vince1 Samba Member
Joined: December 14, 2003 Posts: 823 Location: Burgundy, France
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Wed Nov 24, 2021 9:36 am Post subject: Re: A new Panchito 044 challenger ? |
Boy it would be nice to know what the port volume and flow numbers are. Someone is going to have to test for this. |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3291 Location: Rapid City, SD
Posted: Wed Nov 24, 2021 9:38 am Post subject: Re: A new Panchito 044 challenger ? |
I am ordering a set of 40x35, and I have some more as cast, and CNC panchito's on the way.
I will give them all a good measuring and then run them on the flow bench.
I am eager to see the port volume, and the average airspeed of these new ones.
Panchitos are tough to beat in the right application, but they could use some competition. Maybe I could talk Roy into sending me one of his 050 to test at the same time.
Brian _________________ www.type-emotorsports.com |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Wed Nov 24, 2021 9:42 am Post subject: Re: A new Panchito 044 challenger ? |
Brian_e wrote: |
Brian |
The only problem is if he sends you a hand selected head. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Nov 24, 2021 9:47 am Post subject: Re: A new Panchito 044 challenger ? |
Looks like a modified 501 casting. Bet the Panchito will be better, looks like they slapped on a bigger port. The undrilled 502 will also run hotter, the Panchito has better cooling air flow threw but this 502 head has more potential with more port meat for an even bigger port than is possible with the Panchito. |
Posted: Wed Nov 24, 2021 10:34 am Post subject: Re: A new Panchito 044 challenger ? |
Ya, It will be interesting to see what the rest of the port looks like. The shape at the flange doesn't really mean a whole lot compared to the rest of the port. I am betting typical AA valve job. Hopefully AA did some research and got some knowledgeable help when doing these. Huge improvements could be made with a clean slate AA500 head.
Or.....like the AA thickwall long 94's, they added material in one spot, and completely missed the boat in the important spots.
Let's hope they got closer.
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Wed Nov 24, 2021 11:29 am Post subject: Re: A new Panchito 044 challenger ? |
The autolinea panchito has massively Beefed up combustion chamber and skinny port walls.
This chinese head is the opposite.
Thickwall ports and thinwall chamber |
Posted: Wed Nov 24, 2021 11:59 am Post subject: Re: A new Panchito 044 challenger ? |
modok wrote: |
Similar to what I mentioned about the AA thick 94's.....
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15308 Location: Deep in the 405
Posted: Wed Nov 24, 2021 12:21 pm Post subject: Re: A new Panchito 044 challenger ? |
My concern isn't how well they flow or the HP they produce. My concern is how long they last. I'm sure lots of engine builders could port them and match the flow of the Panchito's. My question is how long before the seats drop out or the springs and valve guides need replaced. How do they hold up on a street engine after a 3 hr road trip. It may take 5 years of road testing before we know these questions. Just because a new product looks cool that doesn't mean it will out preform the competition. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
jpaull Samba Member
Joined: February 22, 2005 Posts: 3465 Location: Paradise, Ca
Posted: Wed Nov 24, 2021 2:03 pm Post subject: Re: A new Panchito 044 challenger ? |
vwracerdave wrote: |
My concern isn't how well they flow or the HP they produce. My concern is how long they last. I'm sure lots of engine builders could port them and match the flow of the Panchito's. My question is how long before the seats drop out or the springs and valve guides need replaced. How do they hold up on a street engine after a 3 hr road trip. It may take 5 years of road testing before we know these questions. Just because a new product looks cool that doesn't mean it will out preform the competition. |
Yes. But also, some things can be seen without needing that. For example, if the guideboss is cut centered, does the valve spring have a flat surface to rest on, or is it sitting on half and teeter toddering? Does the valve seat have full support or is there a big ledge under it giving only 50% support. The valve job can be seen easily just pulling the valves out too. If they pass all those checks, they can right away be a safer bet then some other brands. (Not reffering to cb). |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Wed Nov 24, 2021 2:18 pm Post subject: Re: A new Panchito 044 challenger ? |
My question is... the 500 and 501 have been around for a long enough time that we know the main issues with them, such as mediocre valve job and guides, plus they can really benifit from having extra cooling thru holes drilled in certain areas...
