chadwall1975 Samba Member
Posted: Fri Dec 03, 2021 9:26 pm Post subject: What is this ? |
Here's my 1973 VW Super Beetle. if you will look in the top right corner next to the hinge, it is some type of relay. What is it? It has 5 prongs on it. I've looked at the wiring diagram I don't see it on it. Help me out if you have any information on it.
_________________ Where is the horn located on a 73 Super Beetle? |
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Fri Dec 03, 2021 11:17 pm Post subject: Re: What is this ? |
That relay- does it have black markings/schematic on it such as a factory-style unit? Do the wires connected to it have the blue plastic collars at the spade terminals such as the unconnected ones in the foreground? That relay area is dark so it's not visible in the photo. If so, such collars and spade terminals indicate aftermarket/post-dealer work so that the relay "could" be a regular "work" relay with 2 equal outputs (both have terminal numbers 87) such as used for a pair of driving or fog lamps. Such relays have 3 terminals for input, and usually 1 for output but certain types can also have 2 for output (terminal numbers 87 and 87a for a switching-type use; called a "change-over" relay).
Factory-installed horns are usually located in the left (driver's side) wheelwell towards the front of the car; mounted on a bracket that is on the body or bumper bracket. Here's one on a '71 Super Beetle (tthoms gallery)-
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sat Dec 04, 2021 12:02 am Post subject: Re: What is this ? |
The square one? I'd guess flasher relay. But just see where the wires go. |
busdaddy Samba Member
Posted: Sat Dec 04, 2021 8:51 am Post subject: Re: What is this ? |
Any holes in the body where A/C lines would have passed through? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Sat Dec 04, 2021 12:15 pm Post subject: Re: What is this ? |
Looks like the headlight toggle relay. What are the terminals labeled as? _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
