Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2610 Location: Phoenix AZ
Posted: Mon Nov 29, 2021 6:42 pm Post subject: Re: Flushing full flow system after bearing failure |
Not sure
No oil loss
Thinking a galley may have plugged up 🤷♂️ _________________ 58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S |
Posted: Mon Nov 29, 2021 6:54 pm Post subject: Re: Flushing full flow system after bearing failure |
Haven't so far
Sees a lot of highway use here in phx, 2 round trips to LA, usually loaded up for camping _________________ 58' pg/sg silo fridge westy
76 911S |
Posted: Mon Nov 29, 2021 8:47 pm Post subject: Re: Flushing full flow system after bearing failure |
Freshly built, new lines, cooler, etc
Yeah I'm working on trying to figure figure out what went south _________________ 58' pg/sg silo fridge westy
76 911S
Last edited by sub-hatchtim on Mon Nov 29, 2021 10:34 pm; edited 1 time in total |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3292 Location: Rapid City, SD
Posted: Mon Nov 29, 2021 10:09 pm Post subject: Re: Flushing full flow system after bearing failure |
Cut apart the oil filter and see what is inside of it.
I would also ask what kind of assembly lube he used. That nasty white lithium assembly grease hardens up pretty quick and can make a mess of oil passages.
What kind of pre-oil procedure did you use? Was it cranked lots without pressure before starting?
It does look like some of the oil galleys in the case were opened up some for bearing alignment. That is a good thing.
Does your crank have a straight hole for the oil galley on the main journals, or does it have the long slot/groove?
Just a few things to check.
Brian _________________ www.type-emotorsports.com |
Posted: Mon Nov 29, 2021 10:32 pm Post subject: Re: Flushing full flow system after bearing failure |
Cut open filter, didn't see anything alarming
I bypassed the full flow for break in using comp cam breaking oil
Cranked until the light came on, let it sit until the light went off, cracked until the light came on "did this a few times" then hooked up the coil and proceeded to do the cam break in procedure.
Long slotted hole in crank _________________ 58' pg/sg silo fridge westy
76 911S |
jimmyhoffa Samba Member
Joined: February 16, 2014 Posts: 1058 Location: St. Louis
Posted: Tue Nov 30, 2021 6:36 am Post subject: Re: Flushing full flow system after bearing failure |
Yeah... this is weird... long scalloped oil holes in the center main journal, plus the late external groove bearing is a known safe / "VW approved" combination. Gives 1 & 4 rods oil through a majority of crank rotation, with a short "no oiling" period that shouldn't be an issue. Something else is up. _________________ 1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous. |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Tue Nov 30, 2021 7:07 am Post subject: Re: Flushing full flow system after bearing failure |
If not a failure caused by contaminated oil, then one would assume lack of oil. Those 2 rods would be the first to give out as they share a supply. Perhaps a relief valve stuck open, or oil pump gear spinning on the shaft? _________________ modok wrote:
Posted: Tue Nov 30, 2021 7:31 am Post subject: Re: Flushing full flow system after bearing failure |
I made sure to check the relief plungers on tear down
They slid nice and smooth _________________ 58' pg/sg silo fridge westy
76 911S |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Tue Nov 30, 2021 10:42 am Post subject: Re: Flushing full flow system after bearing failure |
I think you have a combination of 3-4 bad things.
Most likely the extra cranking with not enough, or the wrong kind of assembly lube ran the bearings dry, then they scored once it was running.
I NEVER crank for oil pressure. Always use a pressurized oil primer, or a modified oil pump cover. And back feed the oil pup to prime it. Then you know 100% you have oil pressure, long before the engine is even turned over.
Can you ask your engine builder what the oil clearances were on those rods?
Had the engine sat for a while since it was assembled?
The no filter on the engine at startup didn't help either.
Posted: Tue Nov 30, 2021 12:02 pm Post subject: Re: Flushing full flow system after bearing failure |
Max Welton wrote: |
I'm looking at your photos. What the h3ll is that in the grove?
Max |
That's case sealant _________________ 58' pg/sg silo fridge westy
76 911S |
Posted: Tue Nov 30, 2021 12:05 pm Post subject: Re: Flushing full flow system after bearing failure |
Brian_e wrote: |
Brian |
The engine was installed and fired up with in days of assembly
But I work out of town for months at a time
This last trip was 9 months so the bus sat for that entire time _________________ 58' pg/sg silo fridge westy
76 911S |
Posted: Tue Nov 30, 2021 6:53 pm Post subject: Re: Flushing full flow system after bearing failure |
Max Welton wrote: |
Also ...
sub-hatchtim wrote: |
I bypassed the full flow for break in using comp cam breaking oil |
This also bypassed the filters opportunity to catch any swarf left over from the assembly process.
Max |
I should have phrased that better
The filter was in play, I bypassed the accessory oil cooler _________________ 58' pg/sg silo fridge westy
76 911S |
Posted: Thu Dec 02, 2021 1:45 pm Post subject: Re: Flushing full flow system after bearing failure |
Found the culprit
Oil pump failure, the gear spins on the shaft with low resistance _________________ 58' pg/sg silo fridge westy
76 911S |
