modok Samba Member
Posted: Sun Dec 05, 2021 2:22 pm Post subject: Re: Ever have aluminum crank pulley make alternator belt slip |
Doesn't your conversion technically use a modified type-1 steel pulley?
I remember helping a guy machine the bolt holes into it. |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6032 Location: CONGERS, N.Y.
Posted: Sun Dec 05, 2021 4:09 pm Post subject: Re: Ever have aluminum crank pulley make alternator belt slip |
Modok, excellent memory, ha!!!!
Yes as you can see in the photo from back in 1992
The second photo of a two page article what was in VW Australia, and was sent to me from Mike Sharp of Sharpbuilt Australia.
I did him a favor and sent a Porsche Fan to him and in return he send me parts from his conversion. One was the Aluminum Crank pulley.
Those Aussies sure talk funny, !! I had to ask Me what a Sidchrome was????
No internet back then so it took weeks to get an answer.
_________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
modok Samba Member
Posted: Sun Dec 05, 2021 7:49 pm Post subject: Re: Ever have aluminum crank pulley make alternator belt slip |
That's an odd one for sure
Last one that got me was "alf-oil" which turns out was aluminum foil, like.....
"Got some leftovers from maccas so I wrapped it in alf-oil" |
Posted: Thu Dec 09, 2021 12:03 pm Post subject: Re: Ever have aluminum crank pulley make alternator belt slip |
Finally got to take off the Alternator Belt.
The reason why my alternator light was some times going on at start up.
I cannot believe that belt was in my bug so long. The spare belt I kept in the trunk which Is on the bug now had the date I bought it with the other belt. 22 years ago. Looked fine, till I took it off. The rubber was cracked in many places. This lengthened the inside of the belt and made the belt slightly larger. placed the new belt in with same wedges and is was much tighter. _________________ email: [email protected]
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Thu Dec 09, 2021 12:56 pm Post subject: Re: Ever have aluminum crank pulley make alternator belt slip |
You should probably get a new belt I've heard horror stories where a worn belt is replaced with a NOS one found in the trunk, only to have it fly apart into a million pieces about 100 miles later _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Thu Dec 09, 2021 3:46 pm Post subject: Re: Ever have aluminum crank pulley make alternator belt slip |
evanfrucht wrote: |
You should probably get a new belt I've heard horror stories where a worn belt is replaced with a NOS one found in the trunk, only to have it fly apart into a million pieces about 100 miles later |
This belongs in a display case, not on a running engine.
_________________ Glenn
Member #1009
#BlueSquare |
Luftwagen 2180 Samba Member
Joined: November 24, 2020 Posts: 50 Location: Ontario Canada
Posted: Thu Dec 09, 2021 4:01 pm Post subject: Re: Ever have aluminum crank pulley make alternator belt slip |
How old is the aluminum pulley? A V belt grips on the sides mostly because it expands there when the belt flexes. Bend a belt and look. If the pulley sides aren't flat and are dished out then the pulley is worn out and you have to rely on excessive belt tension to keep it from slipping. |
