vwfye Samba Member
Posted: Fri Dec 03, 2021 2:00 pm Post subject: Can I jump this thing? I'm kidding... |
I just picked this up a couple weeks ago and tomorrow I go to see about getting a rear end for it. It did hold the class D national record back in '87 with an 1835cc engine. I will be trying to bring it back to life over time.
1980s...
Currently
_________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
BFB Samba Member
Posted: Fri Dec 03, 2021 6:35 pm Post subject: Re: Can I jump this thing? I'm kidding... |
daaaaang dats coo _________________ Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
“ The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" “ - bdkw1 |
PhillipM Samba Member
Posted: Sat Dec 04, 2021 6:35 am Post subject: Re: Can I jump this thing? I'm kidding... |
You can.
Once. |
vwfye Samba Member
Posted: Sat Dec 04, 2021 7:20 am Post subject: Re: Can I jump this thing? I'm kidding... |
PhillipM wrote: |
You can.
Once. |
vwfye Samba Member
Posted: Sat Dec 04, 2021 11:29 pm Post subject: Re: Can I jump this thing? I'm kidding... |
Mo parts! Live axle, intermediate housing, wheels, pedals...
Dale M. Samba Member
Posted: Sun Dec 05, 2021 10:57 am Post subject: Re: Can I jump this thing? I'm kidding... |
Many years ago (sort of pre monster truck era) local group sponsored mud bog runs.... Fellow had a VW rail very similar to one pictured here only difference was small wide tires on front, he wound it up dumped clutch and made it to end of pit in seconds, made the "big" trucks look really bad (as in terrible)....
Secret was he was so light and had enough power he just sort of skipped across top of mud.... _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
vwfye Samba Member
Posted: Sun Dec 05, 2021 7:54 pm Post subject: Re: Can I jump this thing? I'm kidding... |
I remember a vw hydraulically driven 4wd got outlawed for that and indoors it could flat out run, throw a lever and reverse the system to slam on the brakes. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sun Dec 05, 2021 10:02 pm Post subject: Re: Can I jump this thing? I'm kidding... |
Found out it was about 550lbs without driver _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Mon Dec 06, 2021 8:41 pm Post subject: Re: Can I jump this thing? I'm kidding... |
Disassemble...
vwfye Samba Member
Posted: Wed Dec 08, 2021 1:03 pm Post subject: Re: Can I jump this thing? I'm kidding... |
This live axle set up sat in a shop for years. The side cover bearings are locked up solid. So, that was the excuse to go through and clean/lube whatever can and needs to be. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Wed Dec 08, 2021 11:17 pm Post subject: Re: Can I jump this thing? I'm kidding... |
Everything for the live axle has been cleaned, emory clothed and made ready for assembly into the transaxle. As soon as my superbeetle mainshaft arrives, we will start to assemble. Woot! _________________ 64 No'back Speedster "Pearl"
pickuptrucker Samba Member
Posted: Thu Dec 09, 2021 7:34 am Post subject: Re: Can I jump this thing? I'm kidding... |
cool, Im curious to see how that lie axle fits into the car! |
vwfye Samba Member
Posted: Thu Dec 09, 2021 9:18 am Post subject: Re: Can I jump this thing? I'm kidding... |
it goes right through the transaxle and replaces swing/IRS axles. Everything else in the transaxle is the same. In the sand car, I will only be using 1st and second gear. When it moves over to the 1/8th or 1/4 mile, the other gears come into play. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Fri Dec 10, 2021 10:04 am Post subject: Re: Can I jump this thing? I'm kidding... |
This spacer will move the axle farther back. It is a nicely built magnesium piece that only adds 15.75lbs.
vwfye Samba Member
Posted: Mon Dec 13, 2021 10:47 am Post subject: Re: Can I jump this thing? I'm kidding... |
I found me some 'training' paddle tires for the 1st hits this summer. The scoops are 1/2 tall and shallow. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Wed Dec 15, 2021 10:31 am Post subject: Re: Can I jump this thing? I'm kidding... |
Photo history of the car...
vwfye Samba Member
Posted: Mon Dec 20, 2021 5:14 pm Post subject: Re: Can I jump this thing? I'm kidding... |
Finally got the front wheels off the spindles to get bearing numbers. Inner bearings are Anglia (no surprise) but the outers are Bantom. So... the search is on. _________________ 64 No'back Speedster "Pearl"
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17971 Location: Eugene, OR
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Mon Dec 27, 2021 6:19 pm Post subject: Re: Can I jump this thing? I'm kidding... |
550 is what my old Digger weight
_________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
vwfye Samba Member
Posted: Mon Dec 27, 2021 6:21 pm Post subject: Re: Can I jump this thing? I'm kidding... |
Nice ride! _________________ 64 No'back Speedster "Pearl"
