k-weaver Samba Member
Joined: November 27, 2012 Posts: 69 Location: Santa Maria, CA
Posted: Tue Nov 30, 2021 10:20 am Post subject: Clutch keeps falling out of adjustment - Ideas? |
Here is the situation. Car has a daikin clutch disk and a Kennedy stage 1 PP. Car is primarily used for drag racing (nothing to crazy, does 9.15 in the 1/8th) and the occasional cars and coffee on the weekends.
Last season, after a pass down the strip the clutch didn't feel right. It had to much slop in the pedal. Tightened it up, worked good for another pass. Then it happened again. Tightened a second time, then when testing to ensure it was good, the adjuster (wing nut) snapped off. Chewed up the threads on the end of the cable. We quickly ran through the swap meet and found another cable. Swapped it out, and finished the day.
This season, we started to see the same behavior. Got everything adjusted at home, car was working great. Car lost in round 1 eliminations because we couldn't get it in second gear. Back at the pits, clutch is loose again.
So at this point there appears to be a larger issue somewhere. I haven't pulled the motor to inspect anything yet (other projects in the way). But I am curious if anyone has seen this before and can maybe help point me the right direction before I start pulling it apart.
Some details that may be helpful:
The bowden tube is in place. I haven't measured but has probably 1 - 1.5" of bend. The trans (type 1 swing) is solid mounted front/rear. Has mid mount with the poly pads under the horns. |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3292 Location: Rapid City, SD
Posted: Tue Nov 30, 2021 10:36 am Post subject: Re: Clutch keeps falling out of adjustment - Ideas? |
I had the exact same parts and the exact same thing happen in my baywindow. I havent pulled it apart yet either.
Then a week ago, another KEP S2 pressure plate, same thing happened in my shorty. Mine made a pop and now the pedal has no feeling. I made it back home without the clutch starting it in gear.
I pulled the engine out, and nothing looks out of the ordinary. Everything from the throw out forward is normal. None of the springs on the pressure plate are visibly broken.
I did test the pressure plate and some others in the press with a valve spring tester like Ohio Tom suggests. The S2 KEP had less PSI than a new AA pressure plate, but the 200psi gauge was right at max. I have a new 500psi tester on the way so I can test them again. I am wondering if the springs in the pressure plate are shot and it won't fully engage the clutch now..
Brian _________________ www.type-emotorsports.com |
KEGZ Samba Member
Joined: October 11, 2021 Posts: 288 Location: Whales Vagina
Posted: Tue Nov 30, 2021 10:39 am Post subject: Re: Clutch keeps falling out of adjustment - Ideas? |
Did you try a new wing nut with clean threads? I've used a barrel nut to lock my wing nut from backing out in the past. |
mukluk Samba Member
Posted: Tue Nov 30, 2021 11:25 am Post subject: Re: Clutch keeps falling out of adjustment - Ideas? |
Sounds like the clutch cable is stretching or has strands that are breaking. Remove the cable, measure its length, then compare that to the length of a new cable. _________________ 1960 Ragtop w/Semaphores "Inga" |
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Tue Nov 30, 2021 11:40 am Post subject: Re: Clutch keeps falling out of adjustment - Ideas? |
Clutch tube break free in the tunnel maybe? |
modok Samba Member
Joined: October 30, 2009 Posts: 26788 Location: Colorado Springs
The clutch pedal itself can start to come apart, if it's a late model stamped pedal set.
Has anyone managed to break early forged pedals yet? |
Posted: Tue Nov 30, 2021 12:12 pm Post subject: Re: Clutch keeps falling out of adjustment - Ideas? |
Both of mine are in buses, and everything all the way back to the throw out bearing is working good.
fastfil Samba Member
Joined: November 25, 2006 Posts: 356 Location: Sunshine Coast, AUS
Posted: Tue Nov 30, 2021 12:19 pm Post subject: Re: Clutch keeps falling out of adjustment - Ideas? |
Clutch tube in tunnel as buguy said... press clutch....pop.....adjust clutch back to normal....press clutch....pop....adjust clutch...
