chancer Samba Member
Joined: July 07, 2014 Posts: 127 Location: united states
Posted: Fri Dec 03, 2021 5:44 am Post subject: 70 autostick |
hi folks i have a 70 autostick that slams into gear was wondering how to adjust that i have the idle as low as possible |
bhartwell59 Samba Member
Joined: December 28, 2014 Posts: 792 Location: dallas, tx
Posted: Fri Dec 03, 2021 6:40 am Post subject: Re: 70 autostick |
Usually that's a control valve issue.
Just need to turn the top screw one way or the other until it shifts a little smoother.
Have a Bentley manual to tell you the procedure?
And try this site: http://vwar.org _________________ '74 Zambezi green Ghia vert, autostick, 101k
'87 Jeep Wrangler, 4.2, 330k |
Tom K. Samba Member
Joined: March 10, 2005 Posts: 1606 Location: Central Pennsylvania
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Fri Dec 03, 2021 9:02 am Post subject: Re: 70 autostick |
Tom K. wrote: |
Autosticks run at higher idles than manuals to maintain good vacuum pressure. Try turning up your idle.
Then, be sure your servo holds vacuum. Those diaphragms go bad. |
Adding to this. Check your vacuum hoses for cracks. The system is easily compromised by any vacuum leak(s). _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
volkenstein Samba Member
Joined: June 26, 2005 Posts: 858 Location: The Land of Oz
Posted: Sun Dec 05, 2021 6:50 pm Post subject: Re: 70 autostick |
Usually slamming into gear indicates that your carby set-up vacuum wise is incorrect. A 009 type distributor coupled with fitting the now disused vac advance line being connected direct to the CV. Or a manifold vacuum take off point being incorrectly used to feed the CV. The CV only needs 5 in/Hg vacuum to actuate.
If you can - post a pic of your engine bay fitting in carb/CV/Distributor.
HTH
Volkenstein _________________ 71 RHD AS Super - "Klaus"...
Wisdom of youth, energy of old age... |
sb001 Samba Member
Posted: Mon Dec 06, 2021 12:12 pm Post subject: Re: 70 autostick |
volkenstein wrote: |
HTH
Volkenstein |
My thoughts exactly. 10 to 1 the control valve vacuum line is connected to the wrong port on carb or intake.
Also agree with Tom's post above that the idle (when engine warmed up) needs to be around 950-1000RPMs. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Posted: Thu Jul 21, 2022 5:02 am Post subject: Re: 70 autostick |
Changed carburetor shifts good now |
