GreenMachineVW Samba Member
Posted: Fri Nov 26, 2021 12:39 pm Post subject: Front end alignment in Seattle area |
I am in the process of rebuilding my front end on a 1983 air cooled Vanagon. I have all the parts stripped off the vehicle. The large parts have been powder coated, all rubber parts, bushings, ball joints, manual steering rack and fasteners replaced with new. When I put it all back together I will try and match the old parts as much as possible as far as positioning for the alignment. However, I will still certainly need a complete front end alignment and all the geometry adjusted.
Does anyone have any suggestions for a shop in the Seattle, or preferably Tacoma area that will give all the settings a once over and make adjustments as needed? A Vanagon specialist would be prefered, but I am open to any shop that will look at all the pieces involved.
Thanks in advance. |
Crankey Samba Member
Posted: Fri Nov 26, 2021 3:22 pm Post subject: Re: Front end alignment in Seattle area |
I went to Fosters frame and axel for my bushings and alignment, excellent shop.
I would also go to True Line on cap hill if it was closer.
I'd expect excellent work at either shop. I went to Fosters because they're very close to my work. |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Sat Nov 27, 2021 7:19 am Post subject: Re: Front end alignment in Seattle area |
Tru-line in Bellevue is my go to when I need to have it done right. They are not cheap but the best rarely is. |
Microbusdeluxe Samba Member
Joined: July 26, 2003 Posts: 980 Location: Bellingham, WA
Posted: Sat Nov 27, 2021 1:07 pm Post subject: Re: Front end alignment in Seattle area |
^^^^^What he said ^^^^^ Tru Line Bellevue _________________ '69 Squareback RIP
'65 21 window deluxe sold before the price spike, damn it.
'70 rhd bay now a taxi in South Sudan
'81 Westy sold
'89 hightop Westy Joker syncro 16" now with Bostig! |
Franklinstower Samba Member
Posted: Sat Nov 27, 2021 1:20 pm Post subject: Re: Front end alignment in Seattle area |
Omni in kirkland.
I have used both tru line and Omni. Both are good, wildly different in cost though, with tru line the more expensive.
Pat at omni also owns a vanagon (as does pete? At tru line) _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
do.dah Samba Member
Joined: August 27, 2015 Posts: 444 Location: Washington
Posted: Sun Nov 28, 2021 12:19 am Post subject: Re: Front end alignment in Seattle area |
Tru-line Bellevue. Yes, Pete' daily driver is a Vanagon. They do a total alignment, not an "alignment lite" like you get from most shops that say they do alignments. And, if you mention what all you did, Pete will put a wrench/check your work. More expensive,, but you get more. |
jimf909 Samba Member
Posted: Sun Nov 28, 2021 4:28 am Post subject: Re: Front end alignment in Seattle area |
Quote: |
Does anyone have any suggestions for a shop in the Seattle, or preferably Tacoma area... |
If Bellevue is too far out of your way (traffic, etc.) you may try calling Small Car in Fife to see if they'd recommend someone in the Tacoma area. _________________ - Jim
Abscate wrote: |
Posted: Mon Nov 29, 2021 7:17 pm Post subject: Re: Front end alignment in Seattle area |
Thank you all for your replies. That gives me what I need to make a few calls. Having Pete check my work sounds like a smart idea. |
rag63 Samba Member
Posted: Mon Nov 29, 2021 8:56 pm Post subject: Re: Front end alignment in Seattle area |
I took my ‘81 Van to a Les Schwab after doing a front end refresh. It was aligned right the first time.
Les Schwab is everywhere in the PNW.
In my experience, the guys that work in the alignment shop are good.
Cheers,
Dave |
do.dah Samba Member
Posted: Mon Nov 29, 2021 9:42 pm Post subject: Re: Front end alignment in Seattle area |
I'll use Les Schwab on vehicles that I FEEL are basically close to being in spec. But, they're not really capable of doing a true 4 wheel alignment, especially on an older vehicle like ours. Not to disparage Les Schwab, but, I feel they do an "alignment lite", "good enough, close enough, may be a wee bit outta called for specs, but you'll never notice" kinda deal. A shop that specializes in alignment, that will get all measurements into specs and adjust them to newer updated info, and check previous work,, priceless. |
VeeDubn Samba Member
Joined: May 31, 2019 Posts: 120 Location: Olympia, Washington
Posted: Fri Mar 08, 2024 2:54 pm Post subject: Re: Front end alignment in Seattle area |
I see these posts from 2021 recommending Tru-Line Bellevue for a front end alignment . . . still a preferred recommendation? Others? I am in Olympia, so would need to set the day aside, but willing to do so.
Thank you!
~ Judy |
Posted: Fri Mar 08, 2024 3:38 pm Post subject: Re: Front end alignment in Seattle area |
You would be well served to go over to the M-Shop in Kirkland. Pete, who used to work at Tru-Line, now works at the M-shop. He's a Syncro owner and is the absolute best alignment tech I know. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Fri Mar 08, 2024 4:00 pm Post subject: Re: Front end alignment in Seattle area |
Christopher Schimke wrote: |
You would be well served to go over to the M-Shop in Kirkland. Pete, who used to work at Tru-Line, now works at the M-shop. He's a Syncro owner and is the absolute best alignment tech I know. |
Thank you Chris! Exactly what I was looking for -
~ Judy |
