VW Bus 1972: Brake Lines sizes?
alexbeatle
alexbeatle is offline
PostPosted: Sat Nov 20, 2021 11:50 pm    Post subject: VW Bus 1972: Brake Lines sizes? Reply with quote
Hey, folks.
Is anybody familiar with the '72 VW bus brake lines?
Looking to confirm whether the lines are 3/16" and what style\size of fittings they have?
Going to work on replacing my master cylinder over the next few days...
Thanks in advance.
Abscate
Abscate is offline
PostPosted: Sun Nov 21, 2021 12:59 am    Post subject: Re: VW Bus 1972: Brake Lines sizes? Reply with quote
The right search term here is
“Brake line flare fitting”
With one such thread here
https://www.thesamba.com/vw/forum/viewtopic.php?t=674869&highlight=brake+flare+fittings
Short version is these cars use metric 10x1 bubble flare fittings , available at NAPA
Once some people add better info here , I’ll pm the mods go link this into the FAQ thread above
.ssS!
alexbeatle
PostPosted: Sun Nov 21, 2021 1:20 am    Post subject: Re: VW Bus 1972: Brake Lines sizes? Reply with quote
Thanks that is actually very helpful!
alexbeatle
PostPosted: Sun Nov 21, 2021 8:02 pm    Post subject: Re: VW Bus 1972: Brake Lines sizes? Reply with quote
Took down the master cylinder today. Confirmed M10-1 bubble flare lines.
alexbeatle
PostPosted: Tue Nov 30, 2021 5:30 pm    Post subject: Re: VW Bus 1972: Brake Lines sizes? Reply with quote
I'm trying to install a non-native brake booster and came down to an issue of needing adapters.
Anybody can suggest a good shop for these?
My booster uses M12-1 nuts and is meant for 1/4" inverted double flare brake lines.
The bus (as discovered) uses 3/16" bubble flare brake lines with M10-1 nuts.
To join the two I'd need to find reducers male 1/4" to female 3/16" with appropriate flares.
