Rear wheel play 12/6 no play 3/9 - bearing?
vanis13
vanis13 is offline
PostPosted: Tue Nov 23, 2021 7:16 pm    Post subject: Rear wheel play 12/6 no play 3/9 - bearing? Reply with quote
What's to check?
Read about the oval bearing housing from smacking on the nut what a 12-6 and a 3-9 caliper measurement confirm this?
tpinthepack
tpinthepack is offline
PostPosted: Wed Nov 24, 2021 4:42 am    Post subject: Re: Rear wheel play 12/6 no play 3/9 - bearing? Reply with quote
I would hope the bearing would be the weak part and wear first, well before the casting. I say you have to pull the bearings and do a measure with a nice caliper before installing new bearings. My guess is the outer bearing will be worn. I changed my bearings a few years back and had this exact issue and bearings fixed it for me. They are tricky to install, and there are many threads on how to do it. I have a huge 3/4" snap on torque wrench for the 46mm nut so I have no experience hitting the axle nut with a huge hammer and the empi tool.
Bearing housings are available now if you do have the worst case scenario. Good luck.
TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne
djkeev
djkeev is offline
PostPosted: Wed Nov 24, 2021 4:50 am    Post subject: Re: Rear wheel play 12/6 no play 3/9 - bearing? Reply with quote
Don't go smacking no nuts!
This was a low budget Beetle era cheap fix.
Bearings aren't cheap....... hitting them with heavy hammer blows damages them.
3/4” drive socket
3/4” Breaker bar
4’ of 2” galvanized pipe.
Loosens AND tightens all in one tool!
Dave
Ghia
Vanagon
Beetle
Abscate
Abscate is offline
PostPosted: Wed Nov 24, 2021 4:52 am    Post subject: Re: Rear wheel play 12/6 no play 3/9 - bearing? Reply with quote
You want a breaker bar to remove this, not a torque wrench
.ssS!
djkeev
djkeev is offline
PostPosted: Wed Nov 24, 2021 4:53 am    Post subject: Re: Rear wheel play 12/6 no play 3/9 - bearing? Reply with quote
Yep.
4’ of pipe to loosen.
Mark your weight on the bar.
Stand (not jump) on the mark to tighten.
One tool, does it all!
Dave
Ghia
Vanagon
Beetle
clift_d
clift_d is offline
PostPosted: Wed Nov 24, 2021 6:40 am    Post subject: Re: Rear wheel play 12/6 no play 3/9 - bearing? Reply with quote
What's to check?
If you can take it out for a drive and check the bearing play again when it's still warm, this will give you a better idea of their condition. The axle bearings on these vans are designated as C3 Clearance Bearings, which means that they have 'Greater Than Normal' clearance between the races than you'd find in a standard bearing, to account for thermal expansion as a result of the bearing getting hot through use. So, you should expect to see some play when the bearings are cold.
1988 LHD T25 1.6TD Westfalia Club Joker syncro
tpinthepack
PostPosted: Wed Nov 24, 2021 11:47 am    Post subject: Re: Rear wheel play 12/6 no play 3/9 - bearing? Reply with quote
I should have elaborated, I have the snap-on detachable head and I have the really long breaker bar attachment for removal, yes. I only torque during reassembly.
1990 Vanagon DOKA
1972 Super Beetle
vanis13
vanis13 is offline
PostPosted: Wed Nov 24, 2021 3:43 pm    Post subject: Re: Rear wheel play 12/6 no play 3/9 - bearing? Reply with quote
Yeah, but I'd expect even play all around when cold... What about the difference in 12/6 vs 3/9
djkeev
djkeev is offline
PostPosted: Wed Nov 24, 2021 3:47 pm    Post subject: Re: Rear wheel play 12/6 no play 3/9 - bearing? Reply with quote
Bearing carrier wear is possible.
They tend to wear vertically as they carry the load.
Dave
Ghia
Vanagon
Beetle
clift_d
clift_d is offline
PostPosted: Thu Nov 25, 2021 2:00 am    Post subject: Re: Rear wheel play 12/6 no play 3/9 - bearing? Reply with quote
Absolutely - I wouldn't rule that out, but a lot of owners, and a fair number of mechanics, don't realise that the bearings are designed to have some play in when cold, and so it's worth reiterating the need to check what they're like when warm before making a decision to replace.
vanis13
vanis13 is offline
PostPosted: Fri Nov 26, 2021 1:27 pm    Post subject: Re: Rear wheel play 12/6 no play 3/9 - bearing? Reply with quote
Dave
Ok, how do I test that and what ever else is testable? Is there a bearing/hub testing FAQ I missed? (I know there are many threads on bearings/hubs but none of them I remember having testing procedures.)
Got it off!
There was 12/6 play and 6/3 firmness with -
the wheel on
on the drum with the wheel off
with the drum off
on the axle stub with the spindle?/lug stud carrier
djkeev
djkeev is offline
PostPosted: Fri Nov 26, 2021 2:07 pm    Post subject: Re: Rear wheel play 12/6 no play 3/9 - bearing? Reply with quote
Pull the bearing and measure the bore
Ghia
Vanagon
Beetle
vanis13
vanis13 is offline
PostPosted: Fri Nov 26, 2021 2:32 pm    Post subject: Re: Rear wheel play 12/6 no play 3/9 - bearing? Reply with quote
"pull bearing" - inside or outside (or both)?
any tricks to keep alignment (12/6) on it coming out or just mark it some way?
djkeev
djkeev is offline
PostPosted: Fri Nov 26, 2021 2:47 pm    Post subject: Re: Rear wheel play 12/6 no play 3/9 - bearing? Reply with quote
Read some tips on these bearings. If you hope to reuse, treat them nice.
Don't go beating on them, or if you do, not on the wrong spots.
Many don't know that bearings are actually quite easily damaged.
Alignment in the housing is meaningless, though it would be interesting to see if the tops of the outer races are worn more than the sides.
Dave
Ghia
Vanagon
Beetle
