Fuel pump with regulator and dual carbs pictures
Chuck67
Chuck67 is offline
PostPosted: Sat Nov 27, 2021 11:15 am    Post subject: Fuel pump with regulator and dual carbs pictures Reply with quote
I'm in need of some design help.
In my ghia have dual 44's with a mechanical fuel pump and a holley pressure regulator.
I'm wanting to clean things up (sight wise) in the engine bay. I know there are many of you out there that have the same setup, or close. Could you post a picture of the set up to help me spur some fuel line routing ideas?
Thanks
QRP
QRP is offline
PostPosted: Sat Nov 27, 2021 11:42 am    Post subject: Re: Fuel pump with regulator and dual carbs pictures Reply with quote
Get a Carter style rotary pump and you won't need the regulator.
I run one line to connect both carbs and one line feeding from the left side carb.
BIGMIKEY
BIGMIKEY is offline
PostPosted: Sat Nov 27, 2021 12:34 pm    Post subject: Re: Fuel pump with regulator and dual carbs pictures Reply with quote
Delorto 36mm carbs in a 1973 Beetle. I ran the fuel line from the stock fuel pump to the regulator on the firewall. Single line out of one side of the regulator to the left carb, I put a fuel pressure gauge in the right regulator outlet. Then from the left carb I ran a line behind the shroud to the right carb. Dells have a inlet/outlet fitting that makes that possible.
Mike T
BIGMIKEY
Deserter Series 1 project.
https://www.thesamba.com/vw/forum/viewtopic.php?t=787047&highlight=
1973 Beetle Driver, Marina Blue.
Chuck67
Chuck67 is offline
PostPosted: Sat Nov 27, 2021 5:52 pm    Post subject: Re: Fuel pump with regulator and dual carbs pictures Reply with quote
Mike T
Thanks!!!
Chuck67
Chuck67 is offline
PostPosted: Sat Nov 27, 2021 5:53 pm    Post subject: Re: Fuel pump with regulator and dual carbs pictures Reply with quote
Thanks!!
evanfrucht
evanfrucht is offline
PostPosted: Sat Nov 27, 2021 6:34 pm    Post subject: Re: Fuel pump with regulator and dual carbs pictures Reply with quote
I made up my own hardline kit with a roll of nickel copper tube. I connected it all togther with short sections of braided fuel line. I just used simple push on connections. Works and looks good. I'll post up some pictures.
I also run a stock rebuild-able german pump and have no need for a regulator for my dual Dellorto 45's as it outputs the correct pressure as is.
1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder )
