SCM Samba Member
Joined: January 26, 2011 Posts: 3116 Location: Bozeman MT
Posted: Wed Dec 01, 2021 4:19 pm Post subject: What would you do about this ATF leak? |
My rebuilt auto transaxle with under 10k miles is leaking ATF from the bellhousing. GTA suggested a few things that it might be and said, "your mechanic can help you out". I passed those suggestions on to my mechanic.
This mechanic is the same one that neglected to reinstall the throttle cable mount on the transaxle when they reinstalled the trans four years ago. He's now telling me, "the ATF level is good and the leak isn't that bad so I would just keep an eye on it".
Well, maybe the ATF level is good because I noticed the leak the very first day it appeared and only drove the van 10 miles further to clean it up, clear the breather vents, and confirm that it was still leaking.
I guess I'm not opposed to taking the van home and driving it some more just to make the leak more obvious but I don't want to risk anything catastrophic happening to the trans. Is there much chance of that?
On the other hand, I already waited a month just to get into the shop and with winter approaching and vacations in the future, I really won't be driving until spring.
Ugh. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32598 Location: Reading Pennsylvania
Posted: Wed Dec 01, 2021 4:45 pm Post subject: Re: What would you do about this ATF leak? |
Living with leaks is just stupid.
To be told by a mechanic to live with the oil leaks = a stupid incompetent mechanic!
In my 90 build thread I combated an ATF leak.
I sealed this, I sealed that, I resealed and sealed again.
What I discovered is something that defied logic.
You expect the air currents from forward motion to blow leaks to the rear.
I found that the leaks I THOUGHT were at the front of the oil pan to actually be coming from one of the 13mm hex nuts that hold the transmission to the transfer case!
I also had a leaking large Oring at that seam.
And I had ATF blowing out of the bell housing! Classic torque converter seal leakage which pissed me off because I installed the superior NAPA seal there.
I sealed up my leaks externally with great success. This isn't a technique I normally use but I do plan on rebuilding my spare auto trans and swapping them.
Anyway......... all these words to say that my leaking torque converter seal wasn't the seal at all!
It was the ATF from the large O ring being blown into the bell housing!
Once I sealed that Oring, everything dried up.
The leak presented as a TQ seal, but only seemed that way due to odd wind currents.
Ghia
Vanagon
Beetle
?Waldo? Samba Member
Posted: Wed Dec 01, 2021 5:26 pm Post subject: Re: What would you do about this ATF leak? |
Not everyone has the same priorities or resources. Living with a TC leak carries a certain amount of risk but calling it stupid seems a bit harsh, as is saying the mechanic is incompetent for suggesting it. Repairing a TC leak requires pulling either the engine or the trans, either of which is a lot of work/$ and the risk is actually quite small.
The main downsides to living with a leak are the mess it creates and the potential for the fluid level getting low and damaging the trans. Most often a leak does not dramatically change the rate of fluid loss but sometimes it does. If you check the fluid level routinely you are unlikely (but not guaranteed) to cause any additional damage. I would not personally choose to live with an ATF leak long term because of the mess it makes and the fact that the fluid will mix with dust and that thick coating will grow in the fins of the TC eventually hindering cooling. That typically takes a lot of time, though. |
dart330 Samba Member
Joined: July 19, 2004 Posts: 454 Location: Houston, TX
Posted: Wed Dec 01, 2021 5:58 pm Post subject: Re: What would you do about this ATF leak? |
I just went through the same thing. Shop overfilled the trans, TC seal blew on a brand new GTA rebuild. Made such a mess flinging ATF everywhere.
12 hours of shop time later the seal was replaced. But they overfilled it again, didn’t get it hot before checking. Glad I inspected it first thing when I got home. Got the extra fluid removed and has been dry ever since.
It’s definitely not worth living with the leak, but you can drive it without ruining the trans as long as you are willing to keep checking the ATF level (which is a pain). _________________ Driving a 90 Carat since 2014
Previous Buses: 59 Westy, 60 Westy, 74 Bus, 82 Westy, 85 Westy, 87 Syncro
Checkout my Syncro Video: https://www.youtube.com/watch?v=0JSWhLS7jLY |
oceanair Samba Member
Joined: June 09, 2013 Posts: 720 Location: Victoria, BC
Posted: Wed Dec 01, 2021 6:45 pm Post subject: Re: What would you do about this ATF leak? |
Living with ongoing leaks is also environmentally irresponsible. Fix that up. _________________ 84 Vanagon Pop Top Conversion from Tin Top, 1970 Ghia - all sweet rides! Love em!
Previous: Green 72 Tin Top, White 72 Westy, Blue 64 Beetle, Yellow 71 Squareback, 2014 Jetta TDI Wagon - wish I could have them all back! |
SCM Samba Member
Posted: Wed Dec 01, 2021 6:49 pm Post subject: Re: What would you do about this ATF leak? |
dart330 wrote: |
This could be the case here too. Luckily they quoted me only 5 hours to R&R the trans but I would hope they take the extra time to look for other issues once they’re inside.
I’m going to have them do the work and try to make it clear that I WANT to pay for them to take their time and get it right. Although I’m pessimistic since despite always having a handful of Vanagons, Porsches and other Euro cars on the lot, they have about a 70% success rate with my van - hence my “when there’s no more mechanics” thread (and why I also agree with Dave’s assessment). _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