Not a fun repair. _________________ "...swingaxle...transaxle...same diff." |
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2610 Location: Phoenix AZ
Posted: Tue Nov 30, 2021 12:24 pm Post subject: Re: Clutch keeps falling out of adjustment - Ideas? |
Brian_e wrote: |
Brian |
Clutch tube at the front amd rear can break away from its mount _________________ 58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S |
Posted: Tue Nov 30, 2021 1:54 pm Post subject: Re: Clutch keeps falling out of adjustment - Ideas? |
sub-hatchtim wrote: |
Brian_e wrote: |
Brian |
Clutch tube at the front and rear can break away from its mount |
Checked them both on both buses. Nice and solid.
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7216 Location: Videbaek Denmark
Wreck Samba Member
Posted: Tue Nov 30, 2021 4:41 pm Post subject: Re: Clutch keeps falling out of adjustment - Ideas? |
Broken welds on the throw out arms ? |
Posted: Tue Nov 30, 2021 10:19 pm Post subject: Re: Clutch keeps falling out of adjustment - Ideas? |
Wow, thats a ton of good feedback! Let me address a few of the replies...
KEGZ wrote: |
When we swapped the cable the first time, a new wing nut was used.
mukluk wrote: |
Sounds like the clutch cable is stretching or has strands that are breaking. Remove the cable, measure its length, then compare that to the length of a new cable. |
This is for sure feasible. Something I was planning to check once I started digging in. Although I would hope not considering the cable is new with a handful of passes on the track and probably < 100 street miles.
buguy wrote: |
This is more than likely the culprit although I'm really hoping its not the case.
modok wrote: |
The clutch pedal itself is one of the "big boy" pedals. As can be seen here
https://www.thesamba.com/vw/classifieds/detail.php?id=1340666. Not to say this isn't a potential problem, something to investigate for sure.
Wreck wrote: |
Yeah, another area I was planning to check once the motor is pulled out.
Might be a bit before I get to the bottom of this but i'll post back what I find when I find it. Appreciate the replies guys. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Danny604 Samba Member
Joined: October 09, 2019 Posts: 89 Location: Port Coquitlam BC Canada
Posted: Wed Dec 01, 2021 9:38 am Post subject: Re: Clutch keeps falling out of adjustment - Ideas? |
I had a similar issue with my beetle when I first put it together. I mismatched the pressure plate and TO bearing. The pressure plate only had the fingers but no collar for the TO bearing to contact, it wore the end of the fingers and I had to constantly adjust it, until one day it failed. |
RWK Samba Member
Posted: Wed Dec 01, 2021 9:43 am Post subject: Re: Clutch keeps falling out of adjustment - Ideas? |
Frame horns can bend in drag racing, effecting the cable also. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Wed Dec 01, 2021 9:47 am Post subject: Re: Clutch keeps falling out of adjustment - Ideas? |
RWK wrote: |
Frame horns can bend in drag racing, effecting the cable also. |
Yes. I had a missing bolt in the nose cone mount. The trans-axle wasn't parallel to the frame horns and thus caused the clutch to pop and slip. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Slow 1200 Samba Member
Posted: Thu Dec 02, 2021 2:58 am Post subject: Re: Clutch keeps falling out of adjustment - Ideas? |
check that the bowden tube is not collapsing internally, it also shows the same symptoms when it happens |
Posted: Wed Feb 02, 2022 2:19 pm Post subject: Re: Clutch keeps falling out of adjustment - Ideas? |
Just wanted to follow up on this in case its useful to anyone in the future.
The clutch tube was broken off, under the rear seat. Welded this back up, problem persisted.
Pulled the motor and found the throw out bearing clip broke. The bearing was no longer centered on the PP. The PP is now junk, its dented and spring pressure is no longer even (its pulled in on one side).
I suspect the tube is the main culprit and everything else suffered as a result. We probably made matters worse scrambling at the track and tightening it up. In any case, new parts on order and should be back in business this weekend. |
