VeeDubb steppin Samba Member
Joined: August 16, 2015 Posts: 73 Location: weast of eden
Posted: Tue Nov 30, 2021 8:23 pm Post subject: 72 T2 Westy appliance options/floorplan/layout questions ? |
I'm working on a 1972 Westfalia camper ,I have a few dillemas/questions . 1.] much of the lettering has either been worn/rubbed off the little aluminum Westfalia badges on the passenger side below door .I'm assuming this would assist in I.D'ing this unit ? [can I get replacements/ is there alternative I.D locations ? ] 2.] I cant seem to find info on floor plan layout or appliance options or if there were different levels offered i.e did some come with waste holding tanks /location of propane tanks etc . In particular ,my bus has No propane tank , P.O had stove hooked to 1 lb bottle ,nor does it have a graywater tank ? Also , for the life of me I cant find info on what looks like a gas furnace to the very right most position behind drivers { RHD } side seat , It appears some components are AWOL,including the furnace cabinet ? front door ? I will try to get pix , but bus is in shop now... Did some have dual batteries etc,and the list goes on ...I really have a lot to learn about VDubz, and westies in particular ...Thanks in advance to all of you who share your knowledge ...! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51003 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Nov 30, 2021 11:19 pm Post subject: Re: 72 T2 Westy appliance options/floorplan/layout questions ? |
Thanks for the info , I am going to get the M code #'s and some pics ASAP , meanwhile I will check out the links you sent ... |
Posted: Wed Dec 01, 2021 12:24 am Post subject: Re: 72 T2 Westy appliance options/floorplan/layout questions ? |
Here are the " M " codes on 72 Bus
22 152 571
507 518
992651 A02 P31 027 172
13 4 7518 UF 2319 41
I started to decipher these ...still trying to get pix to I.D. furnace ? |
P24p1 Samba Member
Joined: August 20, 2020 Posts: 363 Location: Canada, Quebec
Posted: Wed Dec 01, 2021 8:01 am Post subject: Re: 72 T2 Westy appliance options/floorplan/layout questions ? |
I'm a little confused on your initial question, but I'm guessing you just want to know what the layout of your Westfalia is?
From your description of what you have, it doesn't sound original. A 72 Westy had no propane tank, no stove, and really only had a manual pump sink with an icebox, that's it. I second that pictures would help, since most likely you have a different interior fitted.
As for the M plate, here is a link to the website with all the info
http://www.vw-mplate.com/mcode.php?lang=EN&id=51020
But from what I see, you would've had the standard SO 70/2 interior, which you can google pictures of, or simply consult any listing for a 72 Bus
For example, this gorgeous yellow 72 has the same interior yours probably did.
https://www.thesamba.com/vw/classifieds/detail.php?id=2493995 _________________ 1973 Westfalia named Angie
What rust?
Rev it - don't lug it! |
Posted: Wed Dec 01, 2021 10:39 am Post subject: Re: 72 T2 Westy appliance options/floorplan/layout questions ? |
I understand it is a little confusing ...I was trying to find info on different camping packages that may have been available.I also really want to know what the heater looking unit on the right is and manufactured by whom so I can learn how it works . My bus has sink, fresh H 2 O tank , 2 stove top burners ? ,fridge/cooler ? and some sort of heater unit on the right of drawers/tank etc . right behind drivers seat [RHD ],looks like I'm missing the cabinet ? door . So the 72 never had propane tanks ? and No gray water holding tank ?? according to the way I decipher it the AO2,or P31 translated as a original camper setup ... I'm going to try and get pix asap .I haven't gone thru the interior thoroughly ,as I'm dealing with engine /body projects now .Thanks for the help ... |
Posted: Wed Dec 01, 2021 10:58 am Post subject: Re: 72 T2 Westy appliance options/floorplan/layout questions ? |
Thats a nice yellow bus...but no , mine is a 72 pop top Westy , all cabinets along Left hand side , full bed , power in/con/verter ? I need to send pix , but the more time I spend down the rabbit hole ,the less time I can wax on,wax off aka Waxxing off doesnt get my bus movin haha ... |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22403 Location: Escondido CA
Posted: Wed Dec 01, 2021 11:02 am Post subject: Re: 72 T2 Westy appliance options/floorplan/layout questions ? |
VeeDubb steppin wrote: |
You may not have a Westfalia, but some other brand? _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
P24p1 Samba Member
Posted: Wed Dec 01, 2021 11:24 am Post subject: Re: 72 T2 Westy appliance options/floorplan/layout questions ? |
AO2,or P31 translated as a original camper setup |
Yes, so the code P31 designates what's known as a SO 70/2 interior, which was the "model" of the interior and the only one offered as far as I know
Again, all signs seem to point to a conversion to a different interior
Based on your description, it really sounds like you have a late Westfalia interior, as in years 76 to 79, and someone fitted a heater to the spare tire cabinet behind the driver's seat. That's what I'm imagining at least _________________ 1973 Westfalia named Angie
What rust?
