ForestVW Samba Member
Joined: September 08, 2018 Posts: 24 Location: Florida
Posted: Sat Dec 04, 2021 7:37 am Post subject: engine stumbles and coughs |
My 1600 engine in my buggy will cough and stumble when I shift from 1st to 2nd and 3rd when giving it gas then will pick right up and run fine------
The engine 1600 new long block
new 34 pict -3
new pertronix vacuum advance
bosh blue coil
new plug wires and bosh plugs
Timing set at 5 ATDC
As of now it starts right up idles fine - revs up fine no hesitation or cough --put it in 1st take right off just fine put it in 2nd get cough stumble then takes off fine same for 3rd and 4th----oh yes I put the larger jets in, that came with the carb
I would like to thank any input that anyone has on this. Harvey _________________ 1971 super
GTC Puma
VW Trike
VW Sand rail |
Dale M. Samba Member
Posted: Sat Dec 04, 2021 7:48 am Post subject: Re: engine stumbles and coughs |
Try setting timing statically at 7.5° BTDC...
Or try setting timing at about 28° to 32° BTDC at about 3000 RPM with strobe light and forget about static timing or idle timing...
Do you have any numbers on how much advance distributor has (centrifugal + vacuum total advance)... _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Posted: Sat Dec 04, 2021 12:12 pm Post subject: Re: engine stumbles and coughs |
Just cked total advance and it is 28 degrees at 3000 rpm--set at 5 atdc -----about a week ago had it set at 7.5 btdc and it ran like crap and was spitting out lots of unburnt fuel--I will try it again and see what happens-----Thank you _________________ 1971 super
GTC Puma
VW Trike
VW Sand rail |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 852 Location: South Florida
Posted: Sat Dec 04, 2021 4:35 pm Post subject: Re: engine stumbles and coughs |
ForestVW wrote: |
Just cked total advance and it is 28 degrees at 3000 rpm--set at 5 atdc ... |
My suggestion is to try for 30° at 3000 rpm, by setting static timing up a couple degrees; that'd put it at 3° atdc. (Right?) |
Posted: Sat Dec 04, 2021 7:48 pm Post subject: Re: engine stumbles and coughs |
That is odd because it would seem you distributor has something like 33° to 35° advance while most distributors only have about 19° to 27° advance _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
oprn Samba Member
Joined: November 13, 2016 Posts: 12744 Location: Western Canada
Posted: Sun Dec 05, 2021 6:22 pm Post subject: Re: engine stumbles and coughs |
Doesn't surprise me. Pertronics distributors are all over the map from what I could gather on this forum. Mine certainly was not as advertised! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
