3 ratio rockers |
RCP Phx wrote: |
That cam with 1.1:1 rockers is .430" lift so with 1.3 rockers you will see .508" lift if they measure out correctly.
I did run rockers that measured out at 1.38 on my W-100 which came out at .526" lift and it worked quite well to 5800 rpm using the CB 650 outer springs and solid rocker shafts. I didn't notice much if any difference for the money spent.
People have spent more for less.......... _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Mon Dec 06, 2021 3:27 pm Post subject: Re: Existing cam wanting to add 1.3 ratio rockers |
I tried to start mocking up the heads/rockers, I thought I was in luck because I found a set of rockers shims I got with a rocker shim kit. They don't even fit with 8mm studs let alone 3/8" studs! |
