sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2610 Location: Phoenix AZ
Posted: Thu Dec 02, 2021 2:21 pm Post subject: Re: Flushing full flow system after bearing failure |
Now what do I do if anything about some kind of warranty
It's not the engine builders fault the pump failed
I find it highly unlikely that schadek is going to do anything
I'm probably SOL with expecting anything to go my way in that regard _________________ 58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Thu Dec 02, 2021 3:19 pm Post subject: Re: Flushing full flow system after bearing failure |
76 911S |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3228 Location: Rapid City, SD
Posted: Thu Dec 02, 2021 3:24 pm Post subject: Re: Flushing full flow system after bearing failure |
For a brand new pump, that had a lot of shit go through it.
Not sure it was mentioned before, but what weight oil? Was it really cold outside when you drove it?
Can you post a picture of the end of the drive gear where the shaft is pressed in? The end opposite the drive tang. Just wondering if he pressed it out a ways to fit the cam face better.
Do you really need a 30mm pump?
Brian _________________ www.type-emotorsports.com |
esde Samba Member
Joined: October 20, 2007 Posts: 5927 Location: central rust belt
Posted: Thu Dec 02, 2021 5:56 pm Post subject: Re: Flushing full flow system after bearing failure |
So, did the gear spin on the shaft because it was loose to begin with, or because the pump gears were bound up trying to force some grit through the pump?
Is there any trace of whatever chunks caused that damage inside the hose between the pump and the filter? I'm curious as to what it is _________________ modok wrote:
Posted: Thu Dec 02, 2021 6:02 pm Post subject: Re: Flushing full flow system after bearing failure |
20/50 vr1
Not too many cold days here in phx
Just shiny specs "bearing material "
Motor build chose pump size
76 911S |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3987 Location: Antioch, California, a block from the hood
Posted: Thu Dec 02, 2021 6:27 pm Post subject: Re: Flushing full flow system after bearing failure |
The case had not been blasted _________________ 58' pg/sg silo fridge westy
76 911S |
Posted: Thu Dec 02, 2021 6:48 pm Post subject: Re: Flushing full flow system after bearing failure |
Or the case just wasn't clean enough to begin with. Swarf in the passages. Could have weakened the pump at that time and just took a while to let go.
Tempting to say the pump failure killed the bearings. But if the pump failure killed the bearings, the bearing debris could not have killed the pump. But debris from some other source could have killed the pump.
So yeah, possible some junk hid in the engine somewhere and it took 6k miles to get loose. Possible.
I question how good a job your builder did. Your pump damage wasn't caused by the bearing debris.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
