jgallen Samba Member
Posted: Sun Nov 28, 2021 1:20 pm Post subject: Transmission refresh (ie what to do short of cracking the case) |
Hello All,
I am in the process of rebuilding a single cab and have the transaxle out of the bus on some stands but have no experience in refreshing a trans. Just spend 3 hours chipping and brushing the varnished dried oil off the case.
What I need is some advice on what to do to an unknown condition (bus was reportedly running 30 years ago apparently) trans while I have it out. I will be getting new mounts for it and installing a new starter bushing and boots but wonder if there is anything else I should be looking into.
Also what is the best way to deal with transmission and gear oil that has been sitting in an unused transaxle for at least 30 years. Just drain and add more? is there some sort of flush I should consider?
Thanks for the advice. |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 363 Location: Mississippi
Posted: Sun Nov 28, 2021 1:50 pm Post subject: Re: Transmission refresh (ie what to do short of cracking the case) |
I'd say depends on your budget and timing of how close you are to being ready to drive the truck. In other words while you might have the budget to send it out to someone to completely go through it including the reduction boxes and totally refurbish it, if you are a year or 5 from actually using it then that wouldn't be a good idea to me. Otherwise it's a completely unknown component I'd be inclined to service the obvious that I could see without a lot of disassembly, install it fill it with fresh gear oil use magnetic drain plugs and see what happens. If it operates ok then change the oil after minimal mileage, say like 20 or 50 miles and monitor further to gain confidence in what you have or don't have.
OR, perhaps after installing the transmission and engine you could drain the old gear oil out and create a solvent/oil mixture say gear oil and diesel fuel....the ratio is up to you...fill the transmission and reduction boxes with your mixture and run it through the gears with the wheels off and the truck on jack stands. A "no load" situation just spinning the drums. That might tell you if all the gears mate up and work but probably wouldn't tell you if it would pop out of gear once loaded and going down the road. Then after running it a bit on the jack stands drain your mix out and fill with just gear oil put the wheels on and go for a spin.
Good Luck! |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Sun Nov 28, 2021 7:04 pm Post subject: Re: Transmission refresh (ie what to do short of cracking the case) |
Are the brake drums on it? |
Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Posted: Sun Nov 28, 2021 9:33 pm Post subject: Re: Transmission refresh (ie what to do short of cracking the case) |
I call it "playing the transmission lottery"
You could have a nice shifting perfectly good transmission which doesn't make any weird noises. Or you could waste a perfectly good weekend. _________________ .
Wanted:
Khopkinsx Samba Member
Joined: September 24, 2006 Posts: 111 Location: Beaverton, OR
Posted: Sun Nov 28, 2021 11:37 pm Post subject: Re: Transmission refresh (ie what to do short of cracking the case) |
Strickly Foreign in Grants pass is only an hour away.
They could inspect if for you and put in new gaskets. No idea what they would charge.
It is worth your time to make the phone call and find out. _________________ 67 Westy
67 Pop Top Westy
62 SC
62 DC |
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Mon Nov 29, 2021 1:56 am Post subject: Re: Transmission refresh (ie what to do short of cracking the case) |
Lind wrote: |
You could have a nice shifting perfectly good transmission which doesn't make any weird noises. Or you could waste a perfectly good weekend. |
x2 on the transmission lottery. Same goes for unknown engines _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
Braukuche Samba Member
Posted: Mon Nov 29, 2021 8:43 am Post subject: Re: Transmission refresh (ie what to do short of cracking the case) |
Years ago I used to play the transmission lottery and usually won, but over the past three years I’ve replaced four transmissions. So now if it’s an unknown I just send them in, they are mostly all worn to hell at this point. If you have a reputable place close enough I’d send it in. Peace of mind is worth something too. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
