Bugeye54487 Samba Member
Posted: Fri Nov 26, 2021 3:17 pm Post subject: Re: Beginning of a 78 convertible bug project |
busdaddy wrote: |
It ran off to Michigan https://www.thesamba.com/vw/classifieds/detail.php?id=2500742
There's others advertised too, as well as a semi complete system for spare parts, at $125 it's worth investing in IMO. https://www.thesamba.com/vw/classifieds/detail.php?id=2511924
Oddly your system is the 75/76 style (like the one in the ad), a 78 should have a mechanical EGR valve, and no TPS on the throttle body, slightly strange, but 49 state stuff got leftover parts even after the California models changed systems. It's possible it's stock, or it was swapped in during an engine transplant long ago, either system works fine, just be aware it's the earlier style. |
The engine has documentation and is all oem @ 32k miles. Will that make a difference on the tins? I want new tins and fan housing. Seems non for this model going by 1978 model year. 12/77 production. |
TromBug Samba Member
Joined: January 10, 2010 Posts: 179 Location: Southern Alberta, Canada
Posted: Fri Nov 26, 2021 3:45 pm Post subject: Re: Beginning of a 78 convertible bug project |
busdaddy wrote: |
Hey busdaddy, which part in the EGR looks different? Would the mechanical valve you’re talking about replace the vacuum canister that the green cable hooks up to? Asking because my ‘78 seems to have the same setup as OP’s:
_________________ 1978 Super Beetle Convertible - 1776cc L-Jet injection |
Posted: Fri Nov 26, 2021 3:50 pm Post subject: Re: Beginning of a 78 convertable bug project |
While the engine is out, I’d suggest having the injectors sent out to a place that will rebuild and flow test/match them. I sent my stock Bosch injectors to be rebuilt and I got a whole report back on the flow rates of them and details of the rebuild. Was very impressed. If I can recall where I sent them I’ll post it!
I also opted to keep the factory tins on the engine as I’ve heard horror stories about the fitment of aftermarket tins. However, I took them to a powder coat shop first that sandblasted them and re-coated them. I did them in black again to absorb the most heat. I’ve never had an overheating issue so far, even on a cross-Canada trip loaded right up! _________________ 1978 Super Beetle Convertible - 1776cc L-Jet injection |
Posted: Fri Nov 26, 2021 10:00 pm Post subject: Re: Beginning of a 78 convertible bug project |
busdaddy wrote: |
I'd remove that exhaust and clean everything up, the flanges will need work, and some of the support brackets have cracks, a little extra time now will make future work much less traumatic. Pull all the tin for a cleaning and mouse eviction, maybe replace the flywheel seal as well since you don't know it's age. |
I have searched with no luck for support mounts! Might have to weld these up. |
Posted: Fri Nov 26, 2021 10:26 pm Post subject: Re: Beginning of a 78 convertible bug project |
Have these vacuum lines from a TDI project. You think I can use them on the beetle?
virusdoc Samba Member
Joined: August 13, 2018 Posts: 518 Location: Durham, NC, USA
Posted: Sat Nov 27, 2021 6:03 am Post subject: Re: Beginning of a 78 convertible bug project |
Bugeye54487 wrote: |
Those look like high quality silicone lines. If the ID is correct they should work, but they won't look "correct" if that matters to you. _________________ 1976 Convertible Super Beetle, "June Bug".
FI-->34PICT3 carb conversion-->now dual 40 IDFs
Self-rebuilt 1904 (after totally botching a 1641 rebuild, cussing a lot, and throwing lots of cash in the fire) |
Lost69Convertible Samba Member
Joined: July 29, 2020 Posts: 436 Location: Rhode Island
Posted: Sat Nov 27, 2021 8:25 am Post subject: Re: Beginning of a 78 convertible bug project |
If you want the “correct” stock look for vacuum hoses, I recommend BelMetric. I have links to the hose type, size, and clamps if you’re interested. _________________ 1956 Beetle Ragtop: My Father's car
1969 Beetle Convertible: My first car. I loved it, I lost it, and I never got over it.
1979 Super Beetle Convertible |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Nov 27, 2021 9:16 am Post subject: Re: Beginning of a 78 convertible bug project |
busdaddy wrote: |
Yeah, FI exhaust stuff is not available new, weld up the cracks, straighten the flanges, build up thin spots with weld and grind, or weld on replacements you make if they are really bad, mock it all up before the final deed though, everything has to line up.
Some of those pipes still have the insulating shells on them I see, nobody has proven the stuff inside them isn't asbestos, if you remove any of the shells use the appropriate precautions. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Nov 27, 2021 9:51 pm Post subject: Re: Beginning of a 78 convertible bug project |
How to remove this?
Seems to happen on most of them.
What is the technical name for this part? Goes to oil fill spout.
And finally thank you all for pushing me to look under tins.
I found this. Definitely a fire hazard.
EVfun Samba Member
Posted: Sat Nov 27, 2021 10:19 pm Post subject: Re: Beginning of a 78 convertible bug project |
busdaddy wrote: |
I'm pretty sure only the California spec cars got the mechanical EGR (and a catalytic converter.) I had the vacuum operated system on my 49-state version '79 when I got it.
