1950split Samba Member
Posted: Tue Nov 30, 2021 4:23 pm Post subject: Psi spring pressure conversion in kg |
Hi Guys,
I have a Proform valve spring pressure tester which is scaled in PSI and Kg/cm2.
Testing my Oteva 75 SC dual springs I find 100 PSI at installed height and 300 PSI at full lift. The equivalent in Kg/cm2 is 10 and 21.
I’d like to compare these value with the specs on Logmech’s website but the spring are rated in kg there.
How can PSI or Kg/cm2 be converted to Kg?
Thanks,
Phil |
modok Samba Member
Joined: October 30, 2009 Posts: 26778 Location: Colorado Springs
Posted: Tue Nov 30, 2021 5:28 pm Post subject: Re: Psi spring pressure conversion in kg |
The gauge reads hydraulic pressure.
I assume it is connected to a hydraulic cylinder
If the piston has an area of 1 square inch, then PSI scale reads pounds
If the piston has an area of 1 square CM, then it the kg/cm scale reads kilograms
It could be any other size too.
piston area X pressure=force.
Hopefully you can figure it out by measuring the hydraulic cylinder or reading the instructions.
That's the long answer.
Short answer is we assume the thing reads pounds, convert pounds to KG with google. |
Posted: Wed Dec 01, 2021 4:39 am Post subject: Re: Psi spring pressure conversion in kg |
Hi Modok,
This is the tool. Nothing sophisticated.
oprn Samba Member
Joined: November 13, 2016 Posts: 12708 Location: Western Canada
Posted: Wed Dec 01, 2021 4:58 am Post subject: Re: Psi spring pressure conversion in kg |
modok wrote: |
^^^This^^^
There is no such thing as a direct conversion from pressure units to weight units. Two different worlds. Like Modoc says you will have to measure that cylinder area and do the math. Maybe it is already done for you by the manufacturer of that unit?
Put a bathroom scale under it and put some weight on. If they both read the same you can ignore the PSI and read it directly as pounds. I used to work in a shop where we set up weight gauges for rigs. We measured the cylinders, chose a gauge bourdon tube and gauge face plate appropriate to the load expected. Then we calibrated the gauge so that it was a direct weight reading. We would scratch off the unit designation a write in the new one, kg, pounds, tons etc. Then we did up a calibration sheet for the regulatory bodies involved. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed Dec 01, 2021 8:06 am Post subject: Re: Psi spring pressure conversion in kg |
Not sure if this piece of software is any help, but I find it useful in many different situations....
https://joshmadison.com/convert-for-windows/ _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Wed Dec 01, 2021 7:31 pm Post subject: Re: Psi spring pressure conversion in kg |
The bore is exactly 1 square inch. So that a standard pressure gage PSI= Lbs force.
So convert using the PSI reading as Lbs and convert from there. |
modok Samba Member
Posted: Wed Dec 01, 2021 7:51 pm Post subject: Re: Psi spring pressure conversion in kg |
I was going to say....
Nice of them to save you a few $ by using a regular pressure gauge, instead of a custom face with the correct units.
But they DID spend enough money to get their logo on the gauge face
oprn Samba Member
Posted: Wed Dec 01, 2021 8:51 pm Post subject: Re: Psi spring pressure conversion in kg |
modok wrote: |
Posted: Thu Dec 02, 2021 1:36 am Post subject: Re: Psi spring pressure conversion in kg |
Thanks for your replies.
Thanks Tom, you are right => measured 300 LBS over the nose at 25.05mm = 136kg on my engine and on Logmech's site they rate the Oteva 75SC duals at 140kg @25.4 mm. |
