1971 1700 bay window. What is line under bottom right air duct?
Newmanthetiedyebus
Newmanthetiedyebus is offline
PostPosted: Sat Dec 04, 2021 3:38 pm    Post subject: 1971 1700 bay window. What is line under bottom right air duct? Reply with quote
I will try to add pic. Having trouble. It looks like a vacuum line that goes into the bottom right air duct. I don’t see anywhere to attach it. Any help would be appreciated.
busdaddy
busdaddy is offline
PostPosted: Sat Dec 04, 2021 3:49 pm    Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? Reply with quote
There's a few air ducts located on the RH side of a bus, maybe a little more description?, or better yet here's how to post pictures: https://www.thesamba.com/vw/forum/viewtopic.php?t=6
Did you ever solve your coil problem?, it's polite to post a resolution (or update) to the problem in the thread it was discussed in.
Слава Україні!
SGKent Premium Member
SGKent is offline
PostPosted: Sun Dec 05, 2021 12:19 am    Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? Reply with quote
here is a photo of a typical 1971. From the gallery.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Abscate Premium Member
Abscate is offline
PostPosted: Sun Dec 05, 2021 5:20 am    Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? Reply with quote
Could be a nonstock vacuum operated hot air door. I’m guessing it’s not a vacuum line.
.ssS!
busdaddy
busdaddy is offline
PostPosted: Sun Dec 05, 2021 10:03 am    Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? Reply with quote
72 model built in late 71?, could be the fuel pump drain hose. Confused
Слава Україні!
KTPhil Premium Member
KTPhil is offline
PostPosted: Sun Dec 05, 2021 11:13 am    Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? Reply with quote
Part of the tank vent/evap system?
Newmanthetiedyebus
PostPosted: Mon Dec 06, 2021 8:53 am    Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? Reply with quote
I uploaded a pic. Its a line of some sort that goes into the tin under the valve cover on the passenger side. The manual calls it the bottom right air duct. That might be causing some confusion. It has a finished hole in the forward part of the tin where the line fits nicely. It was in there when I took the tin off. But I don’t think it connects to anything. At least I couldn’t find anything to connect it to??
busdaddy
busdaddy is offline
PostPosted: Mon Dec 06, 2021 8:55 am    Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? Reply with quote
Fuel pump drain/vent, it just sticks into the hole in the sled tin.
Слава Україні!
Newmanthetiedyebus
PostPosted: Wed Dec 08, 2021 9:06 am    Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? Reply with quote
Thanks everyone for the comments. Nothing is leaking out of it and performance isn’t affected at all so going to go with vent/drain. And busdaddy yes I fixed the coil issue. Sorry I didn’t give an update. I replaced the coil, points, and condenser and he runs great. Still haven’t got
lights converted to led. It’s a long term project I will continue to play around with.
Abscate is offline
PostPosted: Wed Dec 08, 2021 9:12 am    Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? Reply with quote
Man, am I senile. I would have sworn my last carbed By ,a 1972, had the fuel pump in the left side near Number 3
.ssS!
P24p1
P24p1 is offline
PostPosted: Thu Dec 09, 2021 8:13 am    Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? Reply with quote
Oh my a thermostat! Quick someone take a picture and record it, those things are going extinct!
1973 Westfalia named Angie
What rust?
Rev it - don't lug it!
vwwestyman
vwwestyman is offline
PostPosted: Thu Dec 09, 2021 11:11 am    Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? Reply with quote
...I mean, the picture is right there... Very Happy
Dave Cook
1973 Wild Westerner
My Thing
P24p1
P24p1 is offline
PostPosted: Thu Dec 09, 2021 12:21 pm    Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? Reply with quote
That's a very good point
What rust?
