RCP Phx Samba Member
Joined: November 20, 2021 Posts: 496 Location: Phoenix,AZ
Posted: Wed Dec 01, 2021 5:55 pm Post subject: Opinions on Scat Big Bore pushrod tubes |
I might need something like this for my new build. Is anyone running them? |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Thu Dec 02, 2021 6:19 am Post subject: Re: Opinions on Scat Big Bore pushrod tubes |
I think I've used all the brands ,eventually they leak, ,,,stock don't leak _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Thu Dec 02, 2021 6:47 am Post subject: Re: Opinions on Scat Big Bore pushrod tubes |
I have always used the stock tubes, but I might not have a choice this time! |
Posted: Sat Dec 04, 2021 9:25 am Post subject: Re: Opinions on Scat Big Bore pushrod tubes |
What would be other options? |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Sat Dec 04, 2021 9:59 am Post subject: Re: Opinions on Scat Big Bore pushrod tubes |
Recommend Jaycee or FastFab |
stevemariott Samba Member
Joined: November 09, 2003 Posts: 1052 Location: Portland, OR
Posted: Sun Dec 05, 2021 11:17 am Post subject: Re: Opinions on Scat Big Bore pushrod tubes |
I bought a used set for $20 and they work great, no leaks. I've used the same set on a couple of different combos.
That being said, if I were to buy new, I'd probably buy the JayCee tubes.
RCP Phx wrote: |
_________________ 1963 Manx copy
1968 Bus |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Sun Dec 05, 2021 12:14 pm Post subject: Re: Opinions on Scat Big Bore pushrod tubes |
CB stock style wide mouth racing tubes in stainless steel are nice and one piece like original, plus they are windage style tubes with the extended end that fits in the case side. They also come in regular steel for cheaper. If you just need wide tubes, but don't want or care about them being the two part spring loaded ones which can be replaced with heads installed. Personally I think those are more trouble then they are worth unless you really need to replace some leaking ones on an assembled engine or something, or plan to want to replace them often? These single piece ones will NOT leak if installed properly.
https://www.cbperformance.com/product-p/1567.htm _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
richierich Samba Member
Posted: Sun Dec 05, 2021 1:33 pm Post subject: Re: Opinions on Scat Big Bore pushrod tubes |
Jaycee don't leak..if the person installing them is competent... _________________ Blah..... |
txoval Samba Member
Posted: Sun Dec 05, 2021 3:53 pm Post subject: Re: Opinions on Scat Big Bore pushrod tubes |
Agree and FastFabs are even nicer (better fabrication, same design)
Not a fan of the original style, my opinion
Yes I know they work
richierich wrote: |
Jaycee don't leak..if the person installing them is competent... |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
Posted: Sun Dec 05, 2021 4:49 pm Post subject: Re: Opinions on Scat Big Bore pushrod tubes |
Does anybody make a tool for installing the spring loaded variety? |
jbbugs Samba Member
Joined: September 16, 2002 Posts: 2152 Location: Behind the wheel
Posted: Sun Dec 05, 2021 5:42 pm Post subject: Re: Opinions on Scat Big Bore pushrod tubes |
chrisflstf wrote: |
Channel lock pliers _________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket! |
txoval Samba Member
Posted: Sun Dec 05, 2021 5:46 pm Post subject: Re: Opinions on Scat Big Bore pushrod tubes |
Just use your two hands…install the end at the case first, compress by hand and slide in…
https://m.youtube.com/watch?v=9u9DZD7VbWw |