The EGR, decel valve, and vacuum retard distributor aren't needed on the L-jet unless you have an inspection to pass. _________________
Wildthings wrote: |
Posted: Sun Nov 28, 2021 9:17 am Post subject: Re: Beginning of a 78 convertible bug project |
EVfun wrote: |
busdaddy wrote: |
The EGR, decel valve, and vacuum retard distributor aren't needed on the L-jet unless you have an inspection to pass. |
Could be, I have more experience with the bus system, it went mechanical EGR in 77 for all states.
You are correct about being able to delete some stuff, but don't throw anything away, rules could change in the future and it may come in handy. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9880 Location: Huntington Beach, CA
Posted: Sun Nov 28, 2021 12:30 pm Post subject: Re: Beginning of a 78 convertible bug project |
How to remove this?
Grind it flat to clean steel. Place a steel, non plated nut on top of it, centering the broken shaft with the new hole. Then break out the welder and weld the 2 together. While still red hot, take a hammer and hit it down a few times. Immediately take the appropriate sized socket and remove as normal.
EZ! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Sun Nov 28, 2021 1:01 pm Post subject: Re: Beginning of a 78 convertible bug project |
busdaddy wrote: |
EVfun wrote: |
busdaddy wrote: |
You are correct about being able to delete some stuff, but don't throw anything away, rules could change in the future and it may come in handy. |
Do I want to delete these items? Is there an advantage? Not sure where the car originated, but what you see is all stock guaranteed except the muffler. |
Posted: Sun Nov 28, 2021 1:23 pm Post subject: Re: Beginning of a 78 convertible bug project |
busdaddy wrote: |
EVfun wrote: |
busdaddy wrote: |
I wouldn't myself, EVfun had suggested it. They all play a part and work together in small ways, none of it robs power or economy, get everything working and set up correctly and it'll be an absolute joy to drive.
Send your distributor off to Bill now so it'll be done when it's time to put things back together: https://www.thesamba.com/vw/classifieds/detail.php?id=2235472 _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Nov 28, 2021 6:20 pm Post subject: Re: Beginning of a 78 convertible bug project |
Without the Decel valve, the engine will be rich and prone to backfires when you lift off the throttle. In addition to backfires, my engine ran rough when I lifted off the throttle (Decel valve disconnected)
When I reconnected my Decel valve, with Busdaddy’s help thank you, the engine decelerated smooth and the backfires stopped. _________________ 1956 Beetle Ragtop: My Father's car
Posted: Sun Nov 28, 2021 6:34 pm Post subject: Re: Beginning of a 78 convertible bug project |
busdaddy wrote: |
busdaddy wrote: |
Yeah, FI exhaust stuff is not available new, weld up the cracks, straighten the flanges, build up thin spots with weld and grind, or weld on replacements you make if they are really bad, mock it all up before the final deed though, everything has to line up. |
I ground and welded and ground and welded. Best I can do for amateur night! Lol
Posted: Mon Nov 29, 2021 1:43 am Post subject: Re: Beginning of a 78 convertible bug project |
Lost69Convertible wrote: |
When I reconnected my Decel valve, with Busdaddy’s help thank you, the engine decelerated smooth and the backfires stopped. |
+1 - I agree that the decel valve and the vacuum retard help the FI engine run nice and smooth on throttle lift, and the engine comes down to idle more nicely I find.
However, I did delete my EGR filter - I don't actually think my car even had one when I first got it come to think. I was lucky enough to source a NOS FI muffler when I rebuilt my engine, so I capped the EGR outlet/inlet on the bottom side of the engine by the exhaust, but kept all the EGR bits on the top side of the engine so it would be complete, and also reversible if I ever want to source and reinstall the EGR filter component. _________________ 1978 Super Beetle Convertible - 1776cc L-Jet injection |
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1417 Location: Westfield, MA.
Posted: Mon Nov 29, 2021 5:39 am Post subject: Re: Beginning of a 78 convertable bug project |
Maltboy! wrote: |
Kudos for keeping the FI system. It makes me sad when I see a butchered engine that got converted to carbs. The FI works good and makes the car more drivable when tuned and fully functional. |
Agreed 100 percent! It's an awesome, simple sytem. To the O.P. since the engine is out you've got it easy! Change every fuel line and vacuum hose...as well as the short hoses on the injectors!!! If the injectors have been sitting they may be stuck, it's a good time to have them rebuilt, and don't forget new injector seals. The L-Jetronic system won't tolerate any vacuum leaks. They won't run if a simple breather hose is left off the intake (I've seen this mistake with someone trying to bench run a new engine) Also as said above a new temp sensor #2 on the drivers side head is a good maintenance item, keep the old as an emergency spare if it still works. EDIT: I realized Busdaddy beat me to the advice! He's got grat advice as always!
Posted: Mon Nov 29, 2021 5:42 am Post subject: Re: Beginning of a 78 convertible bug project |
TromBug wrote: |
However, I did delete my EGR filter - I don't actually think my car even had one when I first got it come to think. I was lucky enough to source a NOS FI muffler when I rebuilt my engine, so I capped the EGR outlet/inlet on the bottom side of the engine by the exhaust, but kept all the EGR bits on the top side of the engine so it would be complete, and also reversible if I ever want to source and reinstall the EGR filter component. |
Decell valve yes, it's a good idea to keep it. The vacuum retard on the other hand...NO. The car will idle smoother without it. Also many of the canisters now the retard side is bad anyway. Also always double check your max advance at 3000+ RPM. It's way more important than the idle setting! |
Weezle Samba Member
Joined: February 07, 2014 Posts: 685 Location: ORLANDO
