Millionmph Samba Member
Posted: Thu Dec 02, 2021 4:45 pm Post subject: Dist mod |
Bought a new svda for another build, currently have a 009 pict 30 single port. Was out in the shed tidying up found a vacuum can for pict 30 setup...
Can't upload photos but got the bigger can on the svda. Anyone do this before? Will it work?
[/img] |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Thu Dec 02, 2021 5:01 pm Post subject: Re: Dist mod |
Which distributor is the can off of? If it's from a vacuum only it won't fit.
If you have a 30pict the the soda is not the best choice _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Dec 02, 2021 5:10 pm Post subject: Re: Dist mod |
I slotted the grooves for mounting screws, the arm was the same length as the can on the svda. Don't know what dist it came from, was just in box of parts. Figure throw it in and try it, run it, if it pings pull it. |
Glenn Mr. 010
Posted: Thu Dec 02, 2021 5:20 pm Post subject: Re: Dist mod |
You don't always hear pinging.
Watch you head and oil temps _________________ Glenn
Member #1009
#BlueSquare |
