'59 rebuilt 36hp idle very high
Sham
Sham is offline
PostPosted: Tue Nov 30, 2021 8:21 am    Post subject: '59 rebuilt 36hp idle very high Reply with quote
Hello guys,
So, I have fully rebuilt my 36hp (details here : http://shamwerks.com/Beetle-page-2), and it runs great - well, I had a bit of a misadventure due to a fuel pump spring breaking the lever, but that's been fixed be putting back the original spring.
Anyway.
My issue is that I have a pretty high RPM idle, like 1500 rpm. I'm trying to bring it down, sprayed some brake cleaner squirts at the base of the manifold chasing air leaks (there was none), checked that the cable wasn't pulling on the throttle, same for the choke, checked that the butterfly properly closes... And I still fail to bring down the idle RPM.
The 28PCI has been fully rebuilt ; before the engine rebuild it idled fine at around 500-600RPM .
Would you have ideas to help me lower the idle RPMs? Thank you!
ShamWerks.com
Lingwendil
Lingwendil is offline
PostPosted: Tue Nov 30, 2021 1:08 pm    Post subject: Re: '59 rebuilt 36hp idle very high Reply with quote
If you screw the adjuster in does the butterfly close before the engine begins to stall? Or start running funky?
73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087!
my59
my59 is offline
PostPosted: Tue Nov 30, 2021 3:11 pm    Post subject: Re: '59 rebuilt 36hp idle very high Reply with quote
Have you made sure the accelerator and choke cable are routed correctly and have been lubricated in their housings?
my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '95 Benz E300D, 77 Benz 300D, '47 Willys Jeep
mukluk
mukluk is offline
PostPosted: Tue Nov 30, 2021 3:17 pm    Post subject: Re: '59 rebuilt 36hp idle very high Reply with quote
Since the carburetor was fully disassembled for cleaning, I would try slightly loosening the nuts at either end of the throttle butterfly shaft where the linkages mount. If these are overtightened, they will cause the throttle shaft to stick and prevent full travel.
Sham
Sham is offline
PostPosted: Wed Dec 01, 2021 3:56 am    Post subject: Re: '59 rebuilt 36hp idle very high Reply with quote
You're talking about the adjuster screw on the butterfly lever itself?
I'll give it a try this week end and let you know how it behaves.
Yep, cables changed, greased, and properly routed (I had to redo it twice, got it wrong first try).
That's a pretty good idea, I'm going to check that, thanks!
Actually, I've just rewatched the video of the very first start of this engine a few months ago, and it looks like back then I could get to a reasonnable idle RPM :
Hmmm. Food for thoughts, I'll look into your inputs and let you know what I find out.
ShamWerks.com
Airstream65
Airstream65 is offline
PostPosted: Wed Dec 01, 2021 5:27 am    Post subject: Re: '59 rebuilt 36hp idle very high Reply with quote
First off, starting fluid should not be needed to start the car. Have you double checked the valve lash, points gap, and timing? Start from the beginning!
Sham
Sham is offline
PostPosted: Wed Dec 01, 2021 6:02 am    Post subject: Re: '59 rebuilt 36hp idle very high Reply with quote
Airstream65 : Starting fluid was used only this one time, as it was the very first start of the engine. Oil pressure had been primed before by running the starter motor but disconnecting the ignition. I wanted to ensure the very first sparks would start th engine.
As for points gap, valves, timing, yes, of course those had been adjusted before (and timing checked with a stroboscopic lamp after) this first start.
Obviously starting fluid isn't needed any longer, and the engine happily starts right when the key is turned.
ShamWerks.com
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Dec 01, 2021 11:38 am    Post subject: Re: '59 rebuilt 36hp idle very high Reply with quote
Many are not familiar with the somewhat picky throttle return spring/cone/washer arrangement of the early cars, and it often binds when not cleaned, deburred, straightened, and assembled correctly.
Erik G
Erik G is offline
PostPosted: Wed Dec 01, 2021 1:34 pm    Post subject: Re: '59 rebuilt 36hp idle very high Reply with quote
right. I would start by disconnecting the cable altogether and work backwards from there
KTPhil is offline
PostPosted: Wed Dec 01, 2021 1:50 pm    Post subject: Re: '59 rebuilt 36hp idle very high Reply with quote
A more far out possibility is that the heat riser has burned through to the intake manifold pipe and you are getting extra air through that path. Rare, but it's been reported here.
Yes, take the cable off completely to eliminate/confirm it's a contributor! Easy things first!
motofly196
motofly196 is offline
PostPosted: Thu Dec 02, 2021 12:10 am    Post subject: Re: '59 rebuilt 36hp idle very high Reply with quote
Check that your manifold to head nuts are tight too. Could of loosened up over a few heat/ cool down cycles.
Sham
Sham is offline
PostPosted: Thu Dec 02, 2021 1:40 am    Post subject: Re: '59 rebuilt 36hp idle very high Reply with quote
I've had that car for over 26 years now, I'm very familiar with the spring setup. But you're right, I'll take it off completely, give it another check, and see how disconnecting the cable affects the idle.
No, I think I can strike out that option. I've modified the manifold to shorten it (in the process of increasing compression ratio - details here), and doing so I've pressure tested it for leaks.
Good point. I have squirted brake fluid at the manifold bottom looking for leaks, but I'll check the nuts are tight too.
ShamWerks.com
KTPhil is offline
PostPosted: Thu Dec 02, 2021 10:11 am    Post subject: Re: '59 rebuilt 36hp idle very high Reply with quote
Another common source is NOT removing the old manifold sealing rings (easy to do since it gets squashed and looks like part of the head), and putting an "extra" one on when installing the manifold. You really have to look carefully at the inlet port to tell the difference!
motofly196
PostPosted: Thu Dec 02, 2021 10:18 am    Post subject: Re: '59 rebuilt 36hp idle very high Reply with quote
I was actually going to mention the same thing! But I didn't want to "mechanic shame" anybody Laughing Sometimes the crush washer on the intake can blend right in with the color of the head. You've gotta get a pick in there and lift up.
KTPhil is offline
PostPosted: Thu Dec 02, 2021 10:23 am    Post subject: Re: '59 rebuilt 36hp idle very high Reply with quote
Sounds like the OP has a thick skin and at least a few brain cells between the ears, so I wouldn't worry!
He's covered all the easy sources, so we need to think outside the box and consider rarer options, so keep 'em comin'!
Sham
Sham is offline
PostPosted: Mon Dec 06, 2021 7:43 am    Post subject: Re: '59 rebuilt 36hp idle very high Reply with quote
No worries about mechanic shaming, I'm not taking anything personally, and even though I've been into VWs for about 3 decades, I can will make dumb mistakes just like the next guy. Very Happy Very Happy Very Happy
Crush washer, you know what, since I bead blasted the heads I inspected them veeeeeeery closely. Yet, digging into my pictures library, I found one where... Well, I have the tiniest doubt now. Damn. One more thing to check, though I wouln't put that on top of the list as 1/ no RPM change when squirting brake fluid at the base of the manifold 2/ I did have a correct idle when I first started the engine.
Back to the workshop it is! Wink
ShamWerks.com
