mikelars Samba Member
Joined: February 27, 2019 Posts: 238 Location: North Carolina
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1669 Location: Niagara Region, CANADA
Posted: Wed Nov 24, 2021 7:13 am Post subject: Re: Weber IDF - intermittent fuel leakage from both center/sides |
Could be the cover for the pump jet diaphragm. Possibly the cover is not flat or screws have loosened off. |
RandyV Samba Member
Joined: November 23, 2019 Posts: 357 Location: So Cal
Posted: Wed Nov 24, 2021 7:34 am Post subject: Re: Weber IDF - intermittent fuel leakage from both center/sides |
Ya, accelerator pump area could be culprit since it's happening on both sides. (Both diaphrams torn or loose would be odd though)
Another couple thoughts......
#1.) Use a mirror to view back there & see if you can duplicate by just revving the motor??
#2.) Use/borrow and old GoPro & mount it somewhere in there where you could drive under load to duplicate ?? (If it'll focus so close, the wide view should give you a good look)
Curious to find out what it is. |
Posted: Wed Nov 24, 2021 11:10 am Post subject: Re: Weber IDF - intermittent fuel leakage from both center/sides |
Could also be the inner throttle shaft area. No bushings or bearings there.
Are these Weber or HPMX? |
modok Samba Member
Posted: Wed Nov 24, 2021 11:27 am Post subject: Re: Weber IDF - intermittent fuel leakage from both center/sides |
Get that braided hose the heck away from your voltage regulator.
virusdoc Samba Member
Joined: August 13, 2018 Posts: 525 Location: Durham, NC, USA
Posted: Wed Nov 24, 2021 12:34 pm Post subject: Re: Weber IDF - intermittent fuel leakage from both center/sides |
What is your fuel pressure, and how recently did you measure it with a gauge?
My 40 IDFs were doing the same gas leak thing and my fuel pressure was over 6 psi, overpowering the needle valves and filling the bowls until fuel leaked out the top. I was also using a stock mechanical fuel pump, and I needed to add almost 1 mm of gasket underneath it to bring pressure down to a stable 3-3.5 psi. Make sure you are using the correct length pushrod and bakelite spacer--they are not all the same length. _________________ 1976 Convertible Super Beetle, "June Bug".
FI-->34PICT3 carb conversion-->now dual 40 IDFs
Self-rebuilt 1904 (after totally botching a 1641 rebuild, cussing a lot, and throwing lots of cash in the fire) |
74 Thing Samba Member
Posted: Wed Nov 24, 2021 1:22 pm Post subject: Re: Weber IDF - intermittent fuel leakage from both center/sides |
Tee in one of these and run it in your driveway and see what the pressure is and adjust accordingly:
https://harborfreight.com/fuel-pump-and-vacuum-tester-62637.html
Could be leaking from one of the screws as well if an o ring needs replacing.
You need to run it and see if you can feel where it is wet and fix it. |
Posted: Wed Nov 24, 2021 1:23 pm Post subject: Re: Weber IDF - intermittent fuel leakage from both center/sides |
mikelars wrote: |
virusdoc wrote: |
My 40 IDFs were doing the same gas leak thing and my fuel pressure was over 6 psi, overpowering the needle valves and filling the bowls until fuel leaked out the top. I was also using a stock mechanical fuel pump, and I needed to add almost 1 mm of gasket underneath it to bring pressure down to a stable 3-3.5 psi. Make sure you are using the correct length pushrod and bakelite spacer--they are not all the same length. |
I have never measured fuel pressure. What is the easiest way to do that? I could add gasket spacers as well - this is a generator style mechanical fuel pump. |
You need to verify fuel pressure with a gauge. Any inline fuel gauge will work, Harbor Freight sells a cheap one that is a combined fuel/vacuum gauge and I have found it to be fairly accurate when compared to other gauges. Essentially you T into the fuel line between the pump and before the T that goes to the carbs.
The generator style pumps are very sensitive to pushrod length. Less than a mm made the difference between 6.5 and 3.5 psi for mine. _________________ 1976 Convertible Super Beetle, "June Bug".
Posted: Thu Nov 25, 2021 6:53 am Post subject: Re: Weber IDF - intermittent fuel leakage from both center/sides |
mikelars wrote: |
Ok, I have ordered a pressure regulator I can put in right before the T in the fuel line, and a gauge so I can check the pressure. I am probably converting to an alternator anyway, so I would change out the pump at that point anyway.
So what is the ideal fuel pressure right before the T split out to dual carbs? Is it 2 lbs pressure or 3.5 lbs? |
3.5-4 psi max. The carbs will run OK as low as 2. Below that you may have issues keeping the bowls full under high load conditions. Above 4 you risk overwhelming the needle valves and running into bowl overfilling.
http://cbperformance.net/pdf/WeberInstallationGuide.pdf _________________ 1976 Convertible Super Beetle, "June Bug".
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Thu Nov 25, 2021 2:21 pm Post subject: Re: Weber IDF - intermittent fuel leakage from both center/sides |
No reason for more than 2.5psi.
Is she hard to re-start sometimes?
Acts flooded?
If so, then fuel pressure might well be the issue.
If it's just the accelerator pumps leaking, then it's time for a re-build kit and new pump diaphragms. They do fail and need replaced every so often. They are made of rubber and some kinds of fuel can eat them.
Water can corrode the center rivet as well and make them leak. |
Posted: Fri Nov 26, 2021 7:19 pm Post subject: Re: Weber IDF - intermittent fuel leakage from both center/sides |
Ohio Tom wrote: |
Acts flooded?
The webers are so new, that I doubt they have a failed diaphragm - also it would have been both simultaneously developing the exact same diaphragm failure - I think it is likely my fuel pressure is just too high. I bought an in line fuel pressure gauge as well as a pressure regulator and should be able to check it as soon as the fittings arrive… _________________ Here is my 1961 Beetle Restoration:
https://www.youtube.com/playlist?list=PLW_2wBCs4Ny2qXEPvdnfvEzN42T8JA8zO
Here is my 1966 Split Bus - Restoration Channel:
https://youtube.com/channel/UCPBRysmvrJlif2wzwEwiuwQ
2332 Torque Motor Build
https://youtube.com/playlist?list=PLW_2wBCs4Ny2HwsKM9QT4LFpcSqP3QG0p
Engine Rebuild 1968cc Playlist:
https://youtube.com/playlist?list=PLW_2wBCs4Ny1JbZ2EgJQQ2awfo0koZRqz |