So, is this 502 simply a 501 with a different shape port cast in? Did they do ANYTHING else different with the casting or machining procedures/equipment?
If NOT that will answer a lot of questions. _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder )
Glenn Mr. 010
Posted: Wed Nov 24, 2021 2:23 pm Post subject: Re: A new Panchito 044 challenger ? |
evanfrucht wrote: |
If NOT that will answer a lot of questions. |
Ask the vendor.
Dario Ruiz <[email protected]> _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Nov 24, 2021 2:29 pm Post subject: Re: A new Panchito 044 challenger ? |
I have almost 20k miles in three years on the AA500 heads on a 2332cc in my baywindow. Every summer it goes on 2500 mile road trips in the middle of July. Did 104deg across the middle of Wyoming at 65mpg for hours again this year. Never been apart, and the valves have rarely needed any adjustment. I have built lots of load trip heads for buses using AA heads. I have 100% confidence in their durability at this point.
GMendoza Samba Member
Joined: November 15, 2007 Posts: 341 Location: Alta Loma, CA
Posted: Wed Nov 24, 2021 3:05 pm Post subject: Re: A new Panchito 044 challenger ? |
Those heads are a collaboration with AA and Brother's. A mold was taken from Brother's hand ported heads and these were the result.
If you are concerned about quality of the valve job, buy them from Brother's instead although they are a few bucks more since they do their own valve job.
I just built a 2180cc with these heads; very impressed. |
modok Samba Member
Posted: Wed Nov 24, 2021 5:58 pm Post subject: Re: A new Panchito 044 challenger ? |
I'm glad to hear good news about it. The more good heads we have the better.
Excessive material can always be removed easier than adding missing material! So they are going the right direction I think.
But it is the.... third? different head with the same 502 casting number....
or is it literally the same mold and they keep altering it. ?
They don't understand the function of a casting number. |
Posted: Wed Nov 24, 2021 6:32 pm Post subject: Re: A new Panchito 044 challenger ? |
The 500 and 501 are similar but the 501 actually is a different casting on the exterior. They added material around the ports on the 501 since the 500 only allowed so much port volume without welding. This 502 looks like they didn't change anything except for the inside of the ports, compared to the 501. I guess to be fair they are all cast a little different, so therefore do perhaps deserve their own casting numbers.
Honestly I like the AA casting quality. My main gripe Is the fact that the valve guides are not great and that the valve job could be a little bit more precise out of the box... _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3817 Location: Georgia
Posted: Wed Nov 24, 2021 7:10 pm Post subject: Re: A new Panchito 044 challenger ? |
Where are AA’s coming from? _________________ Volkswagen!
(Compression 8.7:1) |
RandyV Samba Member
Joined: November 23, 2019 Posts: 357 Location: So Cal
Posted: Wed Nov 24, 2021 7:59 pm Post subject: Re: A new Panchito 044 challenger ? |
GMendoza wrote: |
modok Samba Member
Posted: Thu Nov 25, 2021 12:59 am Post subject: Re: A new Panchito 044 challenger ? |
evanfrucht wrote: |
No I mean this is the third? version of the 502 casting.
From the cylinder head sticky, 2016 page three:
502 No longer in production. 40x35, 14mm short plug, heart chamber, solid chamber, 3 full fins.
[/quote] |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Thu Nov 25, 2021 12:43 pm Post subject: Re: A new Panchito 044 challenger ? |
The entire advantage that sets the Panchitos apart imo is the openness of the casting for cooling. Like Dave mentioned, any head porter can port a small head to flow as well as the off the shelf Panchito. If the casting they are using isn’t as efficient at cooling, what good is it? An 044 looses cooling efficiency to gain material for port volume. With the way Pat seems to be building turn keys, it seems like the Panchito is the perfect all around performance street head.
