DanHoug Samba Member
Joined: December 05, 2016 Posts: 4800 Location: Bemidji, MN
Posted: Thu Dec 02, 2021 11:18 am Post subject: OE Vanagon heater core reseal |
after installing a new core, i've suffered poor heat output and have wanted to return to the extremely fine finned OEM core that has far better heat transfer. important for our winter temps in northern MN. so... lots of photos.
OEM core. notice the density of fins compared to replacement
replacement
header tank loosened by simply prying outward with a fine screwdriver and then using a Channel lock pliers to bend tabs a bit more. pretty darn easy.
inlet/outlet side opened. notice the 100% separation between the inlet hose and outlet ensuring 100% of flow thru core with no short circuiting.
i thought there'd be a sealant rope, or some sort of schmoo but it is just a plain rubber/buna endcap seal. this should respond really nicely to re-sealing.
crossover side of tank.
i'll clean the core up in a bath of citric acid, notice one tube is blocked, the rest look great, but the citric will also brighten up the exterior and remove some aluminum oxide. what to seal with? i'm thinking The Right Stuff because it gets harder than normal RTV and seems to bond tenaciously. open to suggestions. _________________ -dan
www.thefixitworkshop.com
bobhill8 Samba Member
Posted: Thu Dec 02, 2021 12:47 pm Post subject: Re: OEM Vanagon core reseal |
Good stuff _________________ 1986 Westy
1971 Squareback |
brickster Samba Member
Joined: January 05, 2004 Posts: 512 Location: CO, USA
Posted: Thu Dec 02, 2021 1:49 pm Post subject: Re: OEM Vanagon core reseal |
What do you want to seal? You said that it didn’t have one originally. |
Posted: Thu Dec 02, 2021 2:23 pm Post subject: Re: OEM Vanagon core reseal |
brickster wrote: |
the header tank to core was originally a crimp onto buna material. 35 years later, the rubber has compressed and lost some schproing elasticity and is going to need help keeping coolant contained. _________________ -dan
www.thefixitworkshop.com |
Posted: Thu Dec 02, 2021 2:36 pm Post subject: Re: OEM Vanagon core reseal |
DanHoug wrote: |
brickster wrote: |
the header tank to core was originally a crimp onto buna material. 35 years later, the rubber has compressed and lost some schproing elasticity and is going to need help keeping coolant contained. |
Understood. I would use a small amount of RTV silicone in the groove and crimp securely. You could use a toothpick to distribute it.
As a test once cured, you could pump air into it (<=15PSI) and see if the pressure drops. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Posted: Thu Dec 02, 2021 2:54 pm Post subject: Re: OEM Vanagon core reseal |
gonna test at 40 psi for 24 hrs... because that's just the kinda guy i am! <swagger mode off>
actually, there's a fella selling vanagon heater cores in the classifieds that he pressure tests at 40psi. so i know it can take it, and might as well stress it beyond anything the system would see.
was just reading on the The Right Stuff black vs gray. the black is more oil resistant and has greater flexibility so i'm going with the gray TRS because i don't need flexibility at all other than some thermal expansion and the harder gray should still accomodate that well.
things are setting (sitting?) in a hot citric acid bath now and cleaning up nicely. water turning dirty, soft nylon bristle brushing of fins releasing dirt. i'm doing a final cleanse in the dishwasher on a heated cycle with Cascade detergent. always brightens our aluminum cookware so it should do great for this. no toxic lead soldered seams to release brain numbing heavy metals so i'm good with it in the DW. it's had far worse in it. _________________ -dan
Posted: Thu Dec 02, 2021 3:01 pm Post subject: Re: OEM Vanagon core reseal |
djkeev wrote: |
I love LEXEL and was thinking this may be a good candidate, but its max use temperature is only 200°........ Boo
Dave |
TRS gray... 450F continuous!! _________________ -dan
Posted: Thu Dec 02, 2021 3:16 pm Post subject: Re: OEM Vanagon heater core reseal |
i was at NAPA filling my $.99 bag with 20% off and put some Permatex TRS in. wasn't until i got home and saw that it was gray vs black that i've used on heads. crap. both are rated at 450F continuous but the gray appears to be even harder than the black, which is harder than any other RTV i've used. so i THINK it is a good application in this case with very restricted movement yet high sealing needs.
about ready to throw everything in the DW. including the citric acid bath because we have have iron in our well water and the DW iron stains clean up nicely with a citric acid wash. it's all for Science. _________________ -dan
patrickgreen Samba Member
Joined: June 23, 2005 Posts: 37 Location: Put-inBay Ohio
Posted: Thu Dec 02, 2021 7:45 pm Post subject: Re: OEM Vanagon heater core reseal |
Not sure of its temperature rating but 3M 5200 is a flexible adhesive that has amazing bonding properties. Designed to be in and around water. |
khughes Samba Member
Joined: July 13, 2013 Posts: 747 Location: Phoenix AZ
Posted: Thu Dec 02, 2021 7:55 pm Post subject: Re: OEM Vanagon heater core reseal |
DanHoug wrote: |
about ready to throw everything in the DW. including the citric acid bath because we have have iron in our well water and the DW iron stains clean up nicely with a citric acid wash. it's all for Science. |
I used to use tons of this stuff (https://www.permatex.com/products/gasketing/gasket-makers/permatex-high-temp-red-rtv-silicone-gasket/?locale=en_us) to stabilize the pleats on HEPA filters in an oven running at 265C. Held up well at that temp for 6 months (our normal replacement interval). So temperature would be no issue. I haven't used it before for any liquid application, so no experience there, but since it's made as a gasket sealer, it should probably work well over the existing Buna. And increase the schroochiness... _________________ '86 Westy FAS GenV Turbo (Marvin) |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4026 Location: Redwood City, California
Posted: Thu Dec 02, 2021 8:08 pm Post subject: Re: OEM Vanagon heater core reseal |
Why did you replace the original ( OE ) original core, was the one you took out OE or OEM?
I've yet to see an original core leak.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Posted: Thu Dec 02, 2021 9:45 pm Post subject: Re: OEM Vanagon heater core reseal |
16CVs wrote: |
Stacy |
aaaand i've had 3 vanagons... all with leaky heater cores that smell of antifreeze when the heat valve is opened, an 85, 87, and 89. it's probably a geographic/climate thing where extreme cold (-40F) & system heat cause a discontinuity in the seal. _________________ -dan
Zeitgeist 13 Samba Member
Posted: Thu Dec 02, 2021 9:50 pm Post subject: Re: OEM Vanagon heater core reseal |
16CVs wrote: |
Stacy |
I've never seen a heater core leak on these, but they typically leak at the seam or the tanks crack. I can see welding on some aluminum tanks, but this plastic is prone to cracking due to the finite number of heat-cycles they can endure. Same with Audi and Mercedes.
Cool project, though. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Thu Dec 02, 2021 11:35 pm Post subject: Re: OEM Vanagon heater core reseal |
IF i were to attempt this i wouldn't be testing anything to 40 psi, it's a sure way to not only distort the core, but it's a fantastic way to have the plastic go off like a bomb if it's in a bad mood.
i have seen 7 year old heater cores go boom with 25 psi. coolant caps are designed to fail at what, 15-18 psi?
anyway, i wouldn't use any goo. i'd be making gaskets out of this:
https://www.mcmaster.com/high-temperature-rubber/f...nd-strips/
or find end tank gaskets for heater cores and radiators. they do exist _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
