Cv Joint Replacement Split Boot
HarryFD
HarryFD is offline
PostPosted: Wed Dec 01, 2021 3:48 pm    Post subject: Cv Joint Replacement Split Boot Reply with quote
Hi. I had a shock absorber bolt take a holiday and now have a torn CV boot. Can I simply remove the damaged boot and replace it with a split boot?
1970 Deluxe Sunroof Bay Brilliant Blue/Cloud White
1973.5 911 Targa
2009 MB C300
busdaddy
busdaddy is offline
PostPosted: Wed Dec 01, 2021 3:53 pm    Post subject: Re: Cv Joint Replacement Split Boot Reply with quote
Is there even such a thing for bay CV's?
Слава Україні!
aeromech
aeromech is offline
PostPosted: Wed Dec 01, 2021 3:55 pm    Post subject: Re: Cv Joint Replacement Split Boot Reply with quote
I’ve never heard of one but maybe some place like JC Whitney sold them
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
HarryFD
HarryFD is offline
PostPosted: Wed Dec 01, 2021 4:07 pm    Post subject: Re: Cv Joint Replacement Split Boot Reply with quote
The part looks like this:
1973.5 911 Targa
2009 MB C300
aeromech
aeromech is offline
PostPosted: Wed Dec 01, 2021 5:36 pm    Post subject: Re: Cv Joint Replacement Split Boot Reply with quote
There may be something available like that but I've worked on a ton of buses and never seen one in use. The early bugs used a similar boot for swing axle trannys
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
busdaddy
busdaddy is offline
PostPosted: Wed Dec 01, 2021 5:46 pm    Post subject: Re: Cv Joint Replacement Split Boot Reply with quote
Hmmm...., I've seen them for other cars, but not for a bus, never used one. Myself I wrap it in a baggie and zip tie it until I can take it apart and fix it properly.
Слава Україні!
sjbartnik
sjbartnik is offline
PostPosted: Wed Dec 01, 2021 7:24 pm    Post subject: Re: Cv Joint Replacement Split Boot Reply with quote
The whole reason for the existence of the split boot on swing axle cars is because it's a real fuckin job to replace the swing axle boot with a non-split one, I mean step 1 is take transmission out.
For a CV boot, it's easy, you pop the axle out, pop the joint off that end, put the new boot on, grease & go. It's messy but easy. Not worth doing a split boot in my opinion.
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
HarryFD
HarryFD is offline
PostPosted: Wed Dec 01, 2021 7:34 pm    Post subject: Re: Cv Joint Replacement Split Boot Reply with quote
If they were not repacked about 3000 miles ago, I might agree. FWIW, I have the repair boot on my shelf (it was planned for a car I no longer have). I am not going to repack the joint, just replace the single torn boot in place.
1973.5 911 Targa
2009 MB C300
HarryFD
HarryFD is offline
PostPosted: Wed Dec 01, 2021 7:36 pm    Post subject: Re: Cv Joint Replacement Split Boot Reply with quote
Right now it has a Duct Tape seal.
1973.5 911 Targa
2009 MB C300
sjbartnik
PostPosted: Wed Dec 01, 2021 8:21 pm    Post subject: Re: Cv Joint Replacement Split Boot Reply with quote
Yeah I don't think you would need to repack the joint (unless some foreign matter got in there through the torn boot), just pull it off the axle, put on new boot, reinstall joint and off you go.
2000 Kawasaki W650
airschooled
Air-Schooled
airschooled is offline
PostPosted: Wed Dec 01, 2021 8:50 pm    Post subject: Re: Cv Joint Replacement Split Boot Reply with quote
The split boots on swing-axle cars don't rotate. Asking one to rotate 800rpm on the highway is asking for trouble, in my opinion. Anyone know of an IRS-specific boot besides your old cut up skinny jeans?
Robbie
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
SGKent Premium Member
SGKent is offline
PostPosted: Wed Dec 01, 2021 9:22 pm    Post subject: Re: Cv Joint Replacement Split Boot Reply with quote
use Saran wrap or equal until you can replace it. If the CV's don't need repacking then doing one CV isn't all that bad.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
richparker
richparker is offline
PostPosted: Wed Dec 01, 2021 10:06 pm    Post subject: Re: Cv Joint Replacement Split Boot Reply with quote
Who pulls apart a CV and doesn’t repack it? This isn’t rocket science, it’s a CV and they are not hard to take apart and out back together. There are numerous VW specific videos on YouTube that show you how to do it.
The question you should be asking is, which boots are going to last the longest? Cause the boots out there are total shit and if you use the wrong one you’ll be replacing it in a few hundred miles. Personally I’ve had the best luck with EMPI boots, I’ve had them to 20k before. However I just removed my axles, tore down the CVs, removed my EMPI boots and cleaned everything including the hardware. It took my an hour and a half to do all that. I’m waiting for my new boots to arrive, I going with the OEM Tiguan boots (well they fit damn near every VW from ‘99 on). Part #1K0498201. The Vanagon crowd have given them good reviews and it seems like that is the best way to go.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
Cap10323
Cap10323 is offline
PostPosted: Wed Dec 01, 2021 10:23 pm    Post subject: Re: Cv Joint Replacement Split Boot Reply with quote
I've tried split boots before, the bolt together kind don't work very well. The grease leaks right out.
The solvent weld kind don't work too badly from what I've seen.
But I agree with the other posters. Just pull the joint off the end and install a new boot. It takes like 20 minutes.
-Ian
'77 Westfalia - 2.0 F.I
timvw7476
timvw7476 is offline
PostPosted: Thu Dec 02, 2021 4:49 pm    Post subject: Re: Cv Joint Replacement Split Boot Reply with quote
Me, it's 80 minutes to get an axle off, do boots (never pays to do just one Sad)
& get it all back in. So much clean up/prep work involved.
Also no way those split garbage boots are as cheap as decent quality ones.
HarryFD
HarryFD is offline
PostPosted: Thu Dec 09, 2021 1:10 pm    Post subject: Re: Cv Joint Replacement Split Boot Reply with quote
The split boot in my tool box was the wrong size. Ended up installing a new Lobro boot. Except for the fiddliness of removing/installing the CV bolts, not hard.
1973.5 911 Targa
2009 MB C300
richparker
PostPosted: Thu Dec 09, 2021 2:28 pm    Post subject: Re: Cv Joint Replacement Split Boot Reply with quote
I hope you took the extra time to clean and regrease the CVs why are you had it apart.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