P24p1 Samba Member
Posted: Wed Dec 01, 2021 11:25 am Post subject: Re: 72 T2 Westy appliance options/floorplan/layout questions ? |
right behind drivers seat [RHD ] |
Also, it's a right hand drive car? _________________ 1973 Westfalia named Angie
What rust?
Posted: Wed Dec 01, 2021 11:27 am Post subject: Re: 72 T2 Westy appliance options/floorplan/layout questions ? |
P.O. rubbed Westy I.D. tag ,dunno If I will be able to deciper these .there are more westy tags inside , honestly I dont think this was a converted hack job...Vee Shall Zee Vee Dub ious deception ? |
Posted: Wed Dec 01, 2021 11:35 am Post subject: Re: 72 T2 Westy appliance options/floorplan/layout questions ? |
OOOPS ,Nix, Nien ,No,No , It's a left hand drive unit ,my apologies . Thats a spare tire well ? " Well raise Mah Rent " ! Perhaps some one has retrofitted later westy pieces in this unit ? doesnt look like it , but if the layout I have is not period correct ,well ...to be continued! |
P24p1 Samba Member
Posted: Wed Dec 01, 2021 11:47 am Post subject: Re: 72 T2 Westy appliance options/floorplan/layout questions ? |
Thats a spare tire well ? |
Not sure! We need pictures of the interior! _________________ 1973 Westfalia named Angie
What rust?
Posted: Wed Dec 01, 2021 11:53 am Post subject: Re: 72 T2 Westy appliance options/floorplan/layout questions ? |
X ray vision not working for me today. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Dec 01, 2021 8:10 pm Post subject: Re: 72 T2 Westy appliance options/floorplan/layout questions ? |
Okay , here's some pix ,apparently the area that is the spare tire cabinet ? has what appears to be a small camper propane heater W/ external vent . it looks like a decent setup , just not factory install. All the while I thought this was a Westfalia installed heater upgrade , behind what is actually just the spare tire cabinet [ my spare is on the nose ] . This bus has a type 4 engine modification , so now I'm not wondering if P.O. may not have removed some or ALL ? cabinetry from the donor of the same type 4 ? BTW , there are no engine codes on the type 4 engine ,it had a recent rebuild ...imagine that ...this must have been a top secret bus ! Furthermore if you look behind front seat back , It looks like there may have been a component mounted there , or are those marks just from a missing upholstery panel ...I dunno quite yet . I think what I do know due to the " M " codes it is a factory poptop westy of sorts ?If it has been retrofitted ,I actually kinda like it , it's very solid ,and I DON't care for the cabinets blocking the sliding door setup anyway ... We will see how it all plays out , I'm in the process of making things better ,and besides I have taken a real liking to these kool vehicles ... stay tuned
Posted: Wed Dec 01, 2021 10:09 pm Post subject: Re: 72 T2 Westy appliance options/floorplan/layout questions ? |
A US delivered 72 (like yours) would have come standard with a type 4, those cabinets are a hodge podge of 76+ items, except for that heater, that looks like an American truck camper or travel trailer part.
When it rolled off the boat it looked like the one P4P linked above inside, except yours had a pop top too. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Dec 01, 2021 11:31 pm Post subject: Re: 72 T2 Westy appliance options/floorplan/layout questions ? |
I agree Busdaddy , I actually kind of like it better the way it is . |
P24p1 Samba Member
Posted: Thu Dec 02, 2021 6:54 am Post subject: Re: 72 T2 Westy appliance options/floorplan/layout questions ? |
Yep, called it, spare tire cabinet and all
That heater looks sketchy as hell, I wonder if it has a brand name?
The glue on the back of the seat was for the upholstery, yeah
Otherwise, yea it's an late interior in an early bus, which is what I'm rocking right now and I love it! Way better then the original interior, more room I find and there's no cabinet blocking your right blind spot. Nice! _________________ 1973 Westfalia named Angie
What rust?
Posted: Thu Dec 02, 2021 8:12 am Post subject: Re: 72 T2 Westy appliance options/floorplan/layout questions ? |
Right P24p1 ! ...I like the cabinetry on the left side WAAAAY better, It looks like the bed and where the inverter is mounted may be original ? and the cabinets swapped ? The heater is externally vented ,kinda looks like one I had in a pop top trailer ...I WILL proceed with caution , but i kinda like the idea , and i think that is a ludicrous place for a ' Tahr ".. I'm going to add a collapsible gray water tank to keep it campground compliant , dunno what I will do for the propane , maybe just rig the 1 lb bottle setup ...
What do you think I should do for the " Stinkin Badges " n the pas. side outer ,below pass. door ? I would like to decipher and/or replace ...If possible . |
