busdaddy Samba Member
Joined: February 12, 2004 Posts: 51003 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Dec 02, 2021 12:38 pm Post subject: Re: Exhaust elbow, is it repairable? |
How about some pictures? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Norma Samba Member
Joined: September 26, 2020 Posts: 152 Location: Nor Cal
Posted: Thu Dec 02, 2021 2:51 pm Post subject: Re: Exhaust elbow, is it repairable? |
_________________ 1976
Injected 2.0 Bay Window
3rd owner of 12 years now! |
SGKent Samba Member
Posted: Thu Dec 02, 2021 2:52 pm Post subject: Re: Exhaust elbow, is it repairable? |
that is the decel valve _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Norma Samba Member
No electrical on it.
This engine was put in approximately 2002? _________________ 1976
SGKent Samba Member
Posted: Thu Dec 02, 2021 2:58 pm Post subject: Re: Exhaust elbow, is it repairable? |
I added an arrow over top of what looks like the egr tube. Your plenum has a micro switch on it so I am not sure whether it is an earlier 75-76 engine, or whether it is orphaned, or whether that is used with an automatic. 76 1/2 and later manual trans engines don't have the micro switch.
Norma Samba Member
Posted: Thu Dec 02, 2021 3:33 pm Post subject: Re: Exhaust elbow, is it repairable? |
Okay, I’ll check it!
Thank you! _________________ 1976
Norma Samba Member
Posted: Thu Dec 02, 2021 3:54 pm Post subject: Re: Exhaust elbow, is it repairable? |
The rod with the red marks looks as though it would line up with the EGR underneath.
It ends, well, I don’t know what that is. Looks as though it would maybe need a block or something if I remove it. _________________ 1976
SGKent Samba Member
Posted: Thu Dec 02, 2021 4:33 pm Post subject: Re: Exhaust elbow, is it repairable? |
that circle is the EGR. It goes to the metal shroud where it bolts. One the other side of the shroud there is the EGR filter that cools the inert exhaust gasses. Then the bottom of the filter bolts to the J-tube where your leak is. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
SGKent Samba Member
Posted: Thu Dec 02, 2021 4:38 pm Post subject: Re: Exhaust elbow, is it repairable? |
Norma Samba Member
Posted: Thu Dec 02, 2021 5:36 pm Post subject: Re: Exhaust elbow, is it repairable? |
Thank SGKent.
I am trying to locate the electric to the EGR. _________________ 1976
Posted: Thu Dec 02, 2021 6:00 pm Post subject: Re: Exhaust elbow, is it repairable? |
I sort of looks like your transplant engine may have a mechanical EGR, not the electric flying saucer. Follow that tube SGK circled and look for a small rectangle with a lever and rod that connects to the throttle arm. Like the thing in the top left of this pic (rod to throttle missing in pic):
Слава Україні! |
Norma Samba Member
Posted: Fri Dec 03, 2021 11:34 am Post subject: Re: Exhaust elbow, is it repairable? |
This is what mine looks like. _________________ 1976
Norma Samba Member
Posted: Fri Dec 03, 2021 11:35 am Post subject: Re: Exhaust elbow, is it repairable? |
But mine is disconnected. _________________ 1976
Norma Samba Member
Posted: Fri Dec 03, 2021 11:38 am Post subject: Re: Exhaust elbow, is it repairable? |
It’s always been disconnected.
I only tried to connect it when it wasn’t starting months back. _________________ 1976
Norma Samba Member
Posted: Fri Dec 03, 2021 11:40 am Post subject: Re: Exhaust elbow, is it repairable? |
I see nothing circled by SGK. _________________ 1976
Posted: Fri Dec 03, 2021 11:53 am Post subject: Re: Exhaust elbow, is it repairable? |
That's the EGR valve, disconnect the lever from the throttle end and leave it attached to the arm on the valve, secure it out of the way so it doesn't get caught in the throttle linkage. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Norma Samba Member
Posted: Fri Dec 03, 2021 4:10 pm Post subject: Re: Exhaust elbow, is it repairable? |
Okay, it has never been clipped on except when it wouldn’t start and thought the disconnect was the problem, thus this old pic.
Coolio!
So leave the EGR pipe below alone?
And block the elbow, will that make the putt putt stop? _________________ 1976
Posted: Fri Dec 03, 2021 4:59 pm Post subject: Re: Exhaust elbow, is it repairable? |
Yes, although as WT's suggested maybe plug the end of the dangling pipe too, just in case that EGR valve is leaking a little why risk sucking up some road dust?. The dangling end won't need any high heat or pressure proof sealing, a blob of silicone RTV, or some other goo will do. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
